    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 381.3k Views 71 Watching
      @Solodown
      Il y en a plein dans la version franΓ§aise πŸ˜‰
      (9 pages πŸ’š
        TIG, thank you for this most excellent tool. It made these twisted spindles absolutely trivial to draw. And lightweight at 47 Kb, too.
        http://farm4.static.flickr.com/3207/5819092833_b558ffdda7_z.jpg
          Possible?
            That'd make it the Bezier-surface-editor that ThomThom's working on ?
            You could add a central 'spine' curve scaled/adjusted as desired and make the mesh in two halves that you recombine later on - erasing coplanar edges etc... To quickly make the spine-rail divide the profile into two equal parts and weld back, then use EEbyRailsToLattice > Rails only - then adjust the central spine-rail as desired and use that curve as a rail twice to make the two meshes you'll later combine....
              I just want to be able to place Cpoints here and there as anchors for the mesh. It's not possible? [under one tool]
                davs001 from 'CatchUp Edition 4' thread ...: I have problems when I followed the niche tutorial. When I tried to use Extrude Edges by Rails in SU8, it allow me to select the profile, rails, etc. but nothing happens. I changed to SU7 and the extruded surface came up immediately. This is my second Issue with SU8…
                Your help please...
                [I've split the thread off into EEbyRails...]
                Assuming you follow the steps correctly as prompted there should be no issues with EEbyRails
                There are some rare clashes with other scripts that change base classes - like group - ill-advisedly... These then stop some tools like Mirror, EEbyRails... and 2dBoolean - actually it's more common in v7 than v8 πŸ˜•
                Some culprit scripts are DrivingDimensions[seen with v7 only - so far], SketchyPhysics[some versions] and a few pretty unusual tools I can recall off hand but you are unlikely to have loading...
                The scripts that fail are doing nothing wrong - the 'rogue' scripts are messing with the way Sketchup handles groups etc...
                  davs001
                  Thank you TIG.
                  I did the same steps in SU8 and SU7. they allow me to select all the elements. The difference is, in SU8 after selecting the melding profile nothing happens, but in SU7 it generates the surface immediately. May I offer you some information to diagnose the issue?
                  Kind Regards from CHILE!
                    If you try it with the Ruby Console open do you get any error messages?
                    Most of users [99.9%] have no problems with any 'version'.
                    You must either have something wrongly installed OR [more likely] an unusual script loading that's messing with stuff !
                    So - error messages and/or a list of loading plugins, please... πŸ˜•
                      lea moura
                        Version 3.3 has been released - it now includes a 'Quad Face' option [smoothed diagonals only] to complement thomthom's Quad-Tools...
                        It is part of the 'zipped set'.
                        See here for notes and link http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                          πŸ‘ πŸ‘
                          ( QF 0.4 will change the definition of a QuadFace slightly, after a discussion I had with Fredo. But I'll be offering a conversion tool, so it should be of no trouble for users to get things working while the new definition is rolled out. I'll let you know when it's shipping ready. )
                            Version 3.4 has been released - it now includes a 'Quad Face' option [smoothed+soft+hidden diagonals only] to complement thomthom's imminent Quad-Tools...
                              Version 3.5 has been released - it now only smooths edges with more than one face [like the built-in tool]... It is part of the 'zipped set'.
                                amro amro
                                Next will be Coon'Surface? β˜€
                                (just add the oposite profile as Rail 3 πŸ˜„
                                thanx
                                  Version 3.6 has been released http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                                  The Quad Faces option now meets latest changes to Thomthom's spec.
                                  See notes and download as part of the zipped set, obtained from the linked thread...
                                    devran
                                    Please help!!! "Extrude Edges by Lines" does not work with edges and circles as the path. The Edge does not rotate at the center of the circle.
                                    http://img442.imageshack.us/img442/5513/extrudeedgesbypath.jpg
                                    I prefer to use extrusion tools instead of "follow me", with follow Me i would use the Circle as the path and delete the unnessassery faces...
                                    http://img696.imageshack.us/img696/985/extrudeedgesbypath2.jpg
                                      You are mistaken.
                                      The circular-face should NOT rotate around the arc-path 'like FollowMe'.
                                      If it did then you might as well use FollowMe !
                                      So then use FollowMe ??
                                      IF you made an alternative circular 'melding-profile' half-way around the arc and another profile at the end, then dong it in two halves would give a result something like you want...
                                      If FollowMe does what you want us eit.
                                      EEbyRails is meant to be used to meld two profile curves along two rail curvess.
                                      Which is hardly what you illustrate with just one profile and one rail.
                                      If you read the notes there are limitations on using closed loop profiles/rails...
                                      There are tools/ways of doing this... BUT you are starting with the wrong premise...
                                      • gillesG Offline
                                        gilles
                                        if you want to lathe your profile choose the lathe tool, fourth icon in the tool-bar AND type the angle (360Β° for a full revolution) .
                                        It's hard work to cut a plank with a hammer.
                                        • N Offline
                                          ninehundred
                                          Ive got a bit of a problem. Ive been trying to turn my edges into tubes but i cant figure out how to do it as my model isnt a set of curved lines that can utilise this tool. Blender has a function called 'wireframe' which turns all edges into tubes. I was wondering if sketchup had a function like this where i could simply select all the edges in the model then extrude them into tubes/ square sections/ triangular sections etc.
                                          Another thing is, i was wondering if it might be possible to add a junction tool onto this so i could define a junction (say a ball joint) that the tubes would fit into.
                                          here are a couple examples:
                                          http://bridgehunter.com/photos/13/55/135570-L.jpg
                                          302 Found
                                          (ktsadium.files.wordpress.com)
                                          http://kubahwarna.blogdetik.com/files/2011/07/space-frame2-300x225.jpg
                                          this last one is more what im looking for than anything else.
                                            You won't get in in this tool.
                                            Didier Bur has a tool to make individual 'tubes' from selected edges. although the junctions intersect and need manual tidying,,,
                                            Taff Goch has some geodesic tutorials, including how to make 'node-joints' etc...
                                            If you have/make a 'stick' proxy of the form, then adding nodes of the joint-components [with centered insertion-points] manually is a simple 'snapping. exercise...
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 19 / 20
