    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 30.8k Views 23 Watching
      mountain cowboy
      @solo said:
      Do you have the new exporter?
      Page not found - Thea Render
      Thea Render (www.thearender.com)
      Yes, I expect so. I assume what you are speaking of is an exporter related to Thea. It comes with the SUplugin doesn't it? I downloaded Thea v1.1 and the SUplugin yesterday. I had nothing before that. If your speaking of an SU exporter, I should be up to date on that as well. I loaded a new copy of Pro 8 about 2 weeks ago.
        mountain cowboy
        I think I am missing something. True if I do as you say, SketchUp remains open and operating correctly. Also the new material is set in the exporter. However, it is not on my drawing. How do I get it there?
        If you close the material editor normal service will resume. This happens on my system too.
        So apply material in SU
        click exporter
        Double click material
        Assign Thea material
        Close material editor
          Texturing in SU and Thea are separately handled but Thea is influenced my mapping in SU. You won't see textures from Thea appearing in SU after applying them in the Editor. Textures in SU are placeholders for textures in Thea
            mountain cowboy
            OK Rich, I think I'v got it. When I modify the material in Thea it is not shown in sketchup but it will be visable when I import it into Thea for additional work or final render. Right? That will minimize the problem. Only negative is I won't see the model in SU as it will finaly look.
            Thanks for your help. Now if we can just eliminate the initial problem, we will have all of what we want.
              mountain cowboy
              Solo, after your last comment, I found that SU the new "SketchUp Web Exporter (Beta)". I have installed it, however it does not have any noticeable effect on the materials problem. I think Rich O'Brian has it right in his answers below.
              Thank you both for taking the time to address the problem for me.
              • soloS Offline
                The thing is I do not set my textures up in the Thea exporter, I export my SU scene and do all my materials in Thea studio.
                  Douglas, have a look at this topic in the Thea forums. It explains it quite straightforward IMO.
                  http://www.thearender.com/forum/viewtopic.php?f=91&t=6290
                  • N Offline
                    notareal
                    Little heads up, Thea Render v1.1.03 Revision 576 (6 October 11) is available at
                    http://www.thearender.com/cms/index.php/downloads/thea-render.html
                    (Quick Installation guide and Changes Log)
                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                      I'm loving the last 2 revisions. Feature rich and fast. Any info on the future roadmap?
                      • N Offline
                        notareal
                        There is no update for the road map at the moment. But like earlier stated, material db and GPU rendering are on the way. Those will be done during 1.x version... probably sooner than later - no exact dates. AutoCAD Exporter Plugin is on the way.
                        • N Offline
                          notareal
                          Thea Render Technology Preview - Adaptive AMC
                          The introduction of a new powerful method (called Adaptive AMC) into IR. This method, that could be thought as the biased analog of TR2, has the ability to resolve difficult lighting conditions, SSS and medium scattering and still give interactive feedback.
                          We have recorded here a video showing all these improvements. The architectural scene used as our test case is courtesy of Davis Carter Scott, Inc. (kindly offered for our internal testing). Naturally there are some workflow improvements with the next release, maybe one can spot those too πŸ˜„
                          [flash=854,480:ovbowqdv]http://www.youtube.com/v/Q7DldMuwbIM[/flash:ovbowqdv]
                          • irwanwrI Offline
                            irwanwr
                            hi there notareal,
                            since you are also within Kerkythea (i assume), do you mind if i ask you about the next Kerkythea? i haven't heard much about the next Boost after the Echo release.
                            thank you.
                            • N Offline
                              notareal
                              @irwanwr, Like you probably already do know, the early development version is available at the Kerkythea forum. There is no release date yet.
                              • irwanwrI Offline
                                irwanwr
                                thank you, notareal.
                                  sonder
                                  I've been using Kerkythea for years now. This looks amazing. I went online to purchase - it looks like you bill the purchaser? Any infor for us US purchasers would be great. I'm in!
                                  • N Offline
                                    notareal
                                    @Sonder, Not sure what info you need? Prices listed are net as euro, VAT does not apply to US customers (further instructions). If some alternative payment method is needed, please use contact form.
                                    You most welcome to join at Thea Forums (preferably use the same email as with the purchase. If not, please use the contact form to get a proper status).
                                      sonder
                                      Thanks - my comment was due to the cart and checkout process. I saw no place to give a payment method. I'll go back and look again. I will join the forum as well.
                                      • N Offline
                                        notareal
                                        Happy New Year! First Thea Render update for 2012. New interactive render engine;Adaptive AMC, bugfixes and some important workflow improvements. Available at the development forum for licensed users.
                                        Dear friends,
                                        besides our best wishes for a happy new year 2012, we bring you a maintenance update for Thea Render, the 4th update in the 1.1 series.
                                        This update contains the latest improvements related to interactive render, as announced in our related tech preview post. Fine tuning of the refreshing, faster operations during IR and a new engine (Adaptive AMC) solving caustics and SSS make interactive rendering much smoother and more fun to play with.
                                        Apart from the interactive rendering, there are some very important noise bug fixes for TR1/TR2; they are related to bump mapping on glossy materials, but also some weird noise - very hard to resolve - appearing on strange lighting conditions.
                                        With respect to the user interface, if you have any bitmaps missing from a scene, there is no need to worry now; Thea will now remember them, tag them and show them to you to browse. And finally, there is a new format "lib.thea" that is going to be used for library installation (a new library will be available soon making use of this functionality).
                                        As always, you can find the detailed changes log and download links, in our usual thread:
                                        http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
                                        best wishes
                                        • N Offline
                                          notareal
                                          Dear friends,
                                          as you may know, we are working currently on tighter integration of Thea with modeling applications, but - of course -
                                          we couldn't leave the studio without any updates. Brief summary of Thea Render Revision 627.
                                          You can find the detailed changes log and download links, in our usual thread. (Download available for licensed users. Non licensed users can grab the latest tested revision from our website page.)
                                          • N Offline
                                            notareal
                                            Brief introduction to new animation features inside Thea; complex motions.
                                            [flash=800,480:1v3xuo95]http://www.youtube.com/v/ZhQkVLqVkdk?hd=1[/flash:1v3xuo95]
                                            Note: Thea does not try to compete with modeling applications that have a rich user interface and algorithms for setting up animation and motion. The important thing for us is the support of such complex motion and a rather minimalistic user interface that uses it.
                                            • 3 / 8
