    Ruby scripts not loading
    15 Posts 4 Posters 1.3k Views 4 Watching
      Did you try turning on the toolbar for Round Corners?
      We could help you better if you give more information.
      • I
        ibej57
        haven't seen a toolbar for roundcorners or matchbox. give me a place to look.
          View>Toolbars
          And did you tick the box for Round Corner in Preferences>Extensions?
          • I
            ibej57
            @dave r said:
            View>Toolbars
            yeah, it's not there dave. i was able to get fredo lib 3.7 to load, but nothing else. i may have a path issue ! thanks
              Sounds like you have an installation error.
              How about posting a screen shot of the Plugins directory?
              • I
                ibej57
                \JOHN-HP\Users\john\AppData\Local\VirtualStore\Program Files (x86)\Google\Google SketchUp 8\Plugins, this is the download location. i've copied to - this folder _ C:\Program Files (x86)\Google\Google SketchUp 8\Plugins, but it still doesn't load ! i'm confused about the different locations ! i can't get the file to download to the more direct path. thanks for your help. i've also reinstalled su.
                  Looks like your system is protecting you from yourself!
                  Are you an Admin?
                  If not then become one!
                  Some folder structures are protected by Window's security settings to prevent unexpected executable files getting put into them.
                  Your Plugins folder needs to have its permissions set to allow you 'all rights'...
                  If you don't have the right permissions then Vista [and I suspect its new sibling Win7] seem to let you think that the files have been put where you expected [i.e. ALL scripts and any subfolders of their required files etc go into the "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins" folder [on a 64bit system, or on a 32bit set up there's no ' (x86)' in the Program File's name]... BUT there secrete them away in a special folder for you to decide that you really wanted to do that!!!].
                  Sometimes MS [mis]treat users as if they are morons! πŸ˜’
                  • T
                    Thoryan
                    Are you an Admin?
                    Having a similar problem. I did manage to upgrade the plugins folder security, which actually let the plugins tab display, but still there isn't any option of opening the round corners toolbar.
                    It just displays the following message when i open sketchup:
                    Error Loading File ZLoader__RoundCorner.rb
                    no such file to load -- LibFredo6.rb
                      Thoryan
                      That's because you haven't installed the additional required 'LibFredo6', as explained on the tools download page!
                      Get it from the link, extract it and install, and restart...
                      • T
                        Thoryan
                        @tig said:
                        Thoryan
                        Thanks Tig, that's done the trick nicely!
