    [Plugin] ClineStyler v1.0 20110822
    13 Posts 11 Posters 11.6k Views 11 Watching
    • TIGT Online
      (c) TIG 2011
      Permission to use, copy, modify, and distribute this software for
      any purpose and without fee is hereby granted, provided the above
      copyright notice appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Script:
      clinestyler.rb
      Place it in the ../Plugins/ folder and restart Sketchup...
      Usage:
      If a selection includes Guide-Lines [clines] then there is a right-click
      context-menu item called 'ClineStyle...', which opens a drop-down list of
      possible cline-styles - choose one and those selected will now display in
      that style; you can revert to the default, which is also the '_' style but
      its code is 0 rather than 61680.
      Donations:
      by PayPal to info @ revitrev.orgPayPalButtonVersion:
      1.0 20110822 First Release.clinestyler.rb
      • srxS Offline
        srx
        Thank you TIG. πŸ˜„
        www.saurus.rs
          8 downloads and 1 thank you. 😞
          Anyway, thank you again for this. Nifty tool πŸ‘
          • 3 Offline
            3dsmax9
            Thank's TIG πŸ˜„
            Thank's TIG πŸ˜„
            Thank's TIG πŸ˜„
            Thank's TIG πŸ˜„
            Thank's TIG πŸ˜„
            Thank's TIG πŸ˜„
            Thank's TIG πŸ˜„
            Thank's TIG πŸ˜„
            8 download = 8 Thank's TIG πŸ˜„
              schnydix
              Thanks Tig but with my screen resolution i cant see the difference
              It is possible to make the Clines into Lines (for Printing)and stronger than 1Pixel
              An realy working dashed line tool would be very nice.
              And a Big Big Thank you for spending so much time in programming for us stupid users
              Google and sketchup special programmers like you and all other great guys here are like
              little Robin hoods for me. You gife as a tool that is much better and faster than very expensive
              Programms. πŸ‘
              • utilerU Offline
                utiler
                oops.... 😳 was directed here from another post and should have πŸ‘
                so here it is again, TIG. πŸ‘ πŸ‘
                Just Curious...
                • TIGT Online
                  little Robin hoods for me. You gife as a tool that is much better and faster than very expensive Programs. πŸ‘
                  I can't fix your screen resolution!
                  As long as Clines are not infinitely long you can use my tool 'xLine2Line.rb'
                  http://forums.sketchucation.com/viewtopic.php?p=274567#p274567
                  which converts selected lines to plain-lines.
                  Then you could use the LineStyle tool in my 2Dtools
                  http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                  to give the line a color/width/dot-dash pattern - remember that then it's no longer a 'line' so snapping etc is no longer possible. The ideas of this ClineStyler is to allow you to change the appearance of selected clines for ease of identification - e.g. center ... instead of ----- ; it's not intended for presentation line styles - where Layout or 2Dtools come in...
                    schnydix
                    Thanks Tiger fast and helpfull answer.
                    and yes i see there is a concept behind your works.
                    Respect from Switzerland
                      seven.sides
                      Thanks TIG. This should be useful for presenting architectural drawings.
                        matt.gordon320
                        Thanks TIG!
                        • H Offline
                          huija
                          thanks TIG!
                            Titan1286
                            TIG - Thanks!
                              Does this the same than Construction Line Styler ? by Tig
