    Entities.add_group bug?
    17 Posts 3 Posters 1.1k Views 3 Watching
    • voljankoV Offline
      voljanko
      Thank you for the "line" example,I have try to "move" a face,but it is not working.
      group1=model.selection[0]
      e0=group1.entities[0] # a face
      group2=group1.entities.add_group()
      group2.entities.add_face(e0.edges)
      e0.erase!
      What's wrong?
      The error is : Edge has different parent
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
      • TIGT Online
        How do YOU know [magically?] that e0=group1.entities[0] is a face?
        I could just as easily be an edge that makes the face!
        To find a face inside the group you must do this...
        ` group1=model.selection[0]
        face=nil
        group1.entities.each{|e|face=e if e.class==Sketchup::Face}
        assumes only ONE face to find!
        face2=group2.entities.add_face(face.vertices)
        face.erase!It's more complex IF the face has more that one loop - i.e. a 'hole'. Then you use... oloop=face.outer_loop
        loops=face.loops-[oloop]
        loops.each{|loop|group2.entities.add_face(loop.vertices)}
        group2.entities.add_face(oloop.vertices)`
        THEN remove holes
        faces2go=[] group2.entities.each{|e|faces2go << e if e.class==Sketchup::Face and e.outer_loop.edges[0].faces[1]}
        faces[1] means it's a hole as it's outer edge abuts another face.
        group2.entities.erase_entities(faces2go)
        NOW you should have a clone of the original face with its holes
        face2=nil group2.entities.each{|e|face2=e if e.class==Sketchup::Face}
        IF face has materials, layer or attributes 'copy' them to the new face2
        then
        face.erase!
        The face has been replicated inside a nested group.
        Nothings that easy šŸ˜’
        • voljankoV Offline
          voljanko
          Uff,a lot of work for "moving" a face.And still needs the material and back material and soften edges...
          Almost easier to wait the Sketchup team to repair the Entities.add_group(other_entities) function šŸ˜„
          The ruby console confirmed it.It is only for testing.
            @tig said:
            face=nil group1.entities.each{|e|face=e if e.class==Sketchup::Face}
            Can be written as:
            face = group1.entities.find{|e|e.class==Sketchup::Face}
              TIG: It's safe to group entities as long as they are in the same context, right? To move the face, why not group it, get it's definition, then place a new instance in the destination context and erase the old.
              Avoiding having to manually recreate the faces with its loops and UV mapping etc....
              • voljankoV Offline
                voljanko
                Can you give the code sample,please(how to group it).I would like to test it.
                • voljankoV Offline
                  voljanko
                  It's working!!
                  I cannot believe it.I have a theory that nothing can work without testing.You are breaking this theory šŸ˜„
                    I always get uneasy when a code is run the first time without any errors... šŸ˜• šŸ˜’
                    • TIGT Online
                      It's only 100% safe to make a group directly with
                      ents.add_group(an_entities_array)
                      [or (an_entity)]
                      if the 'ents' is the model.active_entities OR the same 'entities context'
                      Doing it across a mix of 'entities contexts' can cause Bugsplats ???
                      So then you normally make an empty group
                      group=ents.add_group()
                      and then add the entities to its group.entities; either by cloning raw geometry etc; or if it's a component, by using
                      instance2=group.entities.add_instance(instance.definition, instance.transformation)
                      or if it's a group, by using
                      group2=group.entities.add_instance(group.entities.parent, group.transformation)
                      If you are not immediately erasing the original 'group' then run group2.make_unique on the new group because, otherwise they as as if they are components - changing one changing one changes the other - behavior not expected in groups which ought to only ever have one instance of their definition.
                      • TIGT Online
                        If making a temp group of the face in situ works for you and you can then add an instance of that into another context and explode it and then erase the original face-group then that's good šŸ˜„ ... but if it splats you need to do it by 'cloning' šŸ˜ž
                        • voljankoV Offline
                          voljanko
                          Reading your code, the line
                          group.erase
                          makes me curious because the erase should be with the !.
                          So I discover that it was only half the code working.
                          But the result is ok.
                          So the working code is:
                          def move_face(face, destination_entities )
                            source_entities = face.parent.entities
                            entities = face.edges << face # I think you need to include all the edges related to the face
                            group = source_entities.add_group( entities )
                          So the untested code theory remains šŸ˜„
                          I will test it more,because of the Bugsplat fear.
                          • TIGT Online
                            You need to add the
                            ###... definition = group.entities.parent transformation = Geom::Transformation.new # Adjust to place where you want it. copy = destination_entities.add_instance( definition, transformation ) copy.explode # Ungroup the copied face group.erase**!** # Erase the original temp group
                            otherwise all your code does is move the face into a group that is in the in the same context the face was. I thought your aim was to move the face into another group ?
                            The method move_face( face, destination_entities ) takes the two arguments 'face' - the face to move; and 'destination_entities' - where you want it to end up - e.g. group2.entities...
                            Thomthom's clever face>group,add_instance,explode,delete_original idea should work in this set of circumstances, without recourse to cloning...Note that this method 'moves' the face, and leaves it un-grouped - just as it was originally but now within another entities-context - if you want to copy the face into a group then the code needs tweaking - instead of deleting the original face [that's been grouped] with group.erase! you use group.explode to return the original face to its un-grouped state.
                              <span class="syntaxdefault"><br />defĀ move_face</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Ā face</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Ā destination_entitiesĀ </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">Ā Ā source_entitiesĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />Ā Ā entitiesĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edgesĀ </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault">Ā faceĀ </span><span class="syntaxcomment">#Ā IĀ thinkĀ youĀ needĀ toĀ includeĀ allĀ theĀ edgesĀ relatedĀ toĀ theĀ face<br /></span><span class="syntaxdefault">Ā Ā groupĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā source_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Ā entitiesĀ </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">Ā Ā definitionĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent<br />Ā Ā transformationĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">newĀ </span><span class="syntaxcomment">#Ā AdjustĀ toĀ placeĀ whereĀ youĀ wantĀ it.<br /></span><span class="syntaxdefault">Ā Ā copyĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā destination_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Ā definition</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Ā transformationĀ </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">Ā Ā copy</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">explodeĀ </span><span class="syntaxcomment">#Ā UngroupĀ theĀ copiedĀ face<br /></span><span class="syntaxdefault">Ā Ā group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!</span><span class="syntaxdefault">Ā </span><span class="syntaxcomment">#Ā EraseĀ theĀ originalĀ tempĀ group<br /></span><span class="syntaxdefault">end<br /></span>
                              Note: completely un-tested. Just a theory
                              • voljankoV Offline
                                voljanko
                                Grrr,it is only working if the group is edited (so in the same context).
                                Otherwise strange behaviour and Bugsplat anytime. 😢
                                • TIGT Online
                                  As I suspected then... šŸ˜’
                                  Using ents.add_group(ent_array) only works safely if ents==model.active_entities
                                  So use my cloning tips... šŸ˜•
                                  With your input, this post could be even better šŸ’—
