    [Plugin] QuadFaceTools
    673 Posts 116 Posters 543.8k Views 116 Watching
      huh! ... peculiar... I'll look into it.
      Nice boat! 😄
        @charly2008 said:
        I made another attempt with my Viking ship hull. This tool is really amazing. A small error I could not resolve.
        How did you map it? With the UV Mapping tool, or with the UV Copy & Paste tools?
          I found the cause - you got some messed up geometry there.
          Look at this screenshot:
          Here I made a left to right selection over the selected quad. Notice the Entity Info correctly displaying 7 entities. ( 2 triangles, 5 edges )
          Now look at this one - where I made the same selection around the troublesome area:
          Notice there is 20 (!) entities. Something is messed up in your geometry there.
            Zoom in to the top left corner of that white and see a whole lot of extra edges and faces
              Version 0.5.0
              Changelog: https://bitbucket.org/thomthom/quadface-tools/issues?status=resolved&version=0.5.0
              Download: https://bitbucket.org/thomthom/quadface-tools/wiki/Download
              • charly2008C Offline
                charly2008
                Hi Thomas,
                I did it with the UV Copy & Paste tools.
                  charly2008
                  I found the error. As Gaieus said, in the enlargement can be seen some additional faces. This I have now adjusted.
                    charly2008
                    Hi Thomas,
                    I'm still have a few problems with copy and paste UVs. It is probably a mistake from me again. Would you again take a look at it.
                    Charly
                    STEP 1
                    STEP 2
                    STEP 3
                    wiking.skp
                      It's still some non-quads over at that end.
                        charly2008
                        Hi Thomas,
                        I thank you for your efforts. I'm sometimes a bit hasty with my questions. In the future I will take a closer look before I ask a question.
                        Charly
                          charly2008
                          Hi Thomas,
                          Once it has worked with the hull I need help again. I do not succeed, to bring the texture on these relatively simple geometry. As far as I can judge it must be all quad faces in the model. Yesterday I spent two hours trying to find the error in the geometry, without success. Thanks in advance.
                          Charly
                          wiking3.skp
                          • jo-keJ Offline
                            jo-ke
                            Thank you ThomThom for this wonderful plugin. It helps me a lot with my curtains...
                            http://www.zz7.de
                              @charly2008 said:
                              Hi Thomas,
                              Charly
                              Are you using the Copy and Paste function? Or the UV map function?
                              • mitcorbM Offline
                                mitcorb
                                Wow!
                                Eleven pages and counting. Good work ThomThom
                                  charly2008
                                  Hi Thomas,
                                  I've just tried it again and it worked. I do not know what mistake I made.
                                    charly2008
                                    Not yet perfect but a step in the right direction with the help of the Quad Face tool from Thomas.
                                      Really glad to see some if the stuff this plugin is being used for. 😄
                                        shumas
                                        Problem! when i copy all files to sketchup 8 plugin directory, and open sketchup, I get this error.. I'm doing something wrong?
                                          In the first post, there is a reference to another plugin (library) that you also need to install for this one to work. Please, make sure TT_Lib (linked from the first post) is also installed.
                                          • N Offline
                                            numerobis
                                            😮 AAAHHHHHHH!!!
                                            just watched your last three videos... the new functions look fantastic!!! unbelievable to see this as a ruby in sketchup!!!
                                            thank you very much!
                                            i'll try it... 😄
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 33
                                            • 34
                                            • 20 / 34
