πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Anchor Points v1.0 Update 13/12/2011
19 Posts 10 Posters 16.0k Views 10 Watching
  • R Online
    Anchor Points
    Adds Plugins Menu Item 'Anchor Points' which places
    a construction point at a Group/Component Bounding Box corners.
    Construction Points are placed on a layer named 'Anchor Points'
    Donations: By PayPal.com to info @ revitrev.org
    [flash=600,338:1n0n27ee]http://www.youtube.com/v/0rq6XX8fNXk[/flash:1n0n27ee]
    Thanks to TIG for all the help
    AnchorPoints.rbz
      mitcorb
      Good idea Rich and TIG:
      I need to get the Sketchup maintenance release 2.
        You can still install the plugin, just rename it to .zip and install it like any other old plugin.
        • R Online
          Sorry, this is in the new format .rbz because I dig evolution πŸ‘
            mitcorb
            Hi, Rich:
            There is no need for concern. As ThomThom says, I can simply rename it to .zip. I just needed the reminder. Thanks, all.
              Ha! I saw this on YT before here. Very useful. When I was a newbie and was placing cylindrical columns, I suffered a lot not having anything to grab the components at.
              Now as I do not model any more, I do not need plugins like this either. πŸ˜†
              • R Online
                I don't model either, maybe we should meet up and get twisted? I'll bring the wine you bring the water and eggs πŸ‘
                  What wine? Did you guys started to build greenhouses for vineyards in Ireland lately? πŸ˜’
                    ken
                    Thomthom
                    Do you need to rename the file's extension, or can you just associate the file extension (rbz) to a zip program. I made the rbz file extension to be associated with 7-zip. So the question is if I keep the file extension rbz, associated with 7-zip will I run into problems later on when the internal zip files structures become more complicated.
                    Ken
                      I have Total Commander on Windows and associated rbz with it and can open it up just like a zip file. TC does the same for me with all the fancy, renamed zip files for Thea too.
                      When I get to some serious GE modelling (you never know what you have to do for a living), I will also associate kmz files with TC.
                        Sure, if you use an archive program you can just open the file with that. It was just how I do it because I simply use Windows' built in zip feature in Explorer.
                        • tridemT Offline
                          tridem
                          Useful plugin πŸ‘
                          I got the error "undefined method `file_loaded?' for module ROB"
                          after a little search, I fixed it in this way
                          • R Online
                            Thanks Luca πŸ‘
                            First post updated to reflect Luca's detective work
                              Pan347
                              good job and useful. maybe next version hide &unhide option. i create shortcut Shift + A (for anchor point) but i change visiblity for unhide manually. maybe upgrade for hide/unhide. Thanks.
                              • asimonasA Offline
                                asimonas
                                tool palette for this plugin keeps reappearing on Mac each time I start Sketchup it comes on top. I love the plugin and keep it in my toolbar, but tool palette just keep poping up πŸ˜„ I know many other plugins has save problem, but please fix if its possible. Here is a screenshot
                                  Dacicusan
                                  Ok. This plugin is creating Anchor Points. But how to use them?
                                  • jujuJ Offline
                                    juju
                                    Did you take the time to go through the thread and have you looked at the Plugin Store entry for this?
                                      Dacicusan
                                      Yes, I did. And I watched the short youtube presentation which don't understand what is doing, and I read the following statement which it is not very clear for me, and finally I don't understand how to use them:
                                      "Adds Plugins Menu Item 'Anchor Points' which places a construction point at a Group/Component Bounding Box corners.
                                      Construction Points are placed on a layer named 'Anchor Points'"
                                      • jujuJ Offline
                                        juju
                                        Rich, any chance you could update this extension so one could preset / assign which layer you would like the anchor points to be placed on?
