    Raised Shapes mapped onto a Cylinder
    3 Posts 3 Posters 183 Views 3 Watching
      deedub
      We have a need to raise shapes on a cylinder, like a rolling cookie cutter. I have played with a few ideas, but I am running out of them. Any suggestions?
        If the raised areas are simple 'extrusions' outwards why not try positioning the grouped cylinder on its side and the shapes to use grouped above it. Color those faces distinctively
        Then use SuperDrape to drape the faces and color onto cylinder.
        Now edit the cylinder and select one colored face and right-click > Select > All with same material...
        • Alan FraserA Offline
          Alan Fraser
          My first thought woud be Tools on Surface to actually draw the shapes on the cylinder...followed by Joint Push/Pull to extrude them.
          EDIT: ...or SuperDrape, as TIG suggests. It depends on the shapes that you want.
          3D Figures
