    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      First make sure that you align the whole thing (group, straight line and curve) in a way that the straight line is parallel to the red axis. This is an often overlooked condition (and Chris has been keeping this plugin in Beta version for ages now) πŸ˜’
      Anyway, you can attach any images or many other file types under the text area you are posting (there is an "Upload attachment" tab). the [img] tab is for including/embedding images hosted elsewhere.
        @xorthan said:
        So it looks like it should be working now, and I'm following the instructions from the video: I click on my group or component (I've tried both), then click on the Tool Bar. After that, I should be able to select my straight line, right? Left clicking doesn't do anything. Right clicking brings up a menu that does have anything to do with Shape Bender.
        Argh.
        How do I include screen shots? I clicked on Img - what do I stick between the brackets?
        Please go back to the original post and watch the videos that Chris did. This plugin is not that difficult to use.
          When you try it please have Window > Ruby Console open and post any errors that appear there - it might still not be fully installed ??
          These messages might help us spot what is missing/broken...
          • X Offline
            Xorthan
            I can't find any other forum that's having problems like this. Let me be clear. I have watched the videos several times. Here's where I get stuck:
            1. I select my group.
            2. I select Shape Bender from Plugins, or by using the little icon in the Tool Bar.
            3. My message bar says, "Please select a single line that lies on the red axis." I attempt to select the single line on the red axis. It's pretty much copied right of the video. I have a straight line on the red axis. Next to it, a french fry. And a little further beyond the french fry, an arc. I understand I should be able to select the single line that lies on the red axis and then select the arc. But left clicking on the single line DOES NOTHING. Right clicking on the single line brings up a menu with options that have nothing to do with Shape Bender.
            TIG, you requested the stuff from Ruby:
            Error: #<TypeError: can't convert nil into String>
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:161:in create_cursor' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:161:in make_cursors'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:131:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:1017:in select_tool'
            Error: #<TypeError: no implicit conversion from nil to integer>
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in set_cursor' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in onSetCursor'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:161:in select_tool' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:1017 Error: #<TypeError: no implicit conversion from nil to integer> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in set_cursor'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in onSetCursor' Error: #<TypeError: no implicit conversion from nil to integer> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in set_cursor'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in onSetCursor' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:176:in onMouseMove'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:176:in onMouseMove' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168 Error: #<TypeError: no implicit conversion from nil to integer> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in set_cursor'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in onSetCursor' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168 Error: #<TypeError: no implicit conversion from nil to integer> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in set_cursor'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:233:in onLButtonUp' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168 Error: #<TypeError: no implicit conversion from nil to integer> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:168:in set_cursor'
            • Chris FullmerC Offline
              woohoo, we're getting somewhere.
              You didn't install it right.
                You should have clf_shape_bender_loader.rb in the plugins folder.
                Then all the other files - clf_shape_bnder.rb and all the shapebender icons should be in a subfolder called shapebender.
                The zip file is arranged this way, so you should have just been able to open the zip file and drag it directly into your plugins folder, with the folder hierarchy correct. So, please go try to re-install it, or just manually put all other shapebender files into a subfolder call shapebender.
                Good luck!
                  It works for me.
                  Thank you Chris. This is what TIG and I have been trying to get across.
                  • X Offline
                    Xorthan
                    Well, I thought I had all of the files the way you listed them, but I deleted everything and reinstalled it, and it's working perfectly.
                    Thanks to all who helped me out with this! Sorry it took me so long.
                      πŸ˜’
                      All's well that ends well.....
                      Anyone else with this type of problem... please read the instructions and try again!
                      πŸ˜†
                        penumbradesign
                        Chris,
                        per our discussion. Still crashes, select first line select second line (curved) then crash without warning.
                        Here are my plugins.
                        Best,
                        My plugins.
                          penumbradesign
                          So my problem is as follows: Preselect my group, select first line, select second line (curved), automatic bug splat! no explanation, no warning.
                          after an hour or so sifting through my plugins, I discovered that when SU Podium V2 (i have version 2.6, the file is called SU_Podium_V2.rbs) is present in your plugins folder it causes for shapebender to crash automatically,
                          has anybody experienced the same?
                          Best,
                            reydavid
                            Having problems with the plug-in. I basically try to select the first option (red axis line) and it does not select any line. Therefore I can even get to the second part of selectingthe arc line. I am currently using skp 8 on windows 7. I am not sure if the script does not work on windows 7.
                            Any help?
                              You need to give us more. Could you post the SKP that is giving you trouble?
                              The plugin does work on Windows 7 so I don't think that's the problem.
                                Have you got progressbar.rb installed, as the instructions.
                                The line must be parallel to the red-axis, that line and the curve/arc cannot touch each other OR touch any other geometry.
                                If these two things seem correct then run it with the Ruby Console open and post error messages.
                                  I'm going to guess its an installation problem - cursor icons in the wrong spot. That seems to be the main reason people can't select things.
                                  You can open the Ruby Console and see if it gives any errors while running the script. Then copy and paste them back here for us to read.
                                  I might just need to update shape bender with a quick fix to have it verify that it was installed correctly - subfolder, and files in the right spot. Maybe it can even move them around they are in the wrong spot. And check that progressbar is installed. And then I suppose it would be easy enough to tell people that their line is not on the red axis.
                                  I think those couple of fixes would be enough to save ourselves (and TIG and Dave in particular) some serious headaches. I think 56 of the 58 pages all revolve around installation ("copy and paste") issues.
                                    Chris, it would be great if you could get the plugin to repair itself. You're right about the installation problems. Of course yours isn't the only plugin that folks don't install correctly.
                                    • N Offline
                                      nnguyen2288
                                      Hi guys
                                      I'm having a problem with the shape bender plugin and I can't seem to figure out what is going on. I am working with a file I downloaded off the 3d warehouse and whenever I try to use the shape bender plugin it rotates the object rather than bending it. The screenshot shows you what I am talking about. The plugin works fine on other files so it appears to be something about this particular file. I figured it could be something with the axes, but I can't find a solution. Any suggestions???screen.jpg
                                        Try placing the instance, line and curve in the +ve quadrant = solid red/green.
                                        And retry...
                                        Also is the object a reasonable size ??
                                          Yeah, I think I agree. Rotate the whole bending setup 180 degrees and move it into the positive red and positive green quadrant. That will probably help.
                                          • N Offline
                                            nnguyen2288
                                            It worked! How foolish of me. In terms of whether the piece is reasonably sized or not... it was just a test. Actually trying to do a coiled wire that runs along an arc. This will help greatly. Thank you for your help
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 63
                                            • 64
                                            • 30 / 64
