    Intersection lines and face
    12 Posts 5 Posters 356 Views 5 Watching
    • cottyC Offline
      cotty
      Is there a possibility to intersect lines with a face?
      Example for explanation of the problem (see picture):
      a. I have some closed contours (coplanar) and want to get the outer face with holes
      b. I redraw one line of the outer rectangle to create a face, this face is not intersected by the (coplanar) lines (->only 1 new face)
      c. When I redraw one line of the inner contour, the inner face is seperated
      d.-e. the little holes can be separated this way too, but it is a lot of work with much more holes...
      So the question is if there exist a simpler workaround to intersect all the lines with the created surface (b.)?
      Cotty
      example geometry
      my SketchUp gallery
        If all is Coplanar
        Click the internal surface for select it
        Then Inverse Selection ?
        so without Plugin Triple Click on the center surface for all select then Right click/ Intersect selected
        then Click with CTL+SHIFT on the Center surface for Unselect the center selection ๐Ÿ˜„
        CTL+SHIFT = unselect from an existing selection
        So you will have Only Outer Lines + circles+ inner surfaces
        For complex selection try the plugin SelectionToy by ThomThom
        like only surface, Inverse selection etc...
        • cottyC Offline
          cotty
          Click the internal surface for select it...
          Thank you for your answer. After creating the face (b.) there is only one face. So I am not able to click the internal surface. I created an example...
          Cotty
          Example Sketchup file
          my SketchUp gallery
            that must make the trick ๐Ÿ˜‰
            If you can "save as SU 6" i will can load your file ๐Ÿ˜‰
            • cottyC Offline
              cotty
              Yesterday, I have tried to select all and intersect. The lines didn't intersect with the face.
              Today in the created example it works this way ๐Ÿ˜ฎ
              Thank you Pilou for your hint which pushed me to try it again...
              Cotty
              Example V6
              my SketchUp gallery
              • BoxB Online
                I believe it's the age old problem, you are working too small.
                SU doesn't like to create tiny faces, they can exist however. So scale up by 10 and things will work better.
                You can scale back down afterwards.
                  Select all of the edges and use one of the several MakeFaces/AddFaces tools available.
                  Now every separate area should have its own face.
                  You can simply select the ones you don't want and press <delete> - or select all using the double-triple click tricks holding down shift+ctrl so what you want to keep becomes unselected and then <delete> the faces in the 'holes'...
                  Alternatively - without a tool you can easily add a face to the outer perimeter by over-drawing an edge. Then Select that face and its edges, and all of the inner edges you want to have their own faces cut from the larger face, and Intersect> with Selection... This gives individual faces again... repeat as above to remove 'holes'...
                  • cottyC Offline
                    cotty
                    I have tried this before posting and this didn't make a difference (in this case).
                    Perhaps I had selected only the face yesterday and thought that an intersection with the model would bring the lines in the face, but it seems that the selection of the lines (lines only is enough) and the intersection is the right way.
                    my SketchUp gallery
                      A very easy workflow with your curious file ๐Ÿ˜„
                      (Next time take the habit to draw something on a big rectangle surface so no problem of intersection ๐Ÿ˜‰
                      Didier Bur Projection
                      All take 3 second!
                      • cottyC Offline
                        cotty
                        Nice one, thank you!
                        my SketchUp gallery
                        • jeff hammondJ Offline
                          yeah, sketchup is weird like that.. i've been using it for years and still never figured out exactly when or why this works sometimes and fails others.. even in the same exact model scenario on different sessions.
                          one thing i'd do in this scenario is select all the lines then copy (ctrl-C on windows?) prior to making the face.. make the face then try 'intersecting selected'.. if that fails, i'll paste-in-place (edit -> paste in place)
                          one of those two usually does the trick
                          [and if you haven't done so already, set up 'paste in place' as a su keyboard shortcut.. i use โ‡งโŒ˜V (shift ctrl V on windows?)]
                          strange how often i use this shortcut for various operations.
                            Maybe the tricks from Jeff are less jerky than mine ๐Ÿ’š
