⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
[Plugin] ClineStyler v1.0 20110822
13 Posts 11 Posters 11.5k Views 11 Watching
    (c) TIG 2011
    Permission to use, copy, modify, and distribute this software for
    any purpose and without fee is hereby granted, provided the above
    copyright notice appear in all copies.
    THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
    IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
    WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
    Script:
    clinestyler.rb
    Place it in the ../Plugins/ folder and restart Sketchup...
    Usage:
    If a selection includes Guide-Lines [clines] then there is a right-click
    context-menu item called 'ClineStyle...', which opens a drop-down list of
    possible cline-styles - choose one and those selected will now display in
    that style; you can revert to the default, which is also the '_' style but
    its code is 0 rather than 61680.
    Donations:
    by PayPal to info @ revitrev.orgPayPalButtonVersion:
    1.0 20110822 First Release.clinestyler.rb
      srx
      Thank you TIG. πŸ˜„
      www.saurus.rs
        8 downloads and 1 thank you. 😞
        Anyway, thank you again for this. Nifty tool πŸ‘
        • 3 Offline
          3dsmax9
          Thank's TIG πŸ˜„
          Thank's TIG πŸ˜„
          Thank's TIG πŸ˜„
          Thank's TIG πŸ˜„
          Thank's TIG πŸ˜„
          Thank's TIG πŸ˜„
          Thank's TIG πŸ˜„
          Thank's TIG πŸ˜„
          8 download = 8 Thank's TIG πŸ˜„
            schnydix
            Thanks Tig but with my screen resolution i cant see the difference
            It is possible to make the Clines into Lines (for Printing)and stronger than 1Pixel
            An realy working dashed line tool would be very nice.
            And a Big Big Thank you for spending so much time in programming for us stupid users
            Google and sketchup special programmers like you and all other great guys here are like
            little Robin hoods for me. You gife as a tool that is much better and faster than very expensive
            Programms. πŸ‘
            • U Offline
              utiler
              oops.... 😳 was directed here from another post and should have πŸ‘
              so here it is again, TIG. πŸ‘ πŸ‘
              purpose/expression/purpose/....
                little Robin hoods for me. You gife as a tool that is much better and faster than very expensive Programs. πŸ‘
                I can't fix your screen resolution!
                As long as Clines are not infinitely long you can use my tool 'xLine2Line.rb'
                http://forums.sketchucation.com/viewtopic.php?p=274567#p274567
                which converts selected lines to plain-lines.
                Then you could use the LineStyle tool in my 2Dtools
                http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                to give the line a color/width/dot-dash pattern - remember that then it's no longer a 'line' so snapping etc is no longer possible. The ideas of this ClineStyler is to allow you to change the appearance of selected clines for ease of identification - e.g. center ... instead of ----- ; it's not intended for presentation line styles - where Layout or 2Dtools come in...
                  schnydix
                  Thanks Tiger fast and helpfull answer.
                  and yes i see there is a concept behind your works.
                  Respect from Switzerland
                    seven.sides
                    Thanks TIG. This should be useful for presenting architectural drawings.
                      matt.gordon320
                      Thanks TIG!
                      • H Offline
                        huija
                        thanks TIG!
                          Titan1286
                          TIG - Thanks!
                            Does this the same than Construction Line Styler ? by Tig
