    [Plugin] Super Drape
    192 Posts 54 Posters 383.7k Views 54 Watching
      tulacong
      oh yehh 😍 thank you
        shri
        hi TIG. i usually work in millimeters.i also tried it with increasing the
        segments of the circle but again it did'nt worked.i also tried it with sketchyphics
        installed and got extruded text over the cylinder but what i need is a coplaner text over
        the cylinder.
        here is the attachment of the test model.
        thanks.
        shri
        's super drape test.skp
          It's not the units you use but rather the physical size of the objects that can cause issues.
          However, the SKP you supplied is a 'proper' size so it should cause those problems.
          Your lettering faces are 'upside down' but again that shouldn't usually cause issues...
          Some of your 'drapee' groups are colored by applying a material to the group [e.g. the golden cylinder] i.e. rather than having materials applied to its internal faces, so superdraping 'nil' materialed faces will only add an outline and the group's color will still be seen.
          Some of your 'drapee' surfaces are 'upside down' although they do have materials applied to both faces [e.g. the green bumpy terrain] when they are superdraped the outlines appear but seem to have not taken the draper's color BUT the re-colored faces are underneath on the faces' fronts ! - reverse the faces in the mesh and redo.
          There have been issues with 'lettering' containing curved shapes Draping or SuperDraping onto cylindrical forms successfully...
          I'll investigate and see what I can tweak... πŸ˜•
            Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
            The intersecting method is now much more robust, and several recently reported glitches should now be resolved.
              smb5823
              Sketchup 8 PRO seems to crash once Superdrape.rb is added to the Plugins folder. Was the same with V1.6 but earlier versions were fine.
                TIG, that worked perfectly for me. Thank you.
                • W Offline
                  wyatt
                  1.7 gets stuck calculating for me.
                  WARNING: make_unique is a deprecated methodof Sketchup:Group
                  Error: #<NameError: undefined local variable or method nsedges' for #<TIG::Superdrape:0x135cef64>> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:303:in drape'
                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:296:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:296:in drape'
                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:121:in `onLButtonDown'
                    Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                    [I hope] it fixes the daft typo that I made that could occasional trip it up...
                    The new code should be much faster than before, and [now] more robust...
                    πŸ˜•
                    Feedback please...
                    • W Offline
                      wyatt
                      Hey Tig. 1.8 works sometimes, sometimes not. When it fails, the plugin appears to draw the physical geometry that intersects with the terrain below, but does not delete the geometry or drape the colors. I assume those actions are normally run in the background, but somehow they're happening in the model. I get this error: Error: #<TypeError: reference to deleted Edge>. If I undo and try it again, it will sometimes work; sometimes I have to explode the draped group and regroup it before it will work.
                      SuperDrapeFail.skp
                        Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                        It fixes the 'already erased edge' error that Wyatt found [he's a tough tester... πŸ˜‰ ]
                        Feedback please πŸ€“
                          πŸ‘
                          • W Offline
                            wyatt
                            Thanks, TIG. Unfortunately I had nothing better to do at work today than try to break your plugin. Thanks for updating it!
                            • N Offline
                              natsirht28
                              can you please tell me how to download this plugin..sorry im a noob
                              • Bob JamesB Offline
                                Bob James
                                Just go to the bottom of the first post on page 1.
                                We were all noobs once πŸ˜„
                                  smb5823
                                  @smb5823 said:
                                  Thanks. 1.9 solved my problem.
                                  • FletchF Offline
                                    Fletch
                                    Thanks for sharing, TIG! πŸ‘
                                    Maybe I'm using it incorrectly or expecting something different? πŸ˜•
                                    I expected that it would look like it does with the Drape tool, only with the materials painted as well. But clearly it's not like that.
                                    here's the scene to try
                                    Fletch
                                      Your assumption is correct.
                                      It's meant to be Drape with materials projected too.
                                      It does have occasional glitches.
                                      The tiny loose edge in the draped group seem to cause the issue although it shouldn't.
                                      When I erase it it drapes OK ?
                                      It seems to prevent the proper intersection of the two objects !
                                      Drape isn't perfect either in this kind of thing...
                                      Go figure!
                                      I have to allow it to drape everything, just like Drape itself, as you might well have unfaced edges etc...Capture.PNG If you do get this kind of issue then try a normal Drape then SuperDrape immediately afterwards - the projected edges will then be premade and the materials will then project OK...
                                      • W Offline
                                        wyatt
                                        I've experienced this problem too. Usually if I undo and run superdrape again (or undo, explode the geometry to be draped, regroup, and superdrape again) it will work. For highly detailed drapes, this is still faster than applying materials by hand to the mesh.
                                        • FletchF Offline
                                          Fletch
                                          ok, thank you, TIG.
                                          It sort-of works. I actually have something a bit more complex version of the scene I posted and the "delete edge-explode group-regroup-retry super drape" method does not appear to work on that version. It did, however, give me a nice bugsplat. πŸ˜†
                                          So I will use with caution. I think the drape+superdrape method for moving the materials automatically may be a nice way to go.
                                          I was actually hoping for a drape function like in other 3D apps that will drape a mesh like a cloth over an object. Is there some plugin like that for SU already of which I am unaware?
                                          Fletch
                                            • 6 / 10
