    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.6k Views 116 Watching
      Right, so a tool that let you move the vertices of the unwrapped grid - and simultaneously updates the source mesh.
      It's an interesting idea.
      Ideally I'd wish that the unwrapped mesh resembled more the original mesh, in terms of shape - but it's not a task I'm able to take on right now.
      (Though if anyone else got any ideas. then join in on BitBucket! πŸ˜‰ )
        jorge2011
        @thomthom said:
        @jorge2011 said:
        for example, how to apply texture to that?
        Select the material you want to use from the Material Browser. Then pick the U and V axis.
        I noticed that in the model you posted, no material was selected - I'm guessing this was your issue?
        ok
        the latest version works best.
        but very simple example.
        How do I apply texture to a cylinder?
        Material applies only to a portion of the cylinder.
        and on the other surface not apply.
        What am I doing wrong?
        05.skp
          Like any other mesh, pick a U and V axis.
          Did you have part of the cylinder selected? I had no problems mapping it.
          Maybe some screenshots of what you are doing? Or a video?
          It is not a Quad mesh. All the edges on that surface is soft + smooth.
          • PixeroP Offline
            Pixero
            Maybe a tool that for "onMouseMove" updates UVs while moving vertices?
            Or "onLButtonUp" for semi live update?
              jorge2011
              is odd, thom. When I apply a material to the cylinder not working properly.
              the problem is with the "continuous mapping"
              Am I doing something wrong?
                That is odd. I can't reproduce that at all. Can you post that sample model you used in that video? So I can see what might be the difference between it and my test model.
                  I see in the video that the origin of the V axis (indicated by the green X) isn't where it should be. Though I do not understand why. I can't make that happen on my test models...
                    jorge2011
                    this is the model
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&start=120#p359462
                      jorge2011
                      can you explain a little more?
                      • dereiD Offline
                        derei
                        Hello thomthom, do you have any answer related to the error I mentioned here http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&start=75#p358895 ? Now it happens every time I start SU. I don't know why at first happened only on second instance.
                        • gillesG Offline
                          gilles
                          I get similar result than Jorge with a simple cylinder.
                            You still get that? I thought I'd fixed it in 0.4.1 ...
                            Can you do a load 'tt_quadface.rb' again and report back the error message?
                            You're using SU8, right? (Updated Maintenance release 1?)
                            And TT_Lib2 version ... ?
                              I cannot reproduce this at all. Here's what happen when I try to map the cylinder with continuous mapping: http://www.youtube.com/watch?v=aAWK4TcGn2E
                              I tried all modes, and with the faces selected and nothing selected...
                              Can you post a screenshot or video?
                              • gillesG Offline
                                gilles
                                I got this.
                                  And both of you got QuadFace Tools 0.4.1, and TT_Lib 2.5.8? Using SketchUp 8? (Maintenance release 1?) You got admin rights? 100% sure the plugin has been updated? (Under Vista and Win7 there a Compatibility Files feature that puts files in a ghost folder - it has caused issues from time to time when...)
                                  • gillesG Offline
                                    gilles
                                    SU 8.0.3161
                                    have to update?
                                    • dereiD Offline
                                      derei
                                      I wasn't aware that you released a fixed version. I don't know how to check the version (it doesn't appear in toolbar's name, or anywhere else). So I reinstalled the plugin, with one I downloaded now and it works just fine.
                                      Thank you very much.
                                        @gilles said:
                                        SU 8.0.3161
                                        have to update?
                                        I'd recommend that you do. Always keep your software up to date.
                                        However, for the mapping problems you have been experiencing. I think I might have found it. It's due to a bug in TT_Lib2.5 which I have fixed in the unreleased TT_Lib2.6. (I'd forgotten I'd fixed this bug which affected QuadFace Tools.)
                                        Keep an eye out for an update to TT_Lib2.
                                          When you go to Window > Preferences > Extensions you can find the version from there.
                                          I'll add an About menu to the next version.
                                          Btw, QuadFace tools now supports Fredo's update checker.
                                          • dereiD Offline
                                            derei
                                            If you want to add it only for version, you can add version in toolbar name.
                                            • 11
                                            • 33
                                            • 34
                                            • 9 / 34
