    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 83.4k Views 43 Watching
      New version added http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
        DIEGO-RODRIGUEZ
        Hi Tig. excellent update.
        I attach the file to Spanish translation.
        add the missing lines.
        Two suggestions:
        • Please delete the sound it makes when we choose the tool. is very annoying.
        • The command Ctrl + z does not work properly.
        • Would be more practical angle by reference to generate 0 to 360. instead of 0 to 180 and 180 to 360
        extrudeEdgesByLatheES.rar
          http://forums.sketchucation.com/viewtopic.php?p=184477#p184477 is the latest version with new lingvos.
            Two suggestions:
            I posted the new ES lingvo file before I read this - can you please read it and [re]advise...
            The 'beep' sound it makes is a UI.beep - edit the file and find that line in the code and add a # at the start of the line to stop it loading.
            It is not Ctrl+Z for the angle-direction 'toggle' - it's < Ctrl> alone...
            I know it would be better to have 0 to 360 degrees... BUT its coding has missed me so far - hence the 0-180 & 180-360, with a toggle <Alt>...
              I didn't read the 6 pages prior so if this is already covered I apologise...
              Attached is a .skp that Lathe removes faces from when 'Remove Co-Planar edges is chosen?
              No Ruby Console messages
              EebyL_Error.skp
                Interestingly, when I tested it I got 6+ more facets erased!
                I know why it's happening...
                When you test for coplanar-ness you look at the face normals.
                You erase edges that bound a pair of faces with the same normals.
                However, it was realized by @last/Google that this doesn't always work...
                You can have two faces that will heal into one if there common edge is erased BUT they won't return the same normal ! The tiniest variation in the normal would prevent that...
                It's all down to tolerances of how SUp works out face normals etc that are really 'equal'...
                In Line#755 it says ... e.faces[0].normal.dot(e.faces[1].normal) > 0.99999999999 - i.e. it's almost one!
                If I add/subtract an extra 9 on the end it's even worse??
                My own separate 'erase_coplanar_edges' tool uses 0.99999999 and that fails too... but with only two faces lost that time! But if I try to use its 0.9999999 test in EEbyLathe it'll still knack up...
                So... it's not an error just one of the limitations of the tolerances that crop up when you have managed just to get some 'not quite' coplanar faces and try to remove some 'not quite' coplanar edges...
                If it knacks up then all you can do is to undo it one step back to keep coplanar edges - try other coplanar fixing tools and report back... OR just learn to love them... otherwise try to make forms that don't mess with SUp's head πŸ˜’
                  There is a minor correction to this tool so the 'db' translation for the 'start_operation' is now done correctly - there is also an updated ES lingvo file - thanks to deFisto...
                    No file attached πŸ˜•
                    It's relatively simple to select all and smooth/unsmooth.
                    Use Hidden Geometry ON to see what's happening
                    It's also relatively simple to do it to a selection.
                    You can also use a selection of edges and Entity Info to uncheck smooth/soft [and hidden] settings for edges.
                    The tool produces smoothed-edges if desired.
                    I'm not sure what you are trying to do that it doesn't do OR what isn't easy to do by hand later ???
                    • pbacotP Offline
                      The file is attached. I see it there. I reloaded and perhaps you viewed in the moment that I did that.
                      The edges I need to smooth are many and selection would need to be almost one by one, to not get the wrong edges. If this is best way, so be it. If I create many versions of this model, I want to be more efficient if I can.
                      Also I should say, look at both scenes.
                      Thanks, Peter
                      • pbacotP Offline
                        Hi TIG,
                        This is another great one, including the control it gives on the angle etc. However I have a project in which I want smooth edges for the curved faces but not along the flat faces that result. So I wonder if this is the wrong tool and you have other suggestions. I have attached a file if you are interested.
                        Given the work to create this otherwise (create full circle and cut with intersections), it may not be too much to smooth all the edges "manually". This is only a prototype for a coming project which will probably be drawn many times in design, so I am seeking the best method. Just seeing if I am using the right tool or using it correctly.
                        Thank you for the plugin and, of course, anyone can chime in.
                        Peter
                        AMPHITHEATER 3.skp
                        • jeff hammondJ Offline
                          i always have problems with the smooth option as well (as in, it smooths everything)
                          choose no for smooth then select the group and smooth is via the soften/smooth dialog
                          • pbacotP Offline
                            Yes, Jeff the smooth option smooths every edge--too much here.
                            I got it, I think! Using this tool and ThomThom's Selection Toys to quickly select those edges I need to smooth.
                              OK, now I see the issue.
                              You want yes to smooth? not to smooth every edge - for example leave those with only one face or two faces at right-angles of sharper ?
                                Updated v3.4 so it now only smooths edges with more than one face.
                                • pbacotP Offline
                                  I guess in this case I would not smooth edges that are adjoining a face perpendicular to axis of rotation. I wonder if that is a definable parameter or is that a common desired outcome.
                                    It now works exactly the same as the built-in Smooth tool, which ignores perimeter edges in the smoothing. Should you subsequently add faces to these edges the will remain unsmoothed, but a quick use of the built-in smooth tool will merge them if desired. This is surely better than having them auto-smooth as the face is added because then it's harder to unsmooth those edges you want to stay unsmoothed than it is to smooth the edges you don't smooth later on !?
                                    • pbacotP Offline
                                      Actually I now find that in this application, I can smooth with this ruby and then twiddle the soften smooth edges dialog for the desired effect. I can now really crank these out--if only the project goes forward... πŸ˜•
                                      Thanks a bunch TIG!
                                        Here's an update to EEbyLathe http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
                                        Use the link to get the zipped set which contains the updated file.
                                        20111102 v3.5
                                        Fixed Picked-Angle's messy undo.
                                        Smoothed-edges now stop @90ΒΊ.
                                        • pbacotP Offline
                                          Thanks TIG. That's even more perfect. Now you're doing all my work for me and SU is not so fun anymore. 😒
                                          Just kiddin. Really, it seems custom made for what I was trying to do. β˜€
                                            jamesyzs
                                            Hi Tig
                                            Where is a download link for extrudeEdgesByLathe.rb
                                            I can't seem to find it. Thanks
                                            -James
                                            • 5 / 6
