    Cel Shading
    9 Posts 5 Posters 3.2k Views 5 Watching
      PrizeGold
      Hi All! I'm just using Sketchup and i'm making some cars and tracks for my long term University project. But, i wanna do a Toon-like graphics, so i have to fall back in Cell Shading. But, i don't know how have very impressive Cell Shading graphics/effects on my objects. Could you help me please?
      Thanks to all,
      Greetings 😉
        Could you post an image as an example?
        • EscapeArtistE Offline
          EscapeArtist
          He's referring to a "toon shader" or cel shader, as in how cartoons look. I honestly don't know of any render apps for SU that have that feature, the ones that I can think of offhand that have it are 3DS Max and Maya.
          More here:
          https://secure.wikimedia.org/wikipedia/en/wiki/Cel-shaded_animation
            Thanks Jeff. The extra L in cel confused me.
              KarinaGM
              If you need stills, maybe sculptris could help you, but it depends on the model you are working with. You will need a lot of subdivisions, export in triangles and is betther with organic forms.
              It works with shaders and I've seen a couple of them that look toonish. This is one that I used, but you can find a lot more or create your owm.
              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
              -Benjamín Franklin.**
                kaas
                I tried the same at some point and used the following trick:
                1. draw your objects in 3d and group them
                2. create a clone of the group and scale it 120% from the middle
                3. make the exterior faces of your clone object 100% transparency and the interior faces 100% black
                The result will be that your clone object will give a black contour.
                For simple objects this works. For complex objects it can result in much work and lesser results.
                Greetings, Max
                  Did you look at FotoSketcher? It might give you a usable result.
                    PrizeGold
                    First of all i want to thank you all 😄
                    To reply some answers, i want to work on 3D model of cars, but also, in future, buildings, roads, and so on. But now i'm focused on cars. For example, i want to have a result close to this:
                    http://www.gamershell.com/static/screenshots/4616/86393_full.jpg
                    I don't know if you know this game, it was Auto Modellista, nice game, gameplay apart 😉
                    Sorry for the "Cell" Shading error, that's because in some sites i have found written "Cell Shading" and in others "Cel Shading" so i was a little bit confused. Regards, excuse me for my bad English, but i'm Italian and i have a little bit trouble to speak english 😄
                      KarinaGM
                      I think you can get this result with layers in the gimp or photoshop. Yo make a realistic render and overlay a line drawing from sketchup.
