    Graded curves
    14 Posts 6 Posters 790 Views 6 Watching
      jukanight
      I dont know if I am going about this the complete wrong way, but what is the best way to set up the spiral before I use the follow me and keep me tool? If I simply select the lines and rotate them, sketchup automatically breaks a curve up into a million lines, and the spiral shape doesnt flow right. I know there is an easier way of setting up a spiral shape, I just dont know what the best way to go about it is!
      thanks for your help!
      • GaieusG
        What are you using to draw your spirals? There are various "helix" plugins like this one for instance:
        http://sketchuptips.blogspot.com/ or an extremely complex one: http://www.drawmetal.com/curvemaker
        • mitcorbM
          mitcorb
          Do you need to "Weld.rb" that path? And that would be a single linear path, not multiple rails. My assumptions based on your comment and image.
            jukanight
            I just use the curves imported as a DWG, but I presume now that would be the wrong thing to do. Curve maker looks good, and from there I can specify the angle of my my curve structure, as I have a continous curved ramp that loops throughout the building. Ive always avoided curves in sketchup, but now the building I have designed for my thesis has curves, and ramped curves at that! not a good time to start learning..
            • GaieusG
              It's always a good time to start learning. 😄
              • gillesG
                gilles
                Here is a little tut.
                fak.skp
                • W
                  wyatt
                  You could also try using CurviShear http://forums.sketchucation.com/viewtopic.php?t=29230
                    jukanight
                    thanks! that really helps! its grand to get a step by step.
                    Might be a silly question, but how do you 'weld' lines in sketchup?
                    • GaieusG
                      @jukanight said:
                      ...Might be a silly question, but how do you 'weld' lines in sketchup?
                      File Not Found
                      (www.smustard.com)
                      • mitcorbM
                        mitcorb
                        Now, if that were a highway ramp, you'd need to set the inner radius curb a bit lower than the outer radius curb for the duration of the turn. Just an observation that does not have anything to do directly with the problem at hand.
