    Maxwell Render may soon break SU's poly limit
    extensions
    20 Posts 5 Posters 3.3k Views 5 Watching
    • jeff hammondJ
      the high poly component is inside the .skp itself.. (it doesn't have to be placed anywhere inside the scene)
      name the high poly version something like 'mapletree'
      make another component (could be a guide point or something simple) and name it 'mapletree_dummy'
      place the dummy components where you'd like the actual trees to be located then when exporting, skindigo will replace all the dummy versions with the real ones..
      look at the component window in the su screenshot i posted above.. there are three high poly grass components then three other components named the same thing with '_dummy' added. so that render has 3 different high poly grass patches being scattered about.
      • jeff hammondJ
        fwiw, the final render in this example ends up being around 115,000,000 entities but the sketchup model is fully navigable/not sluggish at all..
        exporting from skindigo to indigo took 6 seconds..
        not bad πŸ˜„
        • jason_marantoJ
          jason_maranto
          The Maxwell plugin has had proxy components for a while as well -- what we are talking about is external MXS files, which can be as large as you want and will never have to be contained within SketchUp at any point.
          If you watch my last tutorial video I explain exactly the same proxy component feature in Maxwell in detail: http://youtu.be/2N1uzZvOw_U
          Best,
          Jason.
          • jeff hammondJ
            ^ oh.. oops 😳
            but yeah, you can assign groups/surfaces/etc to link to external meshes as well via skindigo.. (meshes not contained within the .skp itself).. i think the only caveat is that your .skp file must contain identical material names as the linked mesh file.
            i haven't even experimented with this feature but maybe i'll try some things with it tonight..
            • jason_marantoJ
              jason_maranto
              Cool, if that works the way I think it should that should be awesome -- here's the link to some free XFrog trees and flowers: http://xfrog.com/130-free-xfrogplants-now-available/
              I would be very interested in seeing if you can link to any of those externally from SketchUp, if so that is a big feather in their cap.
              We only just got the ability to have external MXS references in the 2.6 version of Maxwell and that functionality has not made it's way into the SketchUp plugin yet...
              Best,
              Jason.
              • EdsonE
                Edson
                It would look something like this - You create some geometry - a low poly car, for example. Somehow (via naming perhaps) you link the geometry with a maxwell file containing a high poly car. When you export your scene to Maxwell, then, it references that high poly car into your scene.
                it sounds exactly like what Shaderlight V2 does right now.
                http://www.mahfuz.arq.br
                • brodieB
                  brodie
                  Looking at it briefly, I'd guess there would be one important difference (keep in mind I'm only making educated guesses at how the future plugin will work once developed). Shaderlight seems to reference an external .skp file. That is certainly a lot better than referencing an internal component but it still isn't as good as being able to reference an external .mxs (maxwell scene) file in my opinion. I've had relatively good luck importing a single high poly car into SU but have had terrible luck trying to get a single tree into SU with all of the faces in tact and UV's correct.
                  -Brodie
                  • jason_marantoJ
                    jason_maranto
                    Referenced SketchUp files are no good -- they still fall under the limitations of what SketchUp can handle (which is simply too little).
                    An MXS file can hold massive poly-counts compared to SketchUp -- and working with those massive poly-counts is a breeze in Maxwell Studio which can import many 3D file types... and it is fast, for instance importing an XFrog tree takes only seconds.
                    If all we had in Maxwell was external SketchUp references it really wouldn't be much better than proxy components.
                    Best,
                    Jason.
                    • jeff hammondJ
                      Best,
                      Jason.
                      just had a quick mess around with indigo free version (hence the watermark) using one of those x-frog pine trees.. made a simple cube component in sketchup then linked it to the x-frog .obj on my desktop.. also had to add two material names to my .skp (Bark & Needle)
                      worked well though it took me a minute to get the scaling proper (the trees were rendering around 500' tall prior to scaling πŸ˜„ )
                      here's a link a the indigo forum showing whaat's workflow and a couple of sample renders from people that did more than 10 minutes setup.. like this one:
                      image by frutiger
                      • jason_marantoJ
                        jason_maranto
                        Nice! Now that is something worth getting excited about πŸ‘
                        Best,
                        Jason.
                        • jeff hammondJ
                          i just started a render using this link to external mesh technique with a couple of the xfrog trees.. here's how it looks in sketchup.. the cubes are the components which are linked to the trees.. (each of those free downloads has 3 different models included.. a mature tree, a young one, and another version that i haven't figure out what it it.. so this model has three pine trees instanced in the background and a couple of red leaved trees in the foreground)
                          i'll post the rendered version in the morning (fingers crossed πŸ˜„ )
                          i was curious so i made the mistake of trying to import one of these trees into sketchup itself πŸ˜†
                          also, with that earlier experiment i did, while i was sure to add the material names to the .skp. i didn't realize i had to also link the sketchup materials to the external tifs included in the xfrog downloads.. so thats why the earlier test didn't have any leaves or bark on them 😳
                          • brodieB
                            brodie
                            Very interesting. I'm guessing Indigo links the SU material with the Indigo material for the leaves/bark and that's why the material has to be in the SU file? Do you typically apply that material to something so you can still use Purge without it disappearing on you?
                            The 3rd tree is 'Adult' by the way. I think it's in between Young and Mature but don't recall offhand - it usually looks a lot like the Mature tree.
                            -brodie
                            • jeff hammondJ
                              right.. i just applied the materials to the actual dummy components (the green,purple,blue cubes as shown in the previous sketchup shot i posted).. that way, i can purge without losing the assignments.
                              i was thinking adolescent but they looked too similar to the mature for that.. adult makes more sense πŸ˜„
                              here's the rendered version of the previous sketchup shot..
                              gotta say, i really like putting trees in there like this and although this is a maxwell thread and i'm an indigo_er, the thread has enlightened me to the power of linking to meshes outside of sketchup. β˜€
                              click pic -> bigger
                              • jason_marantoJ
                                jason_maranto
                                β˜€
                                Yeah, external linking is definitely the way to go for complex organic geometry -- I've always been a fan of Whaat's work and the Indigo plugin is no exception. Thanks for showing this feature off for us πŸ‘
                                Best,
                                Jason.
                                • brodieB
                                  brodie
                                  Yes, a very cool preview of the sort of thing we should be in for. Thanks for the images.
                                  -Brodie
                                  • W
                                    Whaat
                                    :enlight:
                                    Best,
                                    Jason.
                                    Thanks Jason, and thanks Jeff for showing this feature. I am hoping to finally get around to doing some video tutorials for this sometime. It's been on my TODO list far too long.
