    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 30.5k Views 16 Watching
      chyn2000
      Ok. That certainly changed things a little.
      I type:
      irb(main):002:0> require 'path_to_project\suext'
      and get back:
      LoadError: 127: The specified procedure could not be found. - Init_path_to_project\suext
      path_to_project\suext.so
      from path_to_project\suext.so
      from path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
      from (irb):2
        or
          chyn2000
          Both. The '/'s and ''s that are in the post were copied and pasted. I didn't change any of them. Let me know if you want the original output. I just shortened the paths for readability.
          -Chyn
            Jim
            TIG means try using this --> / <-- instead of that --> ** <-- in your require statement.
              chyn2000
              Ah. Gotchya now.
              Nirg. Same result...
              Anything else? Maybe is one of you guys have successfully built the example you could post it for download. That would make sure I've got my environment set up correctly.
              -Chyn
                How did you build it? Seems something has gotten confused and the path has gotten mixed into the name of the initializing procedure for the C Extension.
                It tries to call a function named Init_path_to_project\suext - where, given the name suext it should be trying to call Init_suext.
                  chyn2000
                  I built in Pelles C.
                  So, the path isn't hard coded in the program. I can place a copy of the suext.so on my d:\ and it changes the error out put to match:
                  irb(main):002:0> require 'D:\suext'
                  LoadError: 127: The specified procedure could not be found. - Init_D:\suext
                  D:\suext.so
                  from D:\suext.so
                  from d:/Ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
                  from (irb):2
                  Is there a specific directory I should have the file at?
                  • Dan RathbunD Offline
                    Dan Rathbun
                    %(#BF8000)[path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/**custom_require.rb**]
                    Why are you customizing the require() method ?
                    Try it WITHOUT loading this custom script...
                    I'm not here much anymore.
                      Jim
                      He isn't - this is something done by RubyGems.
                        Dan Rathbun
                        OK.. my bad.. N/M
                          Jim
                          You did it again.
                          Use:
                          require "D:/suext"
                          irb(main);001;0> require 'C;\SX_Basics'
                          LoadError; 127; The specified procedure could not be found.   - Init_C;\SX_Basics
                          C;\SX_Basics.so
                                  from C;\SX_Basics.so
                                  from (irb);1
                          irb(main);002;0> require 'C;/SX_Basics'
                          => true
                          irb(main);003;0>
                            Jim
                            Ok, I just built TBD's suext example using Visual Studio Express 2010.
                            In order to get the extension to require properly, I had to use:
                            require "SUExt" <-- note case
                            require "suext" failed.
                              chyn2000
                              Yep Jim. That was exactly it!
                              Thanks everyone. Let me know if there is anything I can do to help.
                              Actually, it occurs to me that we may want to start making a small library of math and geometry ruby extensions very targeted towards SU. Thoughts?
                              -Chyn
                                Not a bad idea. I had plans of doing some bezier functions.
                                  Jim
                                  Maybe wrapping up an existing library for SketchUp/Ruby would be a way to go? Here's some interesting ones:
                                  [1] http://vcg.sourceforge.net/index.php/Main_Page
                                  [2] http://www.cgal.org/
                                  [3] http://ptex.us/
                                  [4] http://code.google.com/p/ruby-sketchup-sdk/
                                  [5] http://www.visilibity.org/
                                    jefftrull
                                    I was so excited to discover that someone was building Sketchup extensions with Visual Studio 2010 - that's exactly what I need to do - unfortunately, after going through the whole process, I can't seem to successfully load the SX_HelloWorld module:
                                    require 'SX_HelloWorld'
                                    Error; #<LoadError; C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so; 126; The specified module could not be found.   - C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so>
                                    (eval)
                                    (eval);0
                                    Notice this is not a situation where the file is missing - that produces a similar but different error message.
                                    After some Googling it seemed like missing .so's are sometimes the culprit, so I tried copying over some from my Ruby build directory (win32ole.so and Win32API.so), but it didn't help. Finally I tried running Sketchup from the VS2010 command line shell - this resulted in the infamous "bugsplat".
                                    I'm at my wit's end here... any ideas?
                                    Thanks,
                                    Jeff
                                    PS: My Ruby install gives RUBY_PLATFORM=i386-mswin32_100, RUBY_VERSION=1.8.6; Sketchup gives RUBY_PLATFORM=i386-mswin32 and the same version
                                      Dan Rathbun
                                      FYI: When require loads a shared object library file (and not a ruby script,)
                                      the require(filepath) method looks for a C function named:
                                      "Init_" + File.basename( filepath, File.extname(filepath) )
                                      and runs it after loading the shared library.
                                      This means that named C function must exist (even if it does nothing,) and must be named exactly as the file is named (CASE SENSITIVE.) If an enduser renames the so (or dll, dylib, etc.,) file later (including changing the case of any characters,) then loading the library file with require() will fail. (usually resulting in a "entry point not found" error.)
                                        jefftrull
                                        Thanks for the quick response! Unfortunately, I don't think that's the issue, for three reasons:
                                        1. The error message is "The specified module could not be found", rather than "entry point not found"
                                        2. I'm using the example file from bitbucket unchanged... the name of the relevant function there is "Init_SX_HelloWorld", vs filename "SX_HelloWorld.so"
                                        3. I can use this module OK in Ruby standalone (whichever one I built with)
                                        I do think it's got to be something simple... I just can't see what it might be. The error message isn't terribly helpful 😞
                                          Dan Rathbun
                                          BTW your on Windows 7 ??
                                          Is the path:
                                          %(#BF0080)["C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so"]
                                          and what is the result of (at the console):
                                          puts $LOAD_PATH
                                            jefftrull
                                            That's right, Windows 7 Professional SP1
                                            Is the path:
                                            %(#BF0080)["C:/Program Files(x86)/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so"]
                                            No, it's "C:/Program Files/Google/Google Sketchup 8/Plugins/SX_HelloWorld.so" (no "(x86)")
                                            puts $LOAD_PATH
                                            puts $LOAD_PATH
                                            C;/Program Files/Google/Google SketchUp 8/Tools
                                            nil
                                            • 8 / 9
