    Cant see crosshairs
    4 Posts 2 Posters 291 Views 2 Watching
      dammerel
      hi all
      im using su8 free
      when i use the mouse to select using a window or crossing i cant see the crosshairs
      the edges/faces are selected ok. any clues why?
      thanks andrew
        Could be a possible graphics-card issue.
        Have you got the latest driver for your graphics-card ?
        Do its settings allow an app like SUp to optimize the settings?
        Also try Window > Preferences > OpenGL
        adjust the setting of the various options and see if any of the combinations help with your display issue...
        Report back...
          dammerel
          Tig
          i turned off hardware acceleration and i seems to work now
          thanks for the suggestion
          andrew
            It will run noticeably slower that way, so I suggest you also check drivers etc - updating etc might mean it can work faster again...
