    [Plugin] QuadFaceTools
    680 Posts 116 Posters 594.7k Views 116 Watching
      Tom,
      Here is the model where I have problem (I get the UV axes, but the texture does not appear).
      [attachment=0:33lgahxv]<!-- ia0 -->Quad-mapping Fred.png<!-- ia0 -->[/attachment:33lgahxv]
      Might be related to the nil errors people are reporting...
        Version 0.4.1
        Added a hotpatch to address the loading errors. Might resolve a couple of irregular behaviours as well.
          jorge2011
          for example, how to apply texture to that?
          01.skp
            @cmeed said:
            great to see a video and what amazing work you put into this forum. really well done.
            I'm trying this out for the first time and am having some trouble, the problem is that i can put a texture in but then cant change it to a new one
            Its basically only works once and you can't map anything else to that shape. or i've missed something. - I'm on a mac
            (suggestion - is there a roll over help pop up that can be used that when you leave the curser ove an icon a pop up help describes the function?)
            Try with version 0.4.1 - maybe your issues was related to the nil errors...
              When using "Unwrap Picked Grid" it'd be nice if it used inferencing.
              Had a look at my code again - it does already use inferencing... But I'm changing it so you see the inference icons.
                Select the material you want to use from the Material Browser. Then pick the U and V axis.
                I noticed that in the model you posted, no material was selected - I'm guessing this was your issue?
                • charly2008C Offline
                  charly2008
                  Thank You Thomas,
                  In any case, this is a fantastic tool I've ever wanted for a long time, especially for the planking of ship hulls. But I have a small problem which I have not yet overcome.
                  Charly
                  Untitled.skp
                    @charly2008 said:
                    Thank You Thomas,
                    Charly
                    How/where do you pick the U and V axis?
                      Looking at it, where you see the seam, that's where you set your axis, right? Your texture isn't seamless, so it's the two ends of the texture that meets at the axis.
                      • Rich O BrienR Online
                        Here's a big big ask...
                        The 'Show Grid' is a great option is it possible that this grid represents 'Compressing'[Red], 'Stretching'[Blue] and Normal[Green] of the UVs?
                          charly2008
                          Thomas,
                          thanks for your advice. The texture was not seamless. Now, the planking is almost perfect.
                          Rendered Model
                            Cool hull! 😉
                              "Compressing" - as in distorted texture, no parallel lines in the UV mapping? "Stretching" - would that include skewed textures?
                                Compressing as in the UV has been scaled down in the UV space so that it doesn't appear 'normal'
                                Stretching as in the UV has been scaled up in the UV space so that it doesn't appear 'normal'
                                So, distortion/skewing is including in these suggestions above.
                                What would be incredible is that once unwrapped and the colors show problem areas you could then adjust verts to alleviate this distortion.
                                  Can you elaborate on this one? Maybe some screens or illustrations.
                                  • PixeroP Offline
                                    Pixero
                                    What would be great is if the original and the unwrapped faces were "linked" so when manipulating vertices on the flat object you could directly see its effect on the original object.
                                      How would this manipulation affect the original mesh?
                                      • PixeroP Offline
                                        Pixero
                                        Not the mesh. The UVs. Kind of like when you edit texture in a component and all the rest gets updated in real time.
                                        WYSIWYG
                                          WYSIWYG
                                          Interesting. However, I don't think I can hook into the native mapper.
                                          Did you mean that if you remapped the unwrapped grid with the UV Map tool it'd update?
                                          How about a context menu item "Update" which would update the source?
                                          • PixeroP Offline
                                            Pixero
                                            For example. If you have a object that have the UVs stretched from the default mapping with your tool.
                                            If you then edited the position of the vertices on the unwrapped object you should see how that effects the original objects mapping. Preferably in real time.
                                            • 33
                                            • 34
                                            • 6 / 34
