    [Plugin] VisTools
    69 Posts 21 Posters 72.4k Views 21 Watching
      Jim
      Hi Dana,
      Thanks for the utils, they are a nice addition to SketchUp.
      Just a note - Toolbar image sizes are 24x24 px for the large size and 16x16 px for the small size. SketchUp does a poor job of resizing your 32x32 icons on the toolbar which is why they don't look as nice as they should. Tool cursors are expected 32x32.
      • mitcorbM Offline
        mitcorb
        Hi, ishboo:
        A few questions, perhaps naive:
        Does this plugin disable the native hide/ unhide in sketchup, or work with it?.
        Do you see a need to have an "unisolate" feature as is available with Autocad? Or did I miss this in your description?
        Salute to you!
        • I Offline
          ishboo
          @jim said:
          Hi Dana,
          You're right Jim, I'll have to get around to changing them for the next release.
          SketchUp plugin marketplace: http://extendsketchup.com/
            pptoppto
            thanks!
            • 3dita3 Offline
              3dita
              AWESOME utility!!! working just like a 3ds max fundamental tool!!
              Must have, congrats
              3dita - Digital Visual Motion
              • I Offline
                ishboo
                @pptoppto said:
                thanks!
                Must have, congrats
                You're both welcome! Glad you like it!
                • Dan RathbunD Offline
                  Dan Rathbun
                  @dan rathbun said:
                  Language translators, and proofreaders needed.
                  I did the German (de) ..., and they need proofing.
                  Good news... Aerilius has volunteered to proof / edit the 'de' German files.
                  UPDATE: Aerilius finshed proofing / editing the German 'de' files... great job!
                  I'm not here much anymore.
                    Dan Rathbun
                    Thanks go to Tomot, for knocking out a first edition of the basic Polish 'pl' hash file !!
                    UPDATE: We will need a proofreader, who's first language is polish.
                      Dan Rathbun
                      This action item is complete: Here's the corrected images, for those of you who want to use them right away with ver 1.0
                      Unzip into your "Plugins/SU_Utils" directory (folder) [you can rename the current "images" folder to "images_bak" first if you desire.]
                        Dan Rathbun
                        Version 2.x is coming .....
                        I did the German (de) and Spanish (es) files, and they need proofing. (It's been 35 years since I took Spanish in high school, and I only 'dabble' in German when doing genealogy research.)
                        The files need to be Unix line endings (EOL) and UTF-8 encoded. They are named "basic_utf8_XX.hash" and "debug_utf8_XX.hash", where XX is replaced by the lowercase language code. (ie: 'en', 'es', 'pl', 'fr', etc...)
                        The plugin will "auto" find these files, or the user can choose a specific lang from those that are present. (In 'en' mode, the hash files are not actually loaded... as the Ruby code knows what the English strings are.)
                        <----<<<< PM me if you'd like to do a certain Language translation, or proofread/correct the 'de' or 'es' files.
                        If a debug hash file is not available for a certain language (but the UI strings in a basic hash file are present,) then the UI will be in that local language, and console output will be in English (if the user has turned it ON.)
                        So... the priority is on the 'basic' hash files, in order to show the UI elements in the local language.
                        replaceable parameters
                        %s will be replaced by a number, like: 34
                        '%s' will be replaced by an entity flag, like: '#<Sketchup::Face:0x624452c>'
                        The helper file for pasting into Google Translate.. or whatever
                        NOTE! The above file, and the hash file in the next post, will be used with ver 2.x,... they do NOT work with ver 1.0 (if that's why y'all are downloading, but not volunteering to translate.)
                        Translator links: Google Translate : MicroSoft Translator
                          You can try the translaters I used: http://www.thomthom.net/software/vertex_tools/translations
                            Dan Rathbun
                            Thanks go out to Defisto for proofing and editing the Spanish 'es' files !!!
                              Dan Rathbun
                              OK.. here's the basic hash template file:
                              The 'XX' in the name needs to be replaced with a 2 char. language code.
                              Within the file, change the "XX" hash values to the local translation.
                              Please use parenthesis ( ) as I have, and punctuation periods, or '...' where I have, in the translations.
                              Also repeat the use of capitalized words, as they are in the English keys.
                              The %s params can be moved in the translated strings, to where they are more appropriate for the particular language.
                              basic_utf8_XX.hash.txt
                              Here is the template file for the debug strings.
                              The technical terms should match those in the localized editions of Sketchup.
                              debug_utf8_XX.hash.txt
                                Dan Rathbun
                                Added the "debug" string template file in the post above...
                                see: http://forums.sketchucation.com/viewtopic.php?f=323&t=36465&p=350210#p350210
                                • I Offline
                                  ishboo
                                  Great to see all this activity!
                                    I am on the road for the French language! 😉
                                      I can do some Hungarian - need to install the plugin and see what it exactly does so that I understand why the expressions are what they are.
                                      • I Offline
                                        ishboo
                                        Excellent!
                                          limit=%s
                                          I have translated the word "limit" by "limite" in French : must or not ? (I suppose yes 😄
                                          Not yet tested 😳
                                          you must rename them ...utf8_fr.hash.txt I suppose?
                                            Dan Rathbun
                                            Looks good... Thank you.
                                            But... we need the Plugin Description in Francais, Si vous plaît:
                                            "Adds some useful tools within SketchUp, like Hide / Show entities and layers, Freeze / Unfreeze for components, and Show / Unfreeze all."
                                            Combination of Google & Microsoft Translators:
                                            %(#8000BF)["Ajoute quelques outils utiles dans SketchUp, comme Cacher / Montrer des entités et des calques, Gel / Dégel pour des composants, et de Montrer / Dégeler tous."]
                                            Sound OK ??
                                            • 1 / 4
