    Maxwell for SU VS Twilight
    extensions
    121 Posts 25 Posters 25.1k Views 25 Watching
    • jason_marantoJ Offline
      jason_maranto
      I haven't looked at twilight for quite some time, so I would be no help there but it seems to me that you already have quite a bit of information in regards to the 2 engines within this thread -- the only way you'll likely get more is by actually trying them.
      If you do, give back to the community by posting your thoughts and the reasons you came to the conclusions you did.
      Also don't underestimate the value actually working within the UI and workflow -- if it doesn't work for you then it doesn't matter how nice the results other people get are.
      Best,
      Jason.
      • Z Offline
        Zoom123
        I installed both applications and I am trying them. I might even add the 14 day Shaderlight Trial to the mix!
        • Z Offline
          Zoom123
          I downloaded the trials of Shaderlight and VRay for SU to try them out in addition to Maxwell for SU and Twilight.
          Shaderlight is really simple to use, has a nice interface and several video tutorials and webinars which all combine to make it a good choice for new users that don't want to spend a lot of time to learn a program. Unfortunately it didn't take me long to notice some quite significant issues with the rendering engine. In their forums they said that they are working on these issues to be solved in the next version, but personally I will have to eliminate Shaderlight from the options I am evaluating.
          Vray gave me some good results with mostly default options on exterior scenes. The only question is if I will be patient enough to learn how to use it!
            jason_maranto
            Vray doesn't fit the "easy to learn and free" criteria you had established in the beginning... are you considering buying something now?
            Best,
            Jason.
            • Z Offline
              Zoom123
              Best,
              Jason.
              Yes, although I still don't think I want to spend $800, especially if I can get something adequate for me for $100 or $0. Vray has a 30 day trial, if within this time I manage to learn it good enough to be able to produce results much better and/or much faster than any other renderer then I will consider it.
              I am also planning to test Kerkythea and Indigo RT. How do these compare in terms of learning curve?
                jason_maranto
                Yeah at $800 for VRay you could get the full Maxwell Render Suite for less at $700 which offers much more room to grow beyond just working inside SketchUp.
                The others I don't know very well, so hopefully somebody else can comment.
                Best,
                Jason.
                • Z Offline
                  Zoom123
                  My issue with Maxwell so far is rendering speed. Would the Render Suite be significantly faster?
                  I understand that unbiased renderers are slower by nature but that in the end they can produce more realistic results. The problem is that trial and error is part of the learning process for me, and with a slower renderer I would learn slower as well.
                    jason_maranto
                    Generally setup time with an unbiased renderer is greatly reduced -- so the render takes longer but the setup time takes less which to me is a good tradeoff. Set-up time requires you to be in front of your computer and actively engaged -- whereas render time does not... you can easily render at night or other times when you will not be using the computer.
                    This way the computer is working for you, as opposed the you working for the computer.
                    Also Maxwell comes with 5 render nodes included so you can have up to 6 computers working together or separately on whatever you need.
                    Best,
                    Jason.
                    • Z Offline
                      Zoom123
                      I guess that would work good when you know exactly what you are doing and you know what results you will get. So you set everything up the way it should be and then let it run overnight. But when I am learning I like to experiment. I would change something, e.g. lighting or a material, and then render to see what effect my changes had. Then change it some more and render again, and so on and so forth.
                      It would be nice to have some sort of "lower quality" setting that you can use while learning or experimenting, and then when you are satisfied with the results let it run overnight for the best quality.
                      • Z Offline
                        Zoom123
                        After about a week of trying different applications (Twilight, Maxwell for SU, Shaderlight, V-Ray for SU and Podium) I finally decided to settle on one of them.
                        Obviously it would be be impossible to fully learn all applications within such a limited time but a decision had to be made eventually even with the limited info I could have during such short period.
                        I made a model of my home office in Sketchup and then I tested each of the above applications based on the following factors (in no particular order):
                        1. How close the rendered image was to my actual home office (both during day with light from the window and night with artificial lights)
                        2. How user friendly and easy to use was the interface
                        3. Required features
                        4. Availability of Tutorials and video Tutorials online to help me learn the application quickly.
                        5. Cost
                        6. Speed of Rendering
                        Shaderlight had the easiest to use interface, had several tutorials and webinars and it was relatively fast. Unfortunately the rendering engine itself didn't seem to be up to par with some of the other applications, while the cost was higher than most of the other options.
