    [Plugin] CleanUp
    974 Posts 217 Posters 862.3k Views 217 Watching
    • jamalitoJ Offline
      jamalito
      thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
      my SU is SU8
      Albert Einstein:
      ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
        my SU is SU8
        You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
        Have you ensured you also have the latest Edge Tools?
          blajnov
          @thomthom said:
          my SU is SU8
          Checked on a home computer, everything works fine, most likely due to adminpravami (at work today, he was absent), ie there is no access to the folder webdialog...
          Thomas, thanks for the update plug-in.
          • Z Offline
            Zacchia
            @thomthom said:
            Can you try:
            1. Type in the Ruby Console: TT::Lib::VERSION
            Well... this was in fact 2.5.4.... i am very sorry 😒 I was sure I changed to the new version but I did not! I am sorry and thank you so much for your support! Everything works fine now!
            • Z Offline
              Zacchia
              Hi Tom
              It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
                Cursed! 😞
                Ok, can you Right Click and empty window and click "View Source" ?
                • Z Offline
                  Zacchia
                  @thomthom said:
                  Cursed! 😞
                  In german lanuage "Quelltext anzeigen", hope you mean this...
                    I really do not understand why.
                    What is your Internet Explorer version btw?
                    • charly2008C Offline
                      charly2008
                      Hi Thomas.
                      I have updated to version 3.1.6 but now no more menu box appears. I can run it but only with "Clean with last settings". What could be wrong? In the ruby console appears (see picture below)
                      Charly
                      Command: Clean
                      Command: Clean with last settings
                        That error indicate that you haven't updated TT_Lib2 to 2.5.5. It should have given you an error about that at startup, so I don't understand why you didn't. 😕
                          charly2008
                          Thanks for the tip, I had an older version of TT_Lib2. Now it works again.
                          Charly
                          • dereiD Offline
                            derei
                            @thomthom said:
                            Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                            Sorry,my mistake ! the model was on Monochrome style view and I forgot I had materials applied.That is why the Cleanup didn't worked as expected. It overlapped with plugin update, so I thought is a plugin issue.
                            DESIGNER AND ARTIST DEREI.UK
                            • Z Offline
                              Zacchia
                              1. IE? Why is this important?
                                If it had been IE6 it would. WebDialogs use the IE engine under Windows.
                                  leocallejas
                                  Hi ThomThom.... I just recently discovered your plugin, and I´m really excited to test it out, but I get that same blank window in Windows 7 x64 running Sketchup 8, and Internet Explorer 8. Here are my screenshots, maybe they'll help you sort it out.
                                  Cheers! 😄
                                  http://img694.imageshack.us/img694/8228/blankhr.jpg
                                  http://img217.imageshack.us/img217/8760/versionsq.jpg
                                  http://img821.imageshack.us/img821/6006/propertiest.jpg
                                  http://img163.imageshack.us/img163/7218/sourceh.jpg
                                    I'll post an update to TT_Lib shortly. Not sure if it helps, but we'll see.
                                    Meanwhile, do you see a Compatibility Files button in Windows explorer when you view the plugins folder?
                                    • Z Offline
                                      Zacchia
                                      I do not understand this...
                                        Cheers! 😄
                                        Can you update to TT_Lib version 2.5.6 and report back if that made any difference?
                                          That was for leocallejas - he's on Vista. You won't see such a button in XP.
                                          If you want, you could try CleanUp 3.4.6 with TT_Lib 2.5.6 and see if that works.
                                            blajnov
                                            With the new library TT_Lib 2.5.6, the same problem, blank screen menu....
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 48
                                            • 49
                                            • 35 / 49
