    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.4k Views 116 Watching
      EDIT: this is with v0.4. I did not upgrade yet
      How about 0.4.1?
      (I'm prepping up 0.5 which included quite a few validations and error catching. Should be more informative when things doesn't work.)
      Thanks. Once I have the texture on the shape, what should I do next?
      Then you can click the axis (red and green line) to scale it. Or use the VCB.
        jorge2011
        thom excellent, now works fine.
        thank you very much for your fast response
        • charly2008C Offline
          charly2008
          I made another attempt with my Viking ship hull. This tool is really amazing. A small error I could not resolve.
          wiking.skp
            huh! ... peculiar... I'll look into it.
            Nice boat! 😄
              How did you map it? With the UV Mapping tool, or with the UV Copy & Paste tools?
                I found the cause - you got some messed up geometry there.
                Look at this screenshot:
                Here I made a left to right selection over the selected quad. Notice the Entity Info correctly displaying 7 entities. ( 2 triangles, 5 edges )
                Now look at this one - where I made the same selection around the troublesome area:
                Notice there is 20 (!) entities. Something is messed up in your geometry there.
                  Zoom in to the top left corner of that white and see a whole lot of extra edges and faces
                    Version 0.5.0
                    Changelog: https://bitbucket.org/thomthom/quadface-tools/issues?status=resolved&version=0.5.0
                    Download: https://bitbucket.org/thomthom/quadface-tools/wiki/Download
                      charly2008
                      Hi Thomas,
                      I did it with the UV Copy & Paste tools.
                        charly2008
                        I found the error. As Gaieus said, in the enlargement can be seen some additional faces. This I have now adjusted.
                          charly2008
                          Hi Thomas,
                          I'm still have a few problems with copy and paste UVs. It is probably a mistake from me again. Would you again take a look at it.
                          Charly
                          STEP 1
                          STEP 2
                          STEP 3
                          wiking.skp
                            It's still some non-quads over at that end.
                              charly2008
                              Hi Thomas,
                              I thank you for your efforts. I'm sometimes a bit hasty with my questions. In the future I will take a closer look before I ask a question.
                              Charly
                                charly2008
                                Hi Thomas,
                                Once it has worked with the hull I need help again. I do not succeed, to bring the texture on these relatively simple geometry. As far as I can judge it must be all quad faces in the model. Yesterday I spent two hours trying to find the error in the geometry, without success. Thanks in advance.
                                Charly
                                wiking3.skp
                                • jo-keJ Offline
                                  jo-ke
                                  Thank you ThomThom for this wonderful plugin. It helps me a lot with my curtains...
                                  http://www.zz7.de
                                    @charly2008 said:
                                    Hi Thomas,
                                    Charly
                                    Are you using the Copy and Paste function? Or the UV map function?
                                    • mitcorbM Offline
                                      mitcorb
                                      Wow!
                                      Eleven pages and counting. Good work ThomThom
                                        charly2008
                                        Hi Thomas,
                                        I've just tried it again and it worked. I do not know what mistake I made.
                                          charly2008
                                          Not yet perfect but a step in the right direction with the help of the Quad Face tool from Thomas.
                                            Really glad to see some if the stuff this plugin is being used for. 😄
                                            • 11
                                            • 33
                                            • 34
                                            • 9 / 34
