    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.4k Views 116 Watching
    • charly2008C Offline
      charly2008
      Hi Thomas,
      I thank you for your efforts. I'm sometimes a bit hasty with my questions. In the future I will take a closer look before I ask a question.
      Charly
        charly2008
        Hi Thomas,
        Once it has worked with the hull I need help again. I do not succeed, to bring the texture on these relatively simple geometry. As far as I can judge it must be all quad faces in the model. Yesterday I spent two hours trying to find the error in the geometry, without success. Thanks in advance.
        Charly
        wiking3.skp
        • jo-keJ Offline
          jo-ke
          Thank you ThomThom for this wonderful plugin. It helps me a lot with my curtains...
          http://www.zz7.de
            @charly2008 said:
            Hi Thomas,
            Charly
            Are you using the Copy and Paste function? Or the UV map function?
            • mitcorbM Offline
              mitcorb
              Wow!
              Eleven pages and counting. Good work ThomThom
                charly2008
                Hi Thomas,
                I've just tried it again and it worked. I do not know what mistake I made.
                  charly2008
                  Not yet perfect but a step in the right direction with the help of the Quad Face tool from Thomas.
                    Really glad to see some if the stuff this plugin is being used for. 😄
                      shumas
                      Problem! when i copy all files to sketchup 8 plugin directory, and open sketchup, I get this error.. I'm doing something wrong?
                        In the first post, there is a reference to another plugin (library) that you also need to install for this one to work. Please, make sure TT_Lib (linked from the first post) is also installed.
                        • N Offline
                          numerobis
                          😮 AAAHHHHHHH!!!
                          just watched your last three videos... the new functions look fantastic!!! unbelievable to see this as a ruby in sketchup!!!
                          thank you very much!
                          i'll try it... 😄
                          • 3 Offline
                            3dbybrunolopes
                            Nice set of tools,
                            Bit I can´t change the number of segments for the connect edges tool :S
                            Can you help me?
                              Type in the number of segments, the VCB will update as you type. Then hit Enter to apply. The on screen UI doesn't update as you type. it's just there so you can choose to adjust either number of segments or pinch.
                              • 3 Offline
                                3dbybrunolopes
                                Thanks 😄
                                  A while ago we debated how best to deal with the odd triangular facets needed to complete a manifold surface that is otherwise 'quads'.
                                  Lying in bed this morning I realized that the Art-Deco inverted hemisphere leaded-glass lampshade above my head was made entirely out of quads 😲
                                  Here's how [applied to an entire sphere]...quadsphere.PNGThere are two solutions, depending on the quads' hidden/soft/smooth edges - the right-hand one with lines of latitude hidden/soft/smooth is the 'most even' type...
                                  This is of course with lines of latitude equally spaced which distorts the quads nearer the 'poles' - if they are adjusted the quads get nearer to 'squares'... The 'flower' at the poles can never approximate a square no matter how small you make it as the angle if subtends at the pole is fixed by the number of segments the lines of latitude have - the more segments the less square the 'petals'...quadsphere.skp
                                    Bug Alert
                                    I just discovered an issue where the Hidden property of triangulated quads might get lost when you copy / import a quad face mesh into a model with existing scenes. In some cases the mesh can be recovered by using the Sandbox To Quads and then updating the scenes - but there is a potential for losing the Quad definition of the mesh.
                                    Issue logged at: https://bitbucket.org/thomthom/quadface-tools/issue/57/hidden-property-is-lost-when-activating
                                    Will find a solution to this. Might end up reverting back to the old way of defining Quads. Sorry for the inconvenience this might cause.
                                    • jarynzlesaJ Offline
                                      jarynzlesa
                                      this plug-in deserves three thumbs up.
                                      http://www.vizualizaceschodiste.mypage.cz/
                                        Luigi987
                                        Amazing plugin!
                                        Though, on various occasions it does this:
                                        http://puu.sh/8aAc
                                        the corners always get messed up no matter how perfectly I make them.
                                        Not sure if this is a bug or just me being dumb, help appreciated though~
                                          I'm suspecting it's the shape of the quads in the corners that makes the UV mapping distort in such a manner. I'm guessing it's native quads - so I'd try to triangulate them (using the Triangulate method in QuadFace Tools.)
                                          Can you share a sample model?
                                            Luigi987
                                            Tried triangulating with said option, no luck.
                                            Here's the model part.
                                            example.skp
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
