    What is this? [Airplane part]
    11 Posts 7 Posters 831 Views 7 Watching
    • numbthumbN Offline
      numbthumb
      ItΒ΄s the rod antenna mast.
      With wire to the rudder.
      Comfortably numb...
        numbthumb
        As seen here: http://spitfiresite.com/2010/04/spitfire-masts-and-aerials.html/2
        Are you working on Spitfire? πŸŽ‰
        Comfortably numb...
        • boofredlayB Offline
          boofredlay
          Excellent, thanks.
          Not a Spitfire but another beast. Keep an eye out for the next CatchUp issue πŸ˜‰
          • HumpmetwiceH Offline
            Humpmetwice
            I've always had a love for old WW2 planes. I hope you're working on the Mustang Boofredlay.
            • soloS Offline
              Looking forward to seeing it Eric.
              Bigboy 2 flies again.
                Eric, FWIW, the wire is the antenna and is not there to stabilize the vertical stabilizer.
                Here's a close up of how it attached to the rudder.
                http://spitfiresite.com/uploaded_images/zexspitfi4.jpg
                • EscapeArtistE Offline
                  EscapeArtist
                  HF TR9 antenna (air/ground communications radio). This would likely be an early model Spitfire, as later ones began eliminating the wire, then parts of the aerial masts as they moved from HF to VHF and added IFF and other features.
                    boofredlay
                    Thanks again guys.
                    An interesting thing I was looking over Daniel Simon's Flicker page last month and saw some great photographs. Not only is he a fantastic designer but a great photographer. There was an aircraft (Fouga Magister) in one of his photos with what looked like handles on the nose. I did some research and found out that it was an antennae. Now how could I find that out but not about the Spitfire antennae??? πŸ˜†
                    Here is the photo and a document that details the antennae, p27 & p77.
                    http://salamanca.khbo.be:8080/doks/do/files/FiSe8a8199820e31b83d010e36bba18a0085/Eindwerk_KHBO.pdf;jsessionid=48F2A661F7E7300D7BF6726BD4242048?recordId=SKHB8a8199820e31b83d010e36bba18a0084
                      Those are antennae for the VOR received while the one on the spit was for communications. You could have both on your airplane. I haven't thought about VORs for a long time. It was kind of fun navigating by them or flying a VOR approach.
                        I repaired/maintained a fouga magister. The irish airforce had 4 but now they're only used as ornaments. Pilots would say if they had to eject it meant death. Instant collision with stabiliser as you need to turn plane upside down and fall out.
