    [Plugin] CleanUp
    974 Posts 217 Posters 833.7k Views 217 Watching
      that's the whole error message?
      If yes, then could you open the Ruby Console in SketchUp and type load 'tt_cleanup.rb' and see if you get a more verbose error message then?
      Other than that, maybe a screenshot of how CleanUp and TT_Lib2 is installed in your plugins folder?
      • jeff hammondJ Offline
        [Feature Request]
        Weld all lines... not sure if it's possible or maybe it will take too long but it'd be sweet to weld everything in one shot.
          Weld all edges between junctions?
          That can be done with Edge Tools already if you use the Simplify Selected Curves and specify 0 deviation.
          • O Offline
            oggstreamer
            about the WINE Problem
            starting it via Ruby Console gives a lot of Warnings and an Error:
            Error: #<NameError: C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/webdialog_patch.rb:10: uninitialized constant TT::System>
            C:/Programme/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:79
            C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:400:in require' C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:400 C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:399:in each'
            C:/Programme/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:79:in require' C:/Programme/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:79 (eval):79:in load'
            I think the Directory-Structure is ok - because i tried your plugin in VirtualBox today - and it works like a charm - Great Plugin btw.
            thanks,
            Georg
            tt_cleanup_wine_error.txt
              hm... this is odd... but could you try something?
              Open webdialog_patch.rb and insert two new lines at the top of the file:
              require 'TT_Lib2/core.rb' require 'TT_Lib2/system.rb'
              Not sure why only you get this, but maybe there's some quirk in that it runs under Wine...
              • O Offline
                oggstreamer
                yes - i am one step further. The plugin loads now - but the Plugins->CleanUp3->Clean... shows an empty Windows. Maybe i have to install IExplorer?
                thanks
                • O Offline
                  oggstreamer
                  I will leave it like that - the Merge Faces and erase hidden geometry works! and thats fine for me
                    πŸ‘ I will add the changes to the next release.
                    The window is a webdialog, which under windows use an embedded Internet Explorer window and under OSX it uses an embedded WebKit.
                    It's been a while since I tried Ubuntu, but I used to have an old machine with it and I tried SU a couple of times. But I usually got crashes - when I didn't I got problems with webdialogs.
                    But not sure what the status is now though - a couple of years later...
                    • O Offline
                      oggstreamer
                      i found a blog about webdialog on wine related to Sketchup:
                      Getting SketchUp 8 Working in Wine -- Even WebDialogs!
                      Updated 2010/12/22: Β Updates are shown in red Β below: Some SketchUp enthusiasts have created an excellent resource on getti...
                      (robsworldoftech.blogspot.com)
                      maybe it will work this way but i don't have time right now to try it.
                        GooUser
                        Hello thomthom ! I'm new user of sUP and this forum! Thank you for your work! And sorry for my bad English !
                        • F Offline
                          finnishXchange
                          Thom,
                          I am excited to try your program for cleaning up lines in a file imported from autocad. Would you mind explaining how to install the plug-in, or direct me to where I might find a tutorial for that? I'm a new member of this site and the only other plug-in I have used is Kerkythea, so pretty clueless what to do with the rb file after saving it to the desktop. I am using SU version 8 with mac OS x 10.6.8.
                          Thanks a lot!
                          Troy
                            Here are some instructions how to install zipped plugins:
                            http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                            Note that for this plugin to work, you will also need to install another plugin library (linked from the first post). That's also zipped so the procedure is the same.
                            • opalO Offline
                              opal
                              Hello,
                              So.. after the installation of M2, I put tt_cleanup.rb in the brand new plugins folder.. I think the shiny new empty folder confused it.. it's lonesome in there and I'm getting the messages on startup
                              tt?cleanup.rb
                              Error: No such file to load - TT_lib2/core.rb
                              So.. instead of using the copy/paste of the file from the old plugins folder, I came back to this thread and downloaded it again.. same error message.
                              Is there a companion file I'm supposed to download with it?
                                Yes, TT_Lib2, which is linked from the description in the first post. Above the download link.
                                • opalO Offline
                                  opal
                                  hmmm.. I have that one in there
                                  I'll take it out and download fresh
                                  thank you πŸ˜„
                                    Check how you extracted the files. For each plugin there is a description on how and where the files should be installed. Or even better, if you have SketchUp 8 and updated to the recent M2 update, go to Window > Preferences > Extensions > Install Extension and install the plugins from there. Just select the zip files from the file dialog that appears.
                                    • opalO Offline
                                      opal
                                      Got it working this morning ty
                                      the M2 install from within the program feature doesn't seem to see anything besides file folders and .rbs files. I went to my backup plugins folder to start getting some of the missing most used plugins back after the update from within sketchup and don't see zip or rb files with that tool.
                                        The 'button-installer' only works on .RBZ files [which are compressed archives just like .ZIP files]. By default you will only see folders or .RBZ files in the browser that is opened by the button... BUT you can trick it into showing you all file types: type *+<enter> in the file field and all files will now show... find the tool's .ZIP file and install it, it will work just like a .RBZ file... NOTE: it will install any .ZIP file... so ensure that it is a proper tool-set ZIP and not one of your holiday-photos, as they will could be copied into Plugins folder too πŸ˜‰ Also note that picking any other non-compressed archive file type will generate an error...
                                        • opalO Offline
                                          opal
                                          cool.. ty again
                                          • kingsiK Offline
                                            kingsi
                                            I am very new to Sketchup (1st week) and also one of those annoying people that never says thanks on forums. I plan on being neither from now on. So on that note many thanks for the cleanup script
                                            kingsi
                                            Noobtastic
                                            • 11
                                            • 48
                                            • 49
                                            • 9 / 49