                        Podium was also very easy to use although the interface didn't seem as refined and it had fewer features. Some presets were very fast to render, but unfortunately the rendering engine again didn't seem to be at the level of some other applications (even with the best quality presets which took much longer to render). The cost is not high, but still higher than some of the competition.
                        I tried V-Ray to have a taste of what seems to be the favorite application for many here, even thought the cost was way higher than the rest. I got good results rendered quickly without messing too much with the zillion options available. There are also plenty of tutorials online about Vray. But ultimately the cost was too high for me and so was the learning curve (no point in paying $800 and then using just the defaults). Since I am not a pro I decided that I was not really willing to give up the amount of money and time required by V-Ray.
                        Maxwell for SU (standalone) has a nice and quite intuitive interface, although not as easy to use as Shaderlight or Podium. There are some nice tutorials online, but not that many yet (this app is new). The price is great and there is a free version with no time limits. Unfortunately for the time being it lacks a feature to easily create spotlights and it renders relatively slow. But if you don't mind to wait longer then the results seem to be very good.
                        I got very good results from Twilight, which if not equal are very close to those by V-Ray and Maxwell. Twilight has presets that give good results fast and other presets that give better results slower. It is not as easy to use as Shaderlight and Podium but it is almost as easy and with more features and at a better price. On the minus side the interface is not as polished as some of the other apps and I couldn't find any good video tutorials. My main issue with Twilight is that light strength is entered as some vague number (Podium does this also), not as Watts/Efficacy, Lumen or any real world unit as is the case with the other applications.
                        My choice in the end of this week was Twilight because none of its issues was a "deal breaker". I also liked Maxwell for SU and I will try it again if/when they include MXED, or some other way to include spotlights or IES lights. Shaderlight also showed potential, but I would consider it only if they make the improvements they promised in their rendering engine and also drop the price.
                        • majidM Offline
                          majid
                          just prepared a fast model to compare light/render quality using maxwell and twilight.
                          on my machine twilight/kt and Thea were faster and less noisy comparing to free maxwell. but needs more feedback
                          zzz2.zip
                            jason_maranto
                            I'm not sure what makes you think this is a good test scene for Maxwell (or anything else) -- the render I'm getting with your environment settings and exposure settings is basically a blown-out white mess.
                            Also one of your materials (the pink plastic) exceed the RGB to Spectral (CIE xyz) color conversion recommended threshold for real world surfaces -- a brightness of about 87% or RGB 225, 225, 225 is the real world brightness of a white sheet of paper... anything brighter than that is not only unrealistic but also will produce more noise by reflecting too much energy back into the scene.
                            Also the low roughness of the emitters reduces the light emitting strength (so that the parameters are no longer true to life) and adds no appreciable effect if you are intending an indoor scene (but for that you would need to turn off the physical sky, which is adding unnecessary calculation time).
                            Also surrounding an emitter with shiny metal is a very bad idea as this introduces reflected caustics into the scene which will create more noise and make render times longer for no good reason.
                            And finally Maxwell is a render engine that is meant to work with real-world parameters and that means everything should be modeled to real-world scale and have the same details as a real-world objects -- as near as I can tell this scene bears no relationship to any real world scenario that has ever existed.
                            If you want a good test scene try one of the "eye candy" models that are modeled very well and will show what Maxwell is capable of when dealing with geometry that is properly made.
                            Best,
                            Jason.
                              jason_maranto
                              Here's a couple of renders at 800 pixels wide using your scene as-is (geometry-wise) but with a few materials edited and the physical sky turned off(see attached sketchup file).
                              The free version of the plugin only has the "draft" engine which is not well suited to complex lighting -- the $99 version comes with the prodcution engine which is better suited to such tasks.
                              10 minutes with draft engine
                              10 minutes with production engine
                              zzz2_j_material_edits.skp
                              I can get better results by editing the geometry which I will do next.
                              Best,
                              Jason.
