    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 30.7k Views 16 Watching
      Shouldn't the C extension be protected by a sort of a "namespace"? I mean shouldn't Point3d {}; be SX_Ext_Point3D {};? If we have two diffetent DLL's, do their functions exist in a same 'space' πŸ˜„ ?
      No - only the Ruby modules, classes and methods you define - like in a normal Ruby Script. Everything else is isolated.
      As you see in the init function:
      <span class="syntaxdefault"><br />void&nbsp;Init_SX_Basics</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">void&nbsp;</span><span class="syntaxkeyword">)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Modules<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">mSUExtTest&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">rb_define_module</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">"SUExtTest"&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Constants<br />&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;>&nbsp;SUExtTest;;SX_BASIC_VERSION<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_const</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"SX_BASIC_VERSION"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">rb_str_new2</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxstring">"0.1.0"&nbsp;</span><span class="syntaxkeyword">)&nbsp;);<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;Methods<br />&nbsp;&nbsp;&nbsp;&nbsp;//&nbsp;>&nbsp;SUExtTest.foo<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"foo"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_foobar</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">0&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.multiply(&nbsp;number1,&nbsp;number2&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"multiply"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_multiply</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.pi_array(&nbsp;array&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"pi_array"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_pi_array</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.random_points(&nbsp;size&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"random_points"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_random_points</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1&nbsp;</span><span class="syntaxkeyword">);<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">//&nbsp;>&nbsp;SUExtTest.closest_distance(&nbsp;point_set1,&nbsp;point_set2&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">rb_define_module_function</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">mSUExtTest</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">"closest_distance"</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">h_closest_distance</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">2&nbsp;</span><span class="syntaxkeyword">);<br />}<br />&nbsp;</span><span class="syntaxdefault"></span>
      It's the rb_define_* that will make the extension share anything with the Ruby environment - everything else is isolated.
        chyn2000
        Hi Guys.
        First, I want to say that this project you have started is awesome. I had just decided I needed a ruby extension to get a speed boost for a plug-in project. I found a lot of tutorials on making extensions, but most were for either linux or for MS Visual Studio 6 on Windows. I'm not using either environment. I am on Windows 7 (64bit).
        Sooooo, I have followed TBD's example program the best I can.
        • I have downloaded the SUExt files.
        • I have downloaded the Ruby Installer and Source per the SUExt readme file and installed Ruby.
        • I have installed Pelles C.
        I tried to open suext.ppj file and Pelles C kept throwing an error about "suext.obj is wrongly located in -path_to_project-". So I tried suext6.ppj and it seemed to be fine. It even seemed to build once I pointed Pelles C to where my Ruby installation was at.
        From here I'm a little lost. Am I done? I brought up the irb and typed in: require 'path_to_project/suext.so'
        The results were as follows:
        LoadError: 127: The specified procedure could not be found. - Init_path_to_project\suext
        path_to_project\suext.so
        from path_to_project\suext.so
        from path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
        from (irb):1
        What am I missing?
        -Chyn
          When you require a C Extension, do not include the file extension.
          So instead of:
          do:
          require 'path_to_project/suext'
            chyn2000
            Ok. That certainly changed things a little.
            I type:
            irb(main):002:0> require 'path_to_project\suext'
            and get back:
            from (irb):2
              or
                chyn2000
                Both. The '/'s and ''s that are in the post were copied and pasted. I didn't change any of them. Let me know if you want the original output. I just shortened the paths for readability.
                -Chyn
                  Jim
                  TIG means try using this --> / <-- instead of that --> ** <-- in your require statement.
                    chyn2000
                    Ah. Gotchya now.
                    Nirg. Same result...
                    Anything else? Maybe is one of you guys have successfully built the example you could post it for download. That would make sure I've got my environment set up correctly.
                    -Chyn
                      How did you build it? Seems something has gotten confused and the path has gotten mixed into the name of the initializing procedure for the C Extension.
                      It tries to call a function named Init_path_to_project\suext - where, given the name suext it should be trying to call Init_suext.
