    How to debug?
    46 Posts 13 Posters 86.9k Views 13 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      line 7: no argument for the instance method DefinitionsList.add()
      I'm not here much anymore.
        tomot
        No that's not it ! ..... nice try!..... try again?
        my plugins
        tomot
          Jim
          end if!
            Dan Rathbun
            Wow... that's strange! An empty argument creates a new definition, whose name is "Component". The API does not mention this!!!
            And Jim.. got it correct... although I would think Ruby would issue a ScriptError, something like "blah blah blah...`end' expected"
              tomot
              yup! Jim is right!. So back to the initial subject, is there a debug routine for such errors?
              your editor should be causing a high pitch sound for end if or at least a blicking, or bouncing simile. πŸŽ‰
              my plugins
              tomot
                Jim
                I was going to suggest checking the syntax, but you would need to have Ruby version 1.8.6 installed (not a bad idea if you are developing plugins.)
                $ ruby -c plugin.rb plugin.rb:32: syntax error, unexpected $end
                  tomot
                  Jim: you have helped me with a few rubies I have posted here in the past,
                  would you please elaborate on I would install Ruby version 1.8.6 within the current Ruby/SU environment.
                  Currently I simply use NotePad ++ or SciTE to edit and develop my SketchUp Rubies.
                  my plugins
                  tomot
                    Dan Rathbun
                    Ruby Binary Installer:
                    • Ruby (v1.8.6-p287) Windows One-Click Installer
                    then use...
                    Ruby LOAD PATHs script (Win32) : ver 3.0.1
                      tomot
                      Dan, FYI, I have used that particular code several times to space entities between 2 know points, equally. I don't recall who helped me with the original code, many years ago.
                      my plugins
                      tomot
                        tomot
                        @jim said:
                        Ruby Toolbar started - on Windows, it can open/close the Ruby Console, Clear it, and load/reload a file.
                        Jim: I get the following error when starting SU
                        my plugins
                        tomot
                          Dan Rathbun
                          You need WIn32API.so
                          v186_p287_so.zip
                            brian_concannon
                            I have written a debugger for Sketchup plugins with watches and breakpoints. Why isn't such a debugger already available? Would it be a good contribution to the community? The breakpoints based on watched variable changes seem like the best part.
                            Download the user guide that I attached.
                            It needs some work yet, as it processes only the Ruby snytax that I have
                            programmed with myself. It is a VB6 app. It would be free.
                            Quote message
                            Face2Face plugin - autoextrusion between faces
                            Sent: Wed Dec 21, 2011 4:58 pm
                            by brian_concannon
                            TIG,
                            I posted the plugin as you suggested, in the Resources/Plugins forum. It is being downloaded like crazy!
                            I hope you make it part of your Edgedraw plugins somehow.
                            anyway, I have written a debugger for Sketchup plugins with watches and breakpoints. Why isn't such a debugger already available? Would it be a good contribution to the community?
                            Quote message
                            Re: Face2Face plugin - autoextrusion between faces
                            Sent: Wed Dec 21, 2011 5:16 pm
                            To: brian_concannon
                            It would probably be a useful adjunct.
                            Why not post in the Developers' forum with a new thread.
                            You don't need to post the whole of your code, just some ideas to get a discussion rolling...
                            Thomthom, Jim and Dan are more in debugging etc than I am. I manually slog through with my own return nils, breaks, testing puts, UI.messageboxe, refreshes etc till I get it to work
                            setup file (text)
                              That's my method of debugging as well. A debugger would be welcome. There is one out there already SuRDebug: http://code.google.com/p/surdebug/wiki/SuRDebug
                              I never got around to fully make it work... 😞
                                brian_concannon
                                I tried SurDebug early on and could not make it work either. I was told that the author got angry about some criticism, and he stopped working on it. There were no recent posts about it at the site that you show.
                                Debuggifier's concept is not as nice as the SurDebug concept, as it inserts debug statements after every Ruby statement in all or part of the code. It can be commented / uncommented at will, and totally removed ("undebuggified") when the Plugin development is complete. But I found it necessary to develop for my own programming, because Ruby is so hard to program with. Anyone using a true IDE knows this.
                                I will clean up Debuggifier a little and then post it. Since it is an EXE and requires VB6 DLL's to be installed with InstallShield etc, can I upload it to this forum? Can I upload a zip file?
                                  There's a 4mb limit and it'll will need to be .zip
                                  • ChiefwoodworkerC Offline
                                    Chiefwoodworker
                                    @thomthom said:
                                    And under Windows you have this snippet to output the data to debuggers like DebugView:
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=31216&p=274668#p274467
                                    A friend of mine showed me how to interface Unit Test (http://ruby-doc.org/stdlib-1.9.3/libdoc/test/unit/rdoc/Test/Unit.html) to the SketchUp API and the Ruby Console. It works really great for certain classes of scripts or methods and it allows you to develop a suite of tests that you can run automatically.
                                    If anyone is interested I can add instructions to this forum.
                                    Joe....
                                    http://www.srww.com
                                      πŸ‘ πŸ‘
                                      • liquid98L Offline
                                        liquid98
                                        [encourage] πŸ‘ [/encourage]
                                        Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
                                        • 2 / 3
