    [Plugin] QuadFaceTools
    680 Posts 116 Posters 771.9k Views 116 Watching
    • charly2008C
      charly2008
      Hi Thomas,
      I did it with the UV Copy & Paste tools.
      • charly2008C
        charly2008
        I found the error. As Gaieus said, in the enlargement can be seen some additional faces. This I have now adjusted.
        • charly2008C
          charly2008
          Hi Thomas,
          I'm still have a few problems with copy and paste UVs. It is probably a mistake from me again. Would you again take a look at it.
          Charly
          STEP 1
          STEP 2
          STEP 3
          wiking.skp
            It's still some non-quads over at that end.
            • charly2008C
              charly2008
              Hi Thomas,
              I thank you for your efforts. I'm sometimes a bit hasty with my questions. In the future I will take a closer look before I ask a question.
              Charly
              • charly2008C
                charly2008
                Hi Thomas,
                Once it has worked with the hull I need help again. I do not succeed, to bring the texture on these relatively simple geometry. As far as I can judge it must be all quad faces in the model. Yesterday I spent two hours trying to find the error in the geometry, without success. Thanks in advance.
                Charly
                wiking3.skp
                • jo-keJ
                  jo-ke
                  Thank you ThomThom for this wonderful plugin. It helps me a lot with my curtains...
                  http://www.zz7.de
                    @charly2008 said:
                    Hi Thomas,
                    Charly
                    Are you using the Copy and Paste function? Or the UV map function?
                    • mitcorbM
                      mitcorb
                      Wow!
                      Eleven pages and counting. Good work ThomThom
                      • charly2008C
                        charly2008
                        Hi Thomas,
                        I've just tried it again and it worked. I do not know what mistake I made.
                        • charly2008C
                          charly2008
                          Not yet perfect but a step in the right direction with the help of the Quad Face tool from Thomas.
                            Really glad to see some if the stuff this plugin is being used for. 😄
                              shumas
                              Problem! when i copy all files to sketchup 8 plugin directory, and open sketchup, I get this error.. I'm doing something wrong?
                              • GaieusG
                                In the first post, there is a reference to another plugin (library) that you also need to install for this one to work. Please, make sure TT_Lib (linked from the first post) is also installed.
                                • N
                                  numerobis
                                  😮 AAAHHHHHHH!!!
                                  just watched your last three videos... the new functions look fantastic!!! unbelievable to see this as a ruby in sketchup!!!
                                  thank you very much!
                                  i'll try it... 😄
                                    3dbybrunolopes
                                    Nice set of tools,
                                    Bit I can´t change the number of segments for the connect edges tool :S
                                    Can you help me?
                                      Type in the number of segments, the VCB will update as you type. Then hit Enter to apply. The on screen UI doesn't update as you type. it's just there so you can choose to adjust either number of segments or pinch.
                                        3dbybrunolopes
                                        Thanks 😄
                                          A while ago we debated how best to deal with the odd triangular facets needed to complete a manifold surface that is otherwise 'quads'.
                                          Lying in bed this morning I realized that the Art-Deco inverted hemisphere leaded-glass lampshade above my head was made entirely out of quads 😲
                                          Here's how [applied to an entire sphere]...quadsphere.PNGThere are two solutions, depending on the quads' hidden/soft/smooth edges - the right-hand one with lines of latitude hidden/soft/smooth is the 'most even' type...
                                          This is of course with lines of latitude equally spaced which distorts the quads nearer the 'poles' - if they are adjusted the quads get nearer to 'squares'... The 'flower' at the poles can never approximate a square no matter how small you make it as the angle if subtends at the pole is fixed by the number of segments the lines of latitude have - the more segments the less square the 'petals'...quadsphere.skp
                                            Bug Alert
                                            I just discovered an issue where the Hidden property of triangulated quads might get lost when you copy / import a quad face mesh into a model with existing scenes. In some cases the mesh can be recovered by using the Sandbox To Quads and then updating the scenes - but there is a potential for losing the Quad definition of the mesh.
                                            Issue logged at: https://bitbucket.org/thomthom/quadface-tools/issue/57/hidden-property-is-lost-when-activating
                                            Will find a solution to this. Might end up reverting back to the old way of defining Quads. Sorry for the inconvenience this might cause.
                                            • 11
                                            • 33
                                            • 34
                                            • 9 / 34
