    [Plugin] CleanUp
    974 Posts 217 Posters 984.3k Views 217 Watching
      I really do not understand why.
      What is your Internet Explorer version btw?
      • charly2008C Offline
        charly2008
        Hi Thomas.
        I have updated to version 3.1.6 but now no more menu box appears. I can run it but only with "Clean with last settings". What could be wrong? In the ruby console appears (see picture below)
        Charly
        Command: Clean
        Command: Clean with last settings
          That error indicate that you haven't updated TT_Lib2 to 2.5.5. It should have given you an error about that at startup, so I don't understand why you didn't. 😕
            charly2008
            Thanks for the tip, I had an older version of TT_Lib2. Now it works again.
            Charly
            • dereiD Offline
              derei
              @thomthom said:
              Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
              Sorry,my mistake ! the model was on Monochrome style view and I forgot I had materials applied.That is why the Cleanup didn't worked as expected. It overlapped with plugin update, so I thought is a plugin issue.
              DESIGNER AND ARTIST DEREI.UK
              • Z Offline
                Zacchia
                1. IE? Why is this important?
                  If it had been IE6 it would. WebDialogs use the IE engine under Windows.
                    leocallejas
                    Hi ThomThom.... I just recently discovered your plugin, and I´m really excited to test it out, but I get that same blank window in Windows 7 x64 running Sketchup 8, and Internet Explorer 8. Here are my screenshots, maybe they'll help you sort it out.
                    Cheers! 😄
                    http://img694.imageshack.us/img694/8228/blankhr.jpg
                    http://img217.imageshack.us/img217/8760/versionsq.jpg
                    http://img821.imageshack.us/img821/6006/propertiest.jpg
                    http://img163.imageshack.us/img163/7218/sourceh.jpg
                      I'll post an update to TT_Lib shortly. Not sure if it helps, but we'll see.
                      Meanwhile, do you see a Compatibility Files button in Windows explorer when you view the plugins folder?
                      • Z Offline
                        Zacchia
                        I do not understand this...
                          Cheers! 😄
                          Can you update to TT_Lib version 2.5.6 and report back if that made any difference?
                            That was for leocallejas - he's on Vista. You won't see such a button in XP.
                            If you want, you could try CleanUp 3.4.6 with TT_Lib 2.5.6 and see if that works.
                              blajnov
                              With the new library TT_Lib 2.5.6, the same problem, blank screen menu....
                                sigh I'm completely stomped. I have no idea why it fails on one computer but not the other - without any errors... 😞
                                I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?
                                  blajnov
                                  With the new library TT_Lib 2.5.6, the same problem, blank screen menu....[/quote]
                                  [quote:344sw0qv]
                                  I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?[/quote:344sw0qv]
                                  Returned to the library and TT_Lib 2.5.4 CleanUp 3.1.4, instead TT_Lib 2.5.6 and CleanUp 3.1.6, it worked ...
                                  It is unclear what the problem is!
                                    Did you try the file I sent you?
                                      blajnov
                                      I apologize for any inconvenience, I threw inputbox.rb file in the wrong folder, now replaced in the folder 😄 \ Program Files (x86) \ Google \ Google SketchUp 8 \ Plugins \ TT_Lib2
                                      Everything works fine.
                                      Many thanks for the sympathy!
                                        Update TT_Lib to 2.5.7 - I hope this finally fixes things.
                                          leocallejas
                                          Yep, I see the "Compatibility Files" button when I'm im the Plugins folder.
                                          EDIT: Wow I seem to have missed a lot of posts.. lol. Reading.
                                            That might be causing the problems. Ensure you have admin rights and move the files from that folder to the plugins folder. Windows Vista/7 some times moves things to a ghost folder to "protect" users - but when it comes it the plugins folder it just causes problems.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 48
                                            • 49
                                            • 22 / 49
