    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.5k Views 135 Watching
    • GaieusG
      Yes, especially this second one is extremely important for GE modelling. I think it was introduced in version 7 and was very welcome (although the AA algorithm could be better as the resulting textures are rather bad quality)
      • Wo3DanW
        Wo3Dan
        @gilles said:
        Did you know this one?
        Yes, I knew it worked on arc surfaces.
        But I didn't realize that it also works on cilinders (on a cardinal midpoint to resize it) until now.
        It even works on a truncated cone's cardinal midpoints "Doh!"
        b.t.w. The "arc surface midpoint moving" feature also works with two different arcs, top arc unequals bottom arc. I guess this is similar to being able to resize the truncated cone in "one go".
          A vicious one! ๐Ÿ˜ฎ By the complicity of John H. Aughey & Wiiki โ˜€
          Solution ! ๐Ÿ’š
          Used first Erase Inner faces ! ๐Ÿ˜’
          • P
            pingo
            Thank you, Thank you, Thank you!!
            It's taken me a few days to read through this thread and practise all the many things I didn't know before. So many helpful tips will surely make my future modelling so much easier!
            • onzkiO
              onzki
              One for me was when Gaieus was from Gaieus' talk at the Basecamp (I saw the video) and using the rotate tool.
              When you click the rotate tool and click the rotation point, don't let go of the mouse button... drag it out to either red or green (or any other snap point you set up) then click to start. This relieves any need for a vertical plane to get your rotation set up.
              See image for example.
              [attachment=0:1opsd1fn]<!-- ia0 -->ClickHold.jpg<!-- ia0 -->[/attachment:1opsd1fn]
              I have been using SU since V2 and never knew that until last year.
              This is one of my biggest Duh as well ๐Ÿ˜„ It's almost a year before I discovered it- by Accident! ๐Ÿ˜„ Before, I first do new axis, then rotate.. I've read the thread above, it's so funny and informative especially when I read things that I encountered, reminding me that I'm not alone:)
              [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
              • onzkiO
                onzki
                @d12dozr said:
                You can use the Move tool on the cardinal points to change the radius of an extruded circle as well
                This is amazing! It's like working in 3DSmax edit poly mode haha
                • onzkiO
                  onzki
                  Okay my latest Duh might be not very helpful to everyone as compared with above mentioned Duh's.. but for those who forgot it- "turning on/off Hidden geometry" from view menu helps you edit a smoothened surface. Imagine I even posted a thread on wishlist requesting for un-smoothen or anti-smooth plugin lol ๐Ÿ˜„.
                  • C
                    cordless101
                    My Duh! When you have started a new model from scratch, autosavewill work only after you have saved and named the file yourself first.
                    • C
                      cordless101
                      I just noticed that when orbiting with the wheel, if you hold down the left button it turns to pan. I really like that, don't have to use the keyboard to pan.
                      • plot-parisP
                        plot-paris
                        Wow, I really have to try that!
                          mirale999
                          I noticed that the text tool have the second use to place a label on the screen: you can just select the tool and put the icon to the blank place and click...
                          You can write:copyright xxx~
                          I know someone have known that, but to me it's a big shock, and drives me to find more new method to use sketchup.
                          And I realized the "paste in place" can be used between different files in October this year.
                          paranoia is a higher form of awareness...
                            mirale999
                            One more Duh:
                            If you are using a draw tool- drawing a line or a rectangle or an arc etc, and you've just drawn a first point,
                            you can now use the camera tool like walk, position camera, look around etc, to change your view, and then again use the draw tool,
                            your first point won't lose, you can finish your line or rectangle~ ๐Ÿ˜Ž
                            Below is a short example(a small video)
                            If you are working in a narrow space, it's useful~
                              Seems it's valuable with all tools of visualisation ๐Ÿ˜‰
                              CLick on mouse wheel, + Shift and move etc...
                              • G
                                gr8fzy1
                                Also, this is an older one, but:
                                I knew that if you used the push pull on a face and typed in a pull length, it would push/pull to that length. Double clicking on the face or another face would repeat the push/pull again. But it took me forever to realize that that was on just WHITE faces...if you double clicked the push/pull on a BLUE face, it would push/pull the exact OPPOSITE direction!
                                Example: Pull a white face up on the blue axis two feet. Double click on another white face, it repeats. Double click on a BLUE face, it SUBTRACTS two feet.
                                • G
                                  gr8fzy1
                                  OMG, the K key makes back edges visible! How could I have used this thing for 2 years and discover that NOW?!?
                                  I feel like Superman now with my X-ray vision!
                                  • cottyC
                                    cotty
                                    @gr8fzy1 said:
                                    ...Double click on another white face, it repeats. Double click on a BLUE face, it SUBTRACTS two feet.
                                    It is always in the direction of the positive face normal (white=front).
                                    my SketchUp gallery
                                    • C
                                      cordless101
                                      Thanks! Great tip for me.
                                        hehe - I ran into this a couple of months ago my self. Thought initially I'd activated X-Ray mode, and kept tapping the X key, couldn't work out what what going on. doubleduh!
                                        (Today's not-quite SketchUp duh... or doh!: Tried to orbit a png file... tried to pinch the monitor, because my laptop got touchscreen and my "smart"phone. x_X not the best of days...)
                                        • GaieusG
                                          SU did not even have back edges 2 years ago - only since last September. ๐Ÿ˜„
                                          Also be very careful with this feature. When you draw a shape on the ground plane, it has its back face up. Now PP it to a height - it will suddenly reverse that pushpulled face and it will be a front face. Now repeating the operation by double clicking will PP it back but also your 2D shape disappears since it's PP'd to the (now) opposite parallel face (just like when you PP an opening)
                                          • G
                                            gr8fzy1
                                            Yay, so that takes ONE year off my duncery! Thanks Gaieus! Shakes hand
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 34
                                            • 35
                                            • 16 / 35
