    Entities.add_group bug?
    17 Posts 3 Posters 1.2k Views 3 Watching
      TIG: It's safe to group entities as long as they are in the same context, right? To move the face, why not group it, get it's definition, then place a new instance in the destination context and erase the old.
      Avoiding having to manually recreate the faces with its loops and UV mapping etc....
      • voljankoV Offline
        voljanko
        Can you give the code sample,please(how to group it).I would like to test it.
        SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        • voljankoV Offline
          voljanko
          It's working!!
          I cannot believe it.I have a theory that nothing can work without testing.You are breaking this theory 😄
            I always get uneasy when a code is run the first time without any errors... 😕 😒
            • TIGT Online
              It's only 100% safe to make a group directly with
              ents.add_group(an_entities_array)
              [or (an_entity)]
              if the 'ents' is the model.active_entities OR the same 'entities context'
              Doing it across a mix of 'entities contexts' can cause Bugsplats ???
              So then you normally make an empty group
              group=ents.add_group()
              and then add the entities to its group.entities; either by cloning raw geometry etc; or if it's a component, by using
              instance2=group.entities.add_instance(instance.definition, instance.transformation)
              or if it's a group, by using
              group2=group.entities.add_instance(group.entities.parent, group.transformation)
              If you are not immediately erasing the original 'group' then run group2.make_unique on the new group because, otherwise they as as if they are components - changing one changing one changes the other - behavior not expected in groups which ought to only ever have one instance of their definition.
              • TIGT Online
                If making a temp group of the face in situ works for you and you can then add an instance of that into another context and explode it and then erase the original face-group then that's good 😄 ... but if it splats you need to do it by 'cloning' 😞
                • voljankoV Offline
                  voljanko
                  Reading your code, the line
                  group.erase
                  makes me curious because the erase should be with the !.
                  So I discover that it was only half the code working.
                  But the result is ok.
                  So the working code is:
                  def move_face(face, destination_entities )
                    source_entities = face.parent.entities
                    entities = face.edges << face # I think you need to include all the edges related to the face
                    group = source_entities.add_group( entities )
                  So the untested code theory remains 😄
                  I will test it more,because of the Bugsplat fear.
                  • TIGT Online
                    You need to add the
                    ###... definition = group.entities.parent transformation = Geom::Transformation.new # Adjust to place where you want it. copy = destination_entities.add_instance( definition, transformation ) copy.explode # Ungroup the copied face group.erase**!** # Erase the original temp group
                    otherwise all your code does is move the face into a group that is in the in the same context the face was. I thought your aim was to move the face into another group ?
                    The method move_face( face, destination_entities ) takes the two arguments 'face' - the face to move; and 'destination_entities' - where you want it to end up - e.g. group2.entities...
                    Thomthom's clever face>group,add_instance,explode,delete_original idea should work in this set of circumstances, without recourse to cloning...Note that this method 'moves' the face, and leaves it un-grouped - just as it was originally but now within another entities-context - if you want to copy the face into a group then the code needs tweaking - instead of deleting the original face [that's been grouped] with group.erase! you use group.explode to return the original face to its un-grouped state.
                      <span class="syntaxdefault"><br />def move_face</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> destination_entities </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  source_entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />  entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> face </span><span class="syntaxcomment"># I think you need to include all the edges related to the face<br /></span><span class="syntaxdefault">  group </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> source_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> entities </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  definition </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent<br />  transformation </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">new </span><span class="syntaxcomment"># Adjust to place where you want it.<br /></span><span class="syntaxdefault">  copy </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> destination_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> definition</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> transformation </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  copy</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">explode </span><span class="syntaxcomment"># Ungroup the copied face<br /></span><span class="syntaxdefault">  group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Erase the original temp group<br /></span><span class="syntaxdefault">end<br /></span>
                      Note: completely un-tested. Just a theory
                      • voljankoV Offline
                        voljanko
                        Grrr,it is only working if the group is edited (so in the same context).
                        Otherwise strange behaviour and Bugsplat anytime. 😢
                        • TIGT Online
                          As I suspected then... 😒
                          Using ents.add_group(ent_array) only works safely if ents==model.active_entities
                          So use my cloning tips... 😕
