    [Plugin Library] LibFredo6 - v16.0a - 08 Aug 26
    2.2k Posts 580 Posters 6.3m Views 582 Watching
      bimbachi
      "Fredo6"]NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
      hmm, problem persist the same - images and update, message is;
      "ERROR in Check for Update
      Please verify your Internet connection
      The Following URLS could not be checked
      -- Sketchucation Forum (http://forums.sketchucation.com/viewtopic.php?f=180&t=3263)"
        bimbachi
        Could you try with this patch (drop the attached file into LIBFREDO6_Dir_41 folder)
        [attachment=0:28se3n33]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:28se3n33]
        yes - done - unfortunately no change
        • fredo6F Offline
          [attachment=0:q3lrc8is]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:q3lrc8is]
          Then there is another difference between 5.0.6 and 5.1.
          In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally". This refresh the web dialog box. Can you then see the images.
            bimbachi
            [/quote]
            <<In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally".>> - yes
            <<This refresh the web dialog box.>> - dose not refresh box!
            <<Can you then see the images.>> - checkbox yes images no, text only
            regards
            bimbachi
            • fredo6F Offline
              Bimbachi,
              Alternatively, click on one of the colored filtering cross box. This should refresh the dialog box.
              Also, can you then try with this patch
              to drop into LIBFREDO6_Dir_41 folder
              Thanks very much
                Myro21
                Iv down loaded the plugin and put it the directory stated above but nothing shows up when i start up sketchup? im using a mac and have followed all the steps but still nothing... any help please
                • fredo6F Offline
                  Do you have a menu Windows > LibFredo6 settings....?
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v4.2a - 16 Sep 11
                    LibFredo6 4.2 should fix some issues for recent versions of Mac OS and Safari 5.0.6 and above (images not displayed and check-for-update not working). LibFredo6 4.1 was not fully solving the problem.
                      driven
                      Fred,
                      Everything now works on Safari 5.0.6.
                      thanks for all your great plugins and pursuance of cross platform performance.
                      if I had the money, I'd buy you a mac as a well deserved reward...
                        What was your solution?
                        • fredo6F Offline
                          The solution is to use set_file with a temporary HTML file in the Temp directory. Simply, I had inadvertedly left a piece of code which was still doing a set_html under certain conditions, and set_file did not supersede the set_html (strangely, even if the HTML was taken from the temp file, the web dialog was created with the window.location = about:blank -- only a refresh of the page would make it right).
                          • mariochaM Offline
                            mariocha
                            Yep, solved it here.
                            Cookies to Fredo !
                            %(#008000)[Mario C.
                            • N Offline
                              niks
                              thank you Fredo 😉
                                coolie44
                                I'm trying to install this on a mac. Not clear on how to extract the files into SUplugins.
                                I unzipped the file on the desktop and can select all the files but unsure what to do next.
                                • fredo6F Offline
                                  @coolie44 said:
                                  The unzip operation should lead to a simple footprint in the SU plugins directory
                                  • a file: libFredo6.rb
                                  • a folder: LIBFREDO6_Dir_42
                                  Possibly do the extract in a neutral place, and then copy the file and folder to the SU Plugins directory.
                                    loyflut
                                    Hello Fredo6,
                                    I'm on Mac running OS X Snow Leopard and I've DL all your files and don' manage to install it properly despite I've been following your advices on the .pdf or this web site.
                                    I don't know exactly what's wrong with what I'm doing but it's not working...
                                    libFredo6.rb and libFredo6.pluging are in the right (I think) directory "Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins"
                                    I've DL 000_AdditionalPluginFolders.rb and put it in this directory "Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins" but same same, it's not working.
                                    Basically I'm a bit lost and would love to find the solution to make it work.
                                    This tools looks amazing to use and make the work so much easier.
                                    If any one as a idea I will be pleased and really thankful.
                                      driven
                                      hi,
                                      do you have any working plugins? i.e. others that do work.
                                      can you post a screenshot of the path to your plugins folder.
                                      • fredo6F Offline
                                        @loyflut said:
                                        Hello Fredo6,
                                        First, I guess you use Sketchup 8. So the standard directory for Plugins should be
                                        "Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins".
                                        I say that as you seem to use also the ...Google Sketchup 7...directory.
                                        Second, LibFredo6 is not really a plugin by itself, but a library supporting other plugins.
                                        At least did you check you have a menu ***Windows > LibFredo6 settings.....***If so, then you have a correct installation and ready to dowload and install my other scripts (like FredoScale, Roundcorner, ...)
                                          loyflut
                                          John,
                                          No i don't have any working plugin yet.
                                          So here the first screenshot where I put all of them.
                                          I don't think I should put it here (second screenshot)
                                          Fredo,
                                          Yes I use SU pro 8 (I copy/past from the first post you give 😳 )
                                          So Where should I put LibFredo6 ?
                                          No I don't see LibFredo6 settings in my menu, I don't get what to do btw LibFredo6, and 000_AdditionalPluginFolders or even FreeScale....
                                          Sorry guys I'm a waist of time...
                                          Thank your help
                                          Where I put all the plugin
                                          2nd shot
                                          • fredo6F Offline
                                            @loyflut said:
                                            John,
                                            Fredo,
                                            Thank your help
                                            Your footprint is not correct. You don't have a Folder LIBFREDO6_Dir_42 in your SU Plugins folder (and you have a file LibFredo6.plugin which should not be there).
                                            I suggest you download the ZIP file and do the extraction in a separate directory. You hsould have only:
                                            • 1 file, LibFredo6.rb
                                            • 1 folder LIBFREDO6_Dir_42
                                              Then, when it is OK, copy the file and the folder to the SU Plugins Directory, that is, Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 111
                                            • 112
                                            • 16 / 112
