    Useful graphic apps
    extensions
    91 Posts 39 Posters 138.7k Views 39 Watching
    • N Offline
      notareal
      MeshMan - Mesh Manipulator
      (www.holmes3d.net)
      What is MeshMan?
      MeshMan is a 3D modeling tool. It loads and manipulates 3D mesh geometry in a few useful ways. It supports multiple subdivision schemes for smoothing a mesh, decimation for thinning a mesh, transforms for rotating, scaling, or translating a mesh, can tessellate a mesh into triangles, and supports a few other minor manipulations.
      The primary file format MeshMan works with is the OFF format, a simple format for storing 3D data. For more information on the OFF format, see the pages for my RoffView OFF viewing program and the related OFF Tools page. MeshMan works only with the most basic type of OFF files and does not load the texture coordinates that RoffView can handle. This is because handling that extra data is beyond the scope of MeshMan's manipulations. MeshMan can also open simple OBJ files, and can export to several other formats, including STL and PLY.
      • BurkhardB Offline
        Burkhard
        @zacchia said:
        sure this is very helpful if you work with a lot of files:
        http://www.mootools.com/plugins/us/index.asp
        You can see all files as small tumbnails. It reads different files and you can also save them as different. Also convert files with batch command or polygon reduce with batch command and much more is possilbe. I could not be without it!
        Skp files are only for 32 bit available 😠
        http://www.ia-plus.de
        • V Offline
          valerostudio
          http://www.artrage.com/Hands down one of the best 'painting' programs out there. The Ipad app is amazing and super cheap and the desktop versions are much much cheaper than Corel Painter and Artrage has all of the same functionalities.
          • Mike LuceyM Offline
            Mike Lucey
            Thanks for the headsup on Artrage. I did not know it was now available for the iPad. Must check it out AND yes the iPad Apps are great value for money. This seems to be a GOOD trend. I imagine an app like Artrage would rock on the rumoured iPadHD 👍
              bjornkn
              A program I've been using for many years, but still not often mentioned is Xara http://xara.com
              It comes in different versions, and is a very fast and nice vector drawing program as well as capable of doing a lot of bitmap editing as well. Great for materials as well as all kinds of images, brochures, pdfs, Flash animations etc.
              And it is also excellent for making great web sites, which looks pretty much identical in all browsers - which is not an easy task to do by hand 😄
              • EscapeArtistE Offline
                EscapeArtist
                Don't know if this has been mentioned already:
                https://chrome.google.com/webstore/detail/algoakekcdmbbikdjgjdahbfihboglmi?hl=en-US
                For Chrome. 3DTin.
                • 3 Offline
                  3eighty
                  Is there a free version someplace?
                  (edited by solo as free copy sounded suspect, I'm sure you meant version)
                    Pg09
                    Hello!
                    Is there a free panorama maker that i could use for my photos?
                      Jim
                      @pg09 said:
                      Hello!
                      Hugin?
                      • utilerU Offline
                        utiler
                        Ditto!!! Very powerful app!!
                        Just Curious...
                          Pg09
                          @jim said:
                          @pg09 said:
                          Hello!
                          Hugin?
                          Nice, gonna try it.
                          Thank you!
                            RichardCherry
                            Here is an app that I use quite frequently:
                            Wood Workshop (Freeware) by Spiral Graphics
                            http://www.spiralgraphics.biz/ww_overview.htm
                            It's not only great for creating wood textures it is also great for creating stone patterns as well. It has lot of flexibility and is quite powerful for freeware.
                            • tridemT Offline
                              tridem
                              😮 that's great! I believe to have already saw and then forgot it, in the past. thanks 👍
                              • mitcorbM Offline
                                mitcorb
                                I just visited the Spiralgraphics link that Richard Cherry suggested above and noted that there was a link to another app called Genetica with a Free, Pro, and Studio version. Genetica is similar, but with extended capabilities for those not familiar. I suggest checking it out. I would guess free capability with resolution up to 3000 x3000 would be ok with folks?
                                  JMdesigns
                                  Great info
                                  • mitcorbM Offline
                                    mitcorb
                                    @utiler:
                                    Great find! Amazing extension for GIMP and also open source.
                                    • utilerU Offline
                                      utiler
                                      GPS looks pretty good!
                                      GIMP Paint Studio..... watch out Artrage!
                                      Google Code Archive - Long-term storage for Google Code Project Hosting.
                                      (code.google.com)
                                      Just Curious...
                                      • utilerU Offline
                                        utiler
                                        Only played a little so far but pretty neat!
                                        Just Curious...
                                        • PixeroP Offline
                                          Pixero
                                          Make woodfloor textures yourself with the great free: "Floor Texture Generator" by Martin Chudomel.
                                          http://www.matulik.host.sk/download.php?p=0
                                          Max texture size is 2000x2000 pixels.
                                          Output is not tiling so you'll have to fix that in Photoshop.
                                          To see what can be done here's one I've made:
                                          http://dl.dropbox.com/u/7990360/Bilder/dark_woodfloor01.jpg
                                          • iichiversiiI Offline
                                            iichiversii
                                            This app couldnt come at a better time, its perfect, thanks Pixero, great find 😄
                                            Bring on the Rain...
                                            • 3 / 5
