    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 417.4k Views 154 Watching
      It's the groups/components that take the time and cause the splats!
        My sample model doesn't have any groups/components. Just edges and faces...
          Isn't the Zorro tool in Artisan more stable than this version?
            Just tried the Knife tool - crashed SU, without bugsplat.
              Did you try a series of cuts rather than just one? I find that helps sometimes!
              • dukejazzD Offline
                dukejazz
                I love useing this plugin Zorro2,
                So I added a icon to the tool bar.
                If you want to do this too,
                then paste these lines between the last end statment of zorro2.rb and its file_loaded("Zorro2.rb")
                useing notepad
                #----copy this----------
                adds a icon to tool bar
                remeber to add the attachent zorro2.jpg to plugins folder
                   if( not file_loaded?("Zorro2.rb") )
                tt_hh = UI::Toolbar.new "Zorro2"
                cmd = UI::Command.new("Zorro2 ")  {(Sketchup.active_model.select_tool Zorro2Tool.new)}
                cmd.small_icon = "zorro2.jpg"
                cmd.large_icon = "zorro2.jpg"
                cmd.tooltip = "Zorro2"
                tt_hh.add_item cmd
                tt_hh.show
                #add is compleated
                #---copy to here---------------
                • X Offline
                  xplode35
                  Seems like this plugin badly needs an update. Nothing's changed in 2 years???
                    Why fix something that is not broken? There are much older plugins still performing perfectly what they were designed for 5-6 years ago.
                    • Bob JamesB Offline
                      Bob James
                      Beta for two years 😲 πŸ˜„
                        It's the Google-way! πŸ˜‰ πŸ˜„
                          jwas
                          This is a great plugin, but it's not working for me with the model I'm working on now. The model is large and complex. Is that what's causing it to crash when trying to cut at the section?
                            The Zorro that's bundled with Artisan is apparently more stable than this I believe. Though I could be wrong.
                            Give it a go http://www.artisan4sketchup.com
                              jwas
                              Thanks. Downloading and testing now.
                                ankitsurti
                                slicing the entire model at a section plane Doesnt work for me.. Sketchup crashes and I get a bug splat!
                                  guyscott
                                  @chimbalo said:
                                  After a few hours I figure it out how to fix the bug splat, I have a heavy model, every time that I started using the slice tool my model crashed up, I tryed exploding the model, chainging to newer sketch up, etc etc etc. At the end I took all the model and grouped up whith out the cuting plane, after I slice it, and was the solution for the problem, now it doesn't matter how heavy is the file, the plug in ,work fine. sorry for my bad english, I hope is useful for you.
                                  Thank you - this advice saved me too! Took a while to dig it up though and it seems as though lots of people are searching unsuccessfully for this same solution - perhaps it should be included in the instructions?
                                  • N Offline
                                    nickdk
                                    I totally agree πŸ˜„
                                    It would be great if zorro had a feature to not delete the geometry but instead keep it as two seperate parts πŸ˜„
                                    • sadyoS Offline
                                      sadyo
                                      Zorro2 with icon.7z
                                      Dukejazz Zorro2 with icon, for newbie like me πŸ˜‰
                                      Thank you Whaat
                                        Raz
                                        Hello I am using Sketchup 8 Pro, and it seems to crash every time I try to apply this tool... Any ideas why?
                                          More details please...
                                          How complex is the model?
                                          Are you trying to slice-up raw-geometry or groups/components etc?
                                          At what point during its use does it 'crash' [and what is this 'crash' like]?
                                            ankh
                                            Happens to me too on both Skp 8 and 7. Both Mac and PC.
                                            Even if I draw a simple box and try to slice it with either Zorro or Slice Model (from the section cut dialogue) ... instant crash.
                                            (it`s not a "insufficient hardware" issue), the weird thing is that (on Skp 7) it actually worked one time and then it started crashing. I finally tried with a simple cube (non-group) and realized that the problem is with Sketchup, and not the file.
                                            I`m still looking forward to a solution.
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
