    Do i need plugins do so modeling with sketchup?
    16 Posts 7 Posters 2.1k Views 7 Watching
      Tekkybot
      ok. what is soap skin and bubble and how does it apply to modeling with sketchup?
        If you need a approximation of how tensile structures behave, that's the tool for you. And that's the original intent of it. I've used it specifically for such a task. I had to model up some 'umbrellas' as a roofing system for a street. We found a solution that didn't use glass, but transparent film which was pumped up by air. SSB saved me a whole lot of work for that.
          Tekkybot
          so its not for like modeling curves? what about tools on surface? and skin?
            You can use SSB to create organic shapes. I've used it to create ponds some times. Drawing the outline of the pond, use those edges to SSB and apply a negative pressure.
            Tools on surface allows you to draw lines and shapes on curved surfaces, as oppose to normal SU tools which require a flat plane.
            Skin I haven't used. But I think it generates a surface out of a selection of edges and curves..?
            • jeff hammondJ Offline
              some examples of how i use skin and soap skin bubble.
              skin does basically what it sounds like it would do..
              say i'd like to put a surface to cover up this hole: [EDIT] i should've exaggerated this more in the example but those two sides aren't parallel.. they're closer together at the bottom than at the top.. otherwise, i'd just use push/pull here πŸ˜„
              http://homepage.mac.com/jeffhammond/.Public/scf/skin1.jpg
              i can manually connect the vertexes:
              http://homepage.mac.com/jeffhammond/.Public/scf/skin2.jpg
              or i can use skin.rb:
              http://homepage.mac.com/jeffhammond/.Public/scf/skin3.jpg
              after soften/smooth:
              http://homepage.mac.com/jeffhammond/.Public/scf/skin4.jpg
              i choose which method to use based on the amount of connections and/or complexity..
              for soap skins, i mainly use them as a visualization tool.. (and i don't think the author had this use in mind but it works for me)
              say i have a complex hole to fill:
              http://homepage.mac.com/jeffhammond/.Public/scf/soap1.jpg
              skin wouldn't work here and doing this manually would be a major undertaking so i use a soap skin:
              http://homepage.mac.com/jeffhammond/.Public/scf/soap2.jpg
              after some pressure adjustments and soften/smooth i have a very fast method for visualizing this shape:
              http://homepage.mac.com/jeffhammond/.Public/scf/soap3.jpg
                Tekkybot
                good post jeff πŸ‘
                  Tekkybot
                  i should rephrase what im asking... what are the STEPS needed to take to blow up a bubble when using soapskin and bubble? ? what exactly, do you DO? i notice that s/b has all these extra icons in the folder that don't appear in sketchup for me after checking the s/b menu. maybe this is why i cant get s/b to work?
                    You need to activate SSB at Preferences > Extensions (then maybe even the toolbar at View > Toolbars)
                      And a little tut for use it πŸ˜‰
                      http://www.pushpullbar.com/forums/attachment.php?attachmentid=45676&stc=1&d=1224337660
                        mfarooqi
                        Thank you MAN.. πŸ˜„
