    [Code] file_found?(path) and to_ascii+to_unicode.rb
    42 Posts 5 Posters 6.5k Views 5 Watching
      sigh
      Euro can be used - just not typed into the Console. You might get it passed via SU's ruby method if it's used in a material name or component name. though .unpack('U') will return 8364 for it. Way outside the code point for ISO 8859-1. However, if you type in the octal value "\200" you get the Euro in a 1byte length string. So it should be mappable. But pack and unpack doesn't map the Unicode points between 128-160 well. So I'll be looking for a better conversion.
      I've heard of Iconv, but that's an Win API call I think - not a solution for Mac.
        I am glad you have taken such a complicated thing over .... πŸ˜„
          I'm not... 🀒 This makes my head hurt.
          But I need to know.
          But at least it beats sudoko puzzles... πŸ˜‰
            I can do those !!! πŸ˜‰
              πŸ˜„
              • daikuD Offline
                daiku
                But can you generate a puzzle using ruby code? Sounds like an idea for a ruby challenge.
                Clark Bremer
                http://www.northernlightstimberframing.com
                  tomasz
                  I am looking into this issue right now. I haven't found anything more then TIG and Thomas has figured out. I have even started to code a C extension to return proper string converted from Ruby UTF-8, but my poor C knowledge doesn't let me progress fast.
                  As far as I understand Win uses UTF-16 format, but the whole encoding thing hurts my head badly.
                  Have someone made any progress on this issue?
                  Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                    What are you trying to do? String conversion? Or deal with files with unicode characters?
                      tomasz
                      I am trying to create a file with a path/filename containing for example Polish characters 'BΕ‚Δ…d.xml'. They are not part of ISO 8859-1 so the .pack('C*') doesn't generate proper path and file will be created under different name 'BΔΉβ€šΓ„β€¦d.xml'
                        Right, what you want to do is make your C extension call the Unicode version of the file API's - as converting from Unicode to ASCII in order to try and make Ruby's file functions work will in most cases not work.
                        Note that the ASCII limitation for SketchUp's Ruby file functions exist only under Windows. Under OSX they should work AFAIK.
                        • Dan RathbunD Offline
                          Dan Rathbun
                          Do not ignore Dan Berger's windows-pr package. It goes along with his win32-api package. Has the Windows "unicode.rb"
                          In windows-apt-0.4.0 there's a complementary file "wide_string.rb"
                          I'm not here much anymore.
                          • 2 / 3
