    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 105.2k Views 43 Watching
    • gillesG
      gilles
      Playing with it I notice that it does not detect hole in face, this could be a great improvement.
        New concept of Boolean opérations! 😎
          RichardCherry
          Wow!
          Fantastic tool. Thank you very much 😄
          • sadyoS
            sadyo
            Great Thanks Tak2Hata, it working like a charm now
            • utilerU
              utiler
              @tak2hata said:
              Hi utiler.
              Your second question is the direction of the this plugin's future.
              1st question is No.
              It need only face for hole.
              Tak2hata, another question:
              When you create the whole in the solid it appear to expolde the profile shape; eg: circle / polygon.... Can you force the resulting edges to be hidden?
              thanks mate!! 👍
              Just Curious...
              • mitcorbM
                mitcorb
                Hi. I just tried to extract with Winzip eval version and got this in error output:
                Extracting file: C:\Program Files (x86)\Google\Google Sketchup 7\Plugins\HoleOnSolidTool_v1_01.zip
                Extracting to "C:\Program Files (x86)\Google\Google Sketchup 7\Plugins"
                Use Path: yes Overlay Files: no
                Unable to process "HoleOnSolidTool_v1_01".
                Severe Error: Not permitted or able to create an output directory.<<
                Anyone have any ideas on this? Perhaps 7zip? Note that I am placing this in x86 where my Sketchup 7 version resides. Is this tool only for Sketchup 8?
                  RichardCherry
                  So this plugin only works with the "Pro" version? The free version does not have solids so I am unable to use it 😞
                  Thanks for the great plugin even though I am unable to use it.
                    How did you come to that conclusion? Looking through the thread it appears that other users of the free version of SketchUp have been using the plugin. The free version of SU doesn't have the Solid Tools but it still identifies solid groups and components.
                      RichardCherry
                      I tried the plugin with groups and components and it would not pick the solid feature. So I assumed it only worked with the pro solids.
                        Post an example SKP file in which it doesn't work.
                          RichardCherry
                          Certainly. When I get home this evening I'll post an skp file. Any and all help is appreciated 😄
                          Edit:
                          I figured out what I was doing wrong 😄
                          You have to have the profile lined up with the solid in order for it to work. I had my profile off to the side. My mistake, sorry.
                          Gorgeous plugin.
                          • B
                            boilingsnow
                            really powerful tool. thank you very much.
                              Edit:
                              Gorgeous plugin.
                              Yep, that would do it.
                              • mitcorbM
                                mitcorb
                                As a followup on my previous comment, I did manage to extract and copy drag from the Winzip UI into the plugins folder the two files .rb and icon. When I tested in Sketchup 7, selection would not progress beyond the prompt for the first object/ group which was simply a cubic form made into a group and a circle oriented appropriately. Previously, in XP, I could right click on the zip file already in place in the plugins folder, "extract to here" and see the files deployed appropriately. Any thoughts on what I have managed to miss in the provided info?
                                • T
                                  tak2hata
                                  Hi mitcorb.
                                  This plugin use property of volume.
                                  Sketchup supports solid in later version of 8.
                                  As matter of fact,I think this script may work ,when it judges the Group(Component) is solid.
                                  I must create the method of that judgment for that purpose.
                                  I inquire later.
                                  Thanks.
                                  by TAK2HATA
                                    @mitcorb said:
                                    Hi,tak2hata:
                                    Here is the Ruby Console error message:
                                    Error: #<NoMethodError: undefined method volume' for #<Sketchup::Group:0xa789048>> C:/Program Files (x86)/Google/Google Sketchup 7/Plugins/create_hole_on_solid.rb:298:in onLButtonDown'
                                    I'm guessing you are not using SketchUp 8 - group.volume is a method available since SU8 when SU introduced solids.
                                      Ah - just noticed the file path of your SketchUp in the error - you're on SU7. That would be the problem.
                                      • mitcorbM
                                        mitcorb
                                        Hi,tak2hata:
                                        I see your demo suggests that only available in Sketchup version 8 by the fact that the default component in the demo is Susan. Yet your user profile says you use Vista and Sketchup V7. Perhaps in your first post, mention that this is for V8 only?
                                        • mitcorbM
                                          mitcorb
                                          Thanks, ThomThom:
                                          Yes, I realize that, now. The confusion came from noting the author's profile and subsequent responders profiles have not been updated, so I assumed that this plugin was available for SU v7 also.
                                          I do have Sketchup V8 but I have not yet installed it there.
                                          • T
                                            tak2hata
                                            @mitcorb said:
                                            Thanks, ThomThom:
                                            Hi, Mitcorb and ThomThom.
                                            I improve this plugin.
                                            This will work on Sketchup v7(perhaps v6).
                                            I abort using "volume" property.
                                            Thanks.
                                            by TAK2HATA
                                            • 2 / 7
