[Plugin Library] LibFredo6 - v14.5b - 24 May 24
Can you check your version of Safari.
If it is Safari 5.0.6, then bad luck, there is a big issue (which is under resolution, see that thread)Thanks to confirm. Also, do you see the images in the dialog box (I mean the small + and - at the top of the table, on left)?
Safari is Version 5.1 (7534.48.3)
You are right images not showing correctly.
regards -
NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
LibFredo6 4.1 is a technical release which normally fixes some issues for recent version of Mac OS and Safari 5.0.6 and above (images not displayed and check for update not working).
hm, problem persist the same !
Could you try with this patch (drop the attached file into LIBFREDO6_Dir_41 folder)
Lib6WebWdlg.rbFredo
"Fredo6"]NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
hmm, problem persist the same - images and update, message is;
"ERROR in Check for Update
Please verify your Internet connection
The Following URLS could not be checked
-- Sketchucation Forum (http://forums.sketchucation.com/viewtopic.php?f=180&t=3263)" -
[attachment=0:28se3n33]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:28se3n33]yes - done - unfortunately no change
[attachment=0:q3lrc8is]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:q3lrc8is]yes - done - unfortunately no change
Then there is another difference between 5.0.6 and 5.1.
In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally". This refresh the web dialog box. Can you then see the images.Thanks
[/quote]<<In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally".>> - yes
<<This refresh the web dialog box.>> - dose not refresh box!
<<Can you then see the images.>> - checkbox yes images no, text onlyregards
bimbachi -
Bimbachi,
Alternatively, click on one of the colored filtering cross box. This should refresh the dialog box.
Also, can you then try with this patch
to drop into LIBFREDO6_Dir_41 folderThanks very much
Iv down loaded the plugin and put it the directory stated above but nothing shows up when i start up sketchup? im using a mac and have followed all the steps but still nothing... any help please
Do you have a menu Windows > LibFredo6 settings....?
NEW RELEASE: LibFredo6 v4.2a - 16 Sep 11
LibFredo6 4.2 should fix some issues for recent versions of Mac OS and Safari 5.0.6 and above (images not displayed and check-for-update not working). LibFredo6 4.1 was not fully solving the problem.
Fred,
Everything now works on Safari 5.0.6.
thanks for all your great plugins and pursuance of cross platform performance.
if I had the money, I'd buy you a mac as a well deserved reward...
What was your solution?
The solution is to use
set_file
with a temporary HTML file in the Temp directory. Simply, I had inadvertedly left a piece of code which was still doing aset_html
under certain conditions, and set_file did not supersede the set_html (strangely, even if the HTML was taken from the temp file, the web dialog was created with the window.location = about:blank -- only a refresh of the page would make it right).Fredo
Yep, solved it here.
Cookies to Fredo ! -
thank you Fredo
I'm trying to install this on a mac. Not clear on how to extract the files into SUplugins.I unzipped the file on the desktop and can select all the files but unsure what to do next.
@coolie44 said:
The unzip operation should lead to a simple footprint in the SU plugins directory
- a file: libFredo6.rb
- a folder: LIBFREDO6_Dir_42
Possibly do the extract in a neutral place, and then copy the file and folder to the SU Plugins directory.
Hello Fredo6,
I'm on Mac running OS X Snow Leopard and I've DL all your files and don' manage to install it properly despite I've been following your advices on the .pdf or this web site.
I don't know exactly what's wrong with what I'm doing but it's not working...
libFredo6.rb and libFredo6.pluging are in the right (I think) directory "Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins"
I've DL 000_AdditionalPluginFolders.rb and put it in this directory "Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins" but same same, it's not working.Basically I'm a bit lost and would love to find the solution to make it work.
This tools looks amazing to use and make the work so much easier.If any one as a idea I will be pleased and really thankful.
hi,
do you have any working plugins? i.e. others that do work.
can you post a screenshot of the path to your plugins folder.