                        chyn2000
                        I built in Pelles C.
                        So, the path isn't hard coded in the program. I can place a copy of the suext.so on my d:\ and it changes the error out put to match:
                        irb(main):002:0> require 'D:\suext'
                        LoadError: 127: The specified procedure could not be found. - Init_D:\suext
                        D:\suext.so
                        from D:\suext.so
                        from d:/Ruby/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
                        from (irb):2
                        Is there a specific directory I should have the file at?
                        • Dan RathbunD Offline
                          Dan Rathbun
                          %(#BF8000)[path_to_ruby/lib/ruby/site_ruby/1.8/rubygems/**custom_require.rb**]
                          Why are you customizing the require() method ?
                          Try it WITHOUT loading this custom script...
                          I'm not here much anymore.
                            Jim
                            He isn't - this is something done by RubyGems.
                              Dan Rathbun
                              OK.. my bad.. N/M
                                Jim
                                You did it again.
                                Use:
                                require "D:/suext"
                                irb(main);001;0> require 'C;\SX_Basics'
                                LoadError; 127; The specified procedure could not be found.   - Init_C;\SX_Basics
                                C;\SX_Basics.so
                                        from C;\SX_Basics.so
                                        from (irb);1
                                irb(main);002;0> require 'C;/SX_Basics'
                                => true
                                irb(main);003;0>
                                  Jim
                                  Ok, I just built TBD's suext example using Visual Studio Express 2010.
                                  In order to get the extension to require properly, I had to use:
                                  require "SUExt" <-- note case
                                  require "suext" failed.
                                    chyn2000
                                    Yep Jim. That was exactly it!
                                    Thanks everyone. Let me know if there is anything I can do to help.
                                    Actually, it occurs to me that we may want to start making a small library of math and geometry ruby extensions very targeted towards SU. Thoughts?
                                    -Chyn
                                      Not a bad idea. I had plans of doing some bezier functions.
                                        Jim
                                        Maybe wrapping up an existing library for SketchUp/Ruby would be a way to go? Here's some interesting ones:
                                        [1] http://vcg.sourceforge.net/index.php/Main_Page
                                        [2] http://www.cgal.org/
                                        [3] http://ptex.us/
                                        [4] http://code.google.com/p/ruby-sketchup-sdk/
                                        [5] http://www.visilibity.org/
                                          jefftrull
                                          I was so excited to discover that someone was building Sketchup extensions with Visual Studio 2010 - that's exactly what I need to do - unfortunately, after going through the whole process, I can't seem to successfully load the SX_HelloWorld module:
                                          require 'SX_HelloWorld'
                                          Error; #<LoadError; C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so; 126; The specified module could not be found.   - C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so>
                                          (eval)
                                          (eval);0
                                          Notice this is not a situation where the file is missing - that produces a similar but different error message.
                                          After some Googling it seemed like missing .so's are sometimes the culprit, so I tried copying over some from my Ruby build directory (win32ole.so and Win32API.so), but it didn't help. Finally I tried running Sketchup from the VS2010 command line shell - this resulted in the infamous "bugsplat".
                                          I'm at my wit's end here... any ideas?
                                          Thanks,
                                          Jeff
                                          PS: My Ruby install gives RUBY_PLATFORM=i386-mswin32_100, RUBY_VERSION=1.8.6; Sketchup gives RUBY_PLATFORM=i386-mswin32 and the same version
                                            Dan Rathbun
                                            FYI: When require loads a shared object library file (and not a ruby script,)
                                            the require(filepath) method looks for a C function named:
                                            "Init_" + File.basename( filepath, File.extname(filepath) )
                                            and runs it after loading the shared library.
                                            This means that named C function must exist (even if it does nothing,) and must be named exactly as the file is named (CASE SENSITIVE.) If an enduser renames the so (or dll, dylib, etc.,) file later (including changing the case of any characters,) then loading the library file with require() will fail. (usually resulting in a "entry point not found" error.)
                                            • 3 / 9
