    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      In the first post, there is a big Download button under which there is the link (or click on the image below - you need to be logged in)
      http://forums.sketchucation.com/download/file.php?id=49285
        Lulliloo1
        ref my post this morning regarding downloading:
        [Plugin Library] LibFredo6 - v4.0a - 23 Aug 11'
        The download link did not work with Google Chrome, but it did with Windows Explorer (9). Problem solved...
          that's odd. I've never had any trouble downloading any files from here with Chrome. You might want to check your settings in Chrome.
            bimbachi
            hello
            i'm having problem with "Check Plugins for Update"
            attached screen info
            any idea how to solve it?
            regards
            ps.-i'm on mac, osx 10.7.1
            • fredo6F Offline
              @bimbachi said:
              hello
              regards
              Can you check your version of Safari.
              If it is Safari 5.0.6, then bad luck, there is a big issue (which is under resolution, see that thread)
              Thanks to confirm. Also, do you see the images in the dialog box (I mean the small + and - at the top of the table, on left)?
              PS: I hope I can publish a fix soon.
                bimbachi
                Safari is Version 5.1 (7534.48.3)
                You are right images not showing correctly.
                regards
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
                  LibFredo6 4.1 is a technical release which normally fixes some issues for recent version of Mac OS and Safari 5.0.6 and above (images not displayed and check for update not working).
                  • fredo6F Offline
                    hm, problem persist the same !
                    Could you try with this patch (drop the attached file into LIBFREDO6_Dir_41 folder)
                    Lib6WebWdlg.rb
                      bimbachi
                      "Fredo6"]NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
                      hmm, problem persist the same - images and update, message is;
                      "ERROR in Check for Update
                      Please verify your Internet connection
                      The Following URLS could not be checked
                      -- Sketchucation Forum (http://forums.sketchucation.com/viewtopic.php?f=180&t=3263)"
                        bimbachi
                        [attachment=0:28se3n33]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:28se3n33]
                        yes - done - unfortunately no change
                        • fredo6F Offline
                          [attachment=0:q3lrc8is]<!-- ia0 -->Lib6WebWdlg.rb<!-- ia0 -->[/attachment:q3lrc8is]
                          Then there is another difference between 5.0.6 and 5.1.
                          In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally". This refresh the web dialog box. Can you then see the images.
                            bimbachi
                            [/quote]
                            <<In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally".>> - yes
                            <<This refresh the web dialog box.>> - dose not refresh box!
                            <<Can you then see the images.>> - checkbox yes images no, text only
                            regards
                            bimbachi
                            • fredo6F Offline
                              Bimbachi,
                              Alternatively, click on one of the colored filtering cross box. This should refresh the dialog box.
                              Also, can you then try with this patch
                              to drop into LIBFREDO6_Dir_41 folder
                              Thanks very much
                                Myro21
                                Iv down loaded the plugin and put it the directory stated above but nothing shows up when i start up sketchup? im using a mac and have followed all the steps but still nothing... any help please
                                • fredo6F Offline
                                  Do you have a menu Windows > LibFredo6 settings....?
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v4.2a - 16 Sep 11
                                    LibFredo6 4.2 should fix some issues for recent versions of Mac OS and Safari 5.0.6 and above (images not displayed and check-for-update not working). LibFredo6 4.1 was not fully solving the problem.
                                      driven
                                      Fred,
                                      Everything now works on Safari 5.0.6.
                                      thanks for all your great plugins and pursuance of cross platform performance.
                                      if I had the money, I'd buy you a mac as a well deserved reward...
                                        What was your solution?
                                        • fredo6F Offline
                                          The solution is to use set_file with a temporary HTML file in the Temp directory. Simply, I had inadvertedly left a piece of code which was still doing a set_html under certain conditions, and set_file did not supersede the set_html (strangely, even if the HTML was taken from the temp file, the web dialog was created with the window.location = about:blank -- only a refresh of the page would make it right).
                                          • mariochaM Offline
                                            mariocha
                                            Yep, solved it here.
                                            Cookies to Fredo !
                                            %(#008000)[Mario C.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 108
                                            • 109
                                            • 14 / 109
