    What is this? [Airplane part]
    11 Posts 7 Posters 981 Views 7 Watching
    • boofredlayB
      boofredlay
      What is the vertical bar and cable between the cockpit and tail section called? What is the exact purpose? I think it is for stabilizing the tail but I am not sure.
      Thanks.
      • numbthumbN
        numbthumb
        It´s the rod antenna mast.
        With wire to the rudder.
        Comfortably numb...
        • numbthumbN
          numbthumb
          As seen here: http://spitfiresite.com/2010/04/spitfire-masts-and-aerials.html/2
          Are you working on Spitfire? 🎉
          Comfortably numb...
          • boofredlayB
            boofredlay
            Excellent, thanks.
            Not a Spitfire but another beast. Keep an eye out for the next CatchUp issue 😉
            • HumpmetwiceH
              Humpmetwice
              I've always had a love for old WW2 planes. I hope you're working on the Mustang Boofredlay.
              • soloS
                Looking forward to seeing it Eric.
                Bigboy 2 flies again.
                  Eric, FWIW, the wire is the antenna and is not there to stabilize the vertical stabilizer.
                  Here's a close up of how it attached to the rudder.
                  http://spitfiresite.com/uploaded_images/zexspitfi4.jpg
                  • EscapeArtistE
                    EscapeArtist
                    HF TR9 antenna (air/ground communications radio). This would likely be an early model Spitfire, as later ones began eliminating the wire, then parts of the aerial masts as they moved from HF to VHF and added IFF and other features.
                    • boofredlayB
                      boofredlay
                      Thanks again guys.
                      An interesting thing I was looking over Daniel Simon's Flicker page last month and saw some great photographs. Not only is he a fantastic designer but a great photographer. There was an aircraft (Fouga Magister) in one of his photos with what looked like handles on the nose. I did some research and found out that it was an antennae. Now how could I find that out but not about the Spitfire antennae??? 😆
                      Here is the photo and a document that details the antennae, p27 & p77.
                      http://salamanca.khbo.be:8080/doks/do/files/FiSe8a8199820e31b83d010e36bba18a0085/Eindwerk_KHBO.pdf;jsessionid=48F2A661F7E7300D7BF6726BD4242048?recordId=SKHB8a8199820e31b83d010e36bba18a0084
                        Those are antennae for the VOR received while the one on the spit was for communications. You could have both on your airplane. I haven't thought about VORs for a long time. It was kind of fun navigating by them or flying a VOR approach.
                          I repaired/maintained a fouga magister. The irish airforce had 4 but now they're only used as ornaments. Pilots would say if they had to eject it meant death. Instant collision with stabiliser as you need to turn plane upside down and fall out.
