    Does anyone have...
    59 Posts 11 Posters 4.5k Views 11 Watching
    • utilerU
      utiler
      for skateboarding ... of course!... why waste it by putting water in there? ๐Ÿ˜„
      I don't think you have a choice, Jeff. Doesn't it ever rain in NYC...?
      Beaut model though!!
      Just Curious...
      • jeff hammondJ
        I rarely work in the city.. I just live here then fly out to build.
        regardless, I generally build inside..
        If outside, I use other surface materials & p.t. framing but nothing beats using the european plywood for the final layer. great material to work with (very strong/durable yet still pliable/workable) and the surface is super good for riding on. (fast/smooth with just the right amount of tack)
          Seems for you at little scale ๐Ÿ˜‰
          123D MAKE
          [flash=560,315:3e5fvyrn]http://www.youtube.com/v/hBHxFGXI7nQ[/flash:3e5fvyrn]
            PS Only for Mac! ๐Ÿ˜‰ ๐Ÿ˜ข
            But in SU We have TIG and its Slicer ๐Ÿ˜‰
            • jeff hammondJ
              i think it's only for windows actually ๐Ÿ˜‰
              http://www.123dapp.com/123D
              Edit -- oh wait.. 123D Make is a different app and it is mac only.. weird.
              http://www.123dapp.com/make
                I took my infos directly from to Todesk! ๐Ÿ’š
                • jeff hammondJ
                  ha! pretty neat..
                  here's the pdf output:
                  kidKnee_reducedsize.pdf
                  and a screenshot:
                  click pic -> bigger
                    Original model was SU or Rhino?
                    Seems perfect for prototype! ๐Ÿ‘
                    Any idea of time for the process till the edition to the PDF file ?
                    Next : in what material you want to make it ?
                    • X
                      xrok1
                      SWEET! ๐Ÿ˜ฎ
                      was it easy to get your sketchup model inti make?
                      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                      • jeff hammondJ
                        print it onto paper then cut it out yourself! ๐Ÿ˜„
                        or, take the pdf or eps file to your local laser cutting service (there are a bunch of those nearby.. not sure if they're easy to find in smaller cities)
                        if you send the file off then have the kit mailed back to you, i'm not sure how long it will take..
                        Next : in what material you want make it ?
                        i want to make it full size out of wood ๐Ÿ˜„
                        that said, i might take my computer or file to the guy down the street to get a $quote.. i'm curious now.
                        kidknee2_reducedfilesize.pdf
                        • jeff hammondJ
                          @xrok1 said:
                          SWEET! ๐Ÿ˜ฎ
                          took me a while to find a format that will import but eventually tried .obj and it worked fine..
                          curiously, dwg or dxf weren't acceptable formats ๐Ÿ˜„
                          • X
                            xrok1
                            thats neat. did u send it as a solid? or as a matrix like you showed your SU model earlier? I would imagine a solid.
                            • jeff hammondJ
                              yeah, just a single outer shell.. (sketchup solid)
                              I'll try some other non-solid exports later to see what happens
                              • X
                                xrok1
                                Thanks for the info Jeff. I look forward to seeing your other exports too. ๐Ÿ‘
                                  No, I speak about the calculate itself by 123 Make as soon as you have loaded your original file inside ๐Ÿ˜„
                                  In how many time the file is loaded, in how many time the PDF is calculated? ๐Ÿ˜„
                                  Instantaneous ? I can't test I have a PC ๐Ÿ’š
                                  • jeff hammondJ
                                    oh, yeah.. instant.. in the first screenshot i posted from the app, you'll see the panel on the right side.. as i change the parameters on the left, the cut list on the right updates along with the model.. the pdf is the same thing as the right panel so it's just a matter of saving the pdf..
                                    the app gets sluggish when you start making a whole bunch of intersections/slices.. i imagine these real time booleans require some serious calculating power so i'm not sure if they'll be able to improve it in that dept.
                                      Thx for the infos! โ˜€
                                        Is this feasible in a real world scenario?
                                        Would you actually frame and skin and ramp/bowl in this manner or is this something that would be new in this field?
                                        The reason I ask is because I saw a few videos of Team Pain in action. Stunt Junkies on Discovery showed the Grand Canyon ramp. So if this is a proof of concept then I'm intrigued.
                                        • jeff hammondJ
                                          yeah.. entirely feasible
                                          thing is, i wouldn't want to surface this thing.. i like how it looks.. i'd rather build it in the standard manner then maybe mirror this one next to.. that'd be sweet.
                                          yeah, it's nbd
                                          i'm not 100% sure i'd like to do it like this because i'd be paying a cnc operator to do most of the cuts instead of my crew.. i gotta look out for the boys you know ๐Ÿ˜„
                                          the mirroring scenario works out ok though.. the boys get their cash and people have something cool to look at as well as something awesome to ride.
                                          oh yeah? then you saw me on there ๐Ÿ˜„ (depending on which clip you saw)โ€ฆ
                                          90% of team pain's wood projects over the past decade are my projects (design and crew leader)
                                          • soloS
                                            Hey, it's Jeff!!
                                            ๐Ÿ˜Ž
                                            • 2 / 3
