    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.7k Views 116 Watching
    • charly2008C Offline
      charly2008
      I made another attempt with my Viking ship hull. This tool is really amazing. A small error I could not resolve.
      wiking.skp
        huh! ... peculiar... I'll look into it.
        Nice boat! 😄
          How did you map it? With the UV Mapping tool, or with the UV Copy & Paste tools?
            I found the cause - you got some messed up geometry there.
            Look at this screenshot:
            Here I made a left to right selection over the selected quad. Notice the Entity Info correctly displaying 7 entities. ( 2 triangles, 5 edges )
            Now look at this one - where I made the same selection around the troublesome area:
            Notice there is 20 (!) entities. Something is messed up in your geometry there.
              Zoom in to the top left corner of that white and see a whole lot of extra edges and faces
                Version 0.5.0
                Changelog: https://bitbucket.org/thomthom/quadface-tools/issues?status=resolved&version=0.5.0
                Download: https://bitbucket.org/thomthom/quadface-tools/wiki/Download
                  charly2008
                  Hi Thomas,
                  I did it with the UV Copy & Paste tools.
                    charly2008
                    I found the error. As Gaieus said, in the enlargement can be seen some additional faces. This I have now adjusted.
                      charly2008
                      Hi Thomas,
                      I'm still have a few problems with copy and paste UVs. It is probably a mistake from me again. Would you again take a look at it.
                      Charly
                      STEP 1
                      STEP 2
                      STEP 3
                      wiking.skp
                        It's still some non-quads over at that end.
                          charly2008
                          Hi Thomas,
                          I thank you for your efforts. I'm sometimes a bit hasty with my questions. In the future I will take a closer look before I ask a question.
                          Charly
                            charly2008
                            Hi Thomas,
                            Once it has worked with the hull I need help again. I do not succeed, to bring the texture on these relatively simple geometry. As far as I can judge it must be all quad faces in the model. Yesterday I spent two hours trying to find the error in the geometry, without success. Thanks in advance.
                            Charly
                            wiking3.skp
                            • jo-keJ Offline
                              jo-ke
                              Thank you ThomThom for this wonderful plugin. It helps me a lot with my curtains...
                              http://www.zz7.de
                                @charly2008 said:
                                Hi Thomas,
                                Charly
                                Are you using the Copy and Paste function? Or the UV map function?
                                • mitcorbM Offline
                                  mitcorb
                                  Wow!
                                  Eleven pages and counting. Good work ThomThom
                                    charly2008
                                    Hi Thomas,
                                    I've just tried it again and it worked. I do not know what mistake I made.
                                      charly2008
                                      Not yet perfect but a step in the right direction with the help of the Quad Face tool from Thomas.
                                        Really glad to see some if the stuff this plugin is being used for. 😄
                                          shumas
                                          Problem! when i copy all files to sketchup 8 plugin directory, and open sketchup, I get this error.. I'm doing something wrong?
                                            In the first post, there is a reference to another plugin (library) that you also need to install for this one to work. Please, make sure TT_Lib (linked from the first post) is also installed.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 33
                                            • 34
                                            • 22 / 34