                                jason_maranto
                                Here's the a version with edited geometry (see attached SketchUp file) at 10 min with the production engine ($99 version of the plugin)
                                production engine 10 mintes.
                                Here's the results of the same scene using the full Maxwell Render Suite ($696.50) at 10 minutes and with Color Multilight enabled which allows me to not only adjust the intensity of the light but also the color as well.
                                Maxwell Render Suite 10 minutes.
                                changed intensity after render.
                                changed intensity again.
                                changed color and intensity
                                zzz2_J_edited.skp
                                Best,
                                Jason.
                                  jason_maranto
                                  I suppose I should say as a point of reference I am using a Intel i7 920 processor (@2.67 GHz) -- which is hardly the latest/speediest hardware available... so anybody who has a better processor/ more cores should be able to get much better/faster results.
                                  Best,
                                  Jason.
                                    jason_maranto
                                    Here's why you would not want to use physical sky in an interior scene.
                                    Both of these are rendered to the same 10 minutes, but one is a hole which reveals the physical sky lighting and the other is a simple emitter plane in the same spot:
                                    Hole to Physical Sky 10 minutes
                                    Emitter plane 10 minutes
                                    As you can see both will render white because of the exposure needed for the interior setting for this render so from a practical POV it is faster to simply use an emitter plane or a HDR emitter plane for that "hole" rather than making Maxwell slog through all the extra calculations for such a tiny opening.
                                    If there was stuff going on outside that could be seen through the windows I'd say OK, but even then IBL is a better choice than Physical Sky -- which in my opinion is best used if it is the only lighting in the scene (otherwise I prefer IBL environment or HDR emitter planes).
                                    Best,
                                    Jason.
                                    • soloS Offline
                                      πŸ’š πŸ˜•
                                      I'm guessing he put that hole in the wall for that exact reason to stress out an unbiased engine.... almost cruel.
                                        jason_maranto
                                        @solo said:
                                        :mrgreen: πŸ˜•
                                        Maybe he did at that -- pretty sadistic indeed πŸ‘Ώ
                                        Best,
                                        Jason.
                                        • majidM Offline
                                          majid
                                          @solo said:
                                          :mrgreen: πŸ˜•
                                          Best,
                                          Jason.
                                          not for sure mate, solo is right. also I was using the free version, and am not on testing a "real model" as if Maxwell is modeled to mimic the real world , so it most be also capable for a bit larger or smaller objects "that are possible in real world".
                                          twilight and v-ray also were good on this scene... no something special, but just a simple scene.......
                                          I was not aware of "roughness on emitter materials and was thinking completely at the other side!!! (imagined that it must be like a light bulb, and so, must be glossy...., as real world πŸ˜‰ ). also about the lights... I've modeled it based on one of maxwell manual scenes.
                                          at the other hand , Thea also supports more light types... that are really handy while I am not familliar with maxwell lights ( I just have experienced Mx r1.7)
                                            jason_maranto
                                            To be clear my point is that Maxwell is optimized to render scenes with realistic proportions and details in the geometry, the higher-poly the better...
                                            A test like this proves very little because nobody who is using Maxwell as it is intended to be used is actually going to ever need a scene like this.
                                            Basically all you are saying to me with this test scene is "Maxwell sucks at the pure CG look" -- which I already know, it's not meant for that.
                                            The question of speed is somewhat redundant because of course any biased engine is going to outperform unbiased engines in speed as a rule... and fully unbiased engines should generally vary in render time very little assuming they are using the same hardware resources and using similar features.
                                            And finally it has been said in just about every way conceivable that the draft engine (which is all that is available in the free plugin) is not suitable for complex lighting... it can be used but do not expect great results fast using more than 1 - 2 lightsources.
                                            The free plugin will do a very nice job on exterior arch-viz shots and IBL lit advertising-type product shots, but arch-viz interiors (with emitters) will be somewhat of a stretch using the free plugin.
                                            But at the end of all this, to be completely fair, if you are going to compare the interior results from other engines you need to use the production engine -- at $95 it is still cheaper than Twilight... and this way you would be comparing apples to apples.
                                            Best,
                                            Jason.
                                            • 2 / 7
