    OnTransactionStart/Commit oddities?
    29 Posts 5 Posters 2.1k Views 5 Watching
      However, this didn't work as expected under SU 6.4.265
      Sketchup.active_model.start_operation('test')
      -onTransactionStart:#Sketchup::Model:0x10c1f660
      onTransactionCommit:#Sketchup::Model:0x10c1f660
      true
      Sketchup.active_model.active_entities.add_cpoint [10,10,10]
      #<Sketchup::ConstructionPoint:0x10c1bdf0>
      Sketchup.active_model.active_entities.add_cpoint [20,10,10]
      #<Sketchup::ConstructionPoint:0x10c1bb20>
      Sketchup.active_model.commit_operation
      true
      • Dan RathbunD Offline
        Dan Rathbun
        So this is perhaps why the poster, over at GG was having problems ??
        GoogleGroup: "transaction model question"
        Would my idea of a "manual" callback be a valid workaround ?? (If not as I've shown, perhaps moving the call after the commit call?)
        I'm not here much anymore.
          I was trying to use the observer because I wanted to catch any actions performed while my tool is active. It draws a UI based on the model geometry so I need to refresh when the geometry changes. And I wanted to catch events where a custom action from outside my plugin was triggered.
            Dan Rathbun
            Does the disable_ui flag have any difference in the effect ??
            Also.. I wonder about the transparency flags.
            But it does seem like a bug. We would want them to trigger only once, per operation, per model.
              Dan Rathbun
              @thomthom said:
              ... I wanted to catch any actions performed while my tool is active. ...
              And that stickin' ToolsObserver still will not fire for Ruby tools, right?
                I tried both. Same results.
                onActiveToolChanged triggers, but not onToolStateChanged.
                Besides, many actions are not triggered by a tool.
                Once more I seem stomped by observers. I swear, they'll be the bane of me.
                  Dan Rathbun
                  As I remember, onActiveToolChanged didn't give us any useful data.
                  The tool_id just says 50000 (or similar,) for ANY Ruby tool, and "RubyTool" for the tool_name.
                  I wish they would fix this...
                  I suppose the built-in Standard Ruby Observer class won't work ether huh?
                    Some 'transparent' tools like Zoom or Pan don't trigger.
                    Other native-tools do trigger... BUT some have names not exactly equivalent to what you might expect.
                    Plugin tools all return the same value/name !
                      I can't find any combination of methods or observers that will let me know reliably when an operation has been committed.
                      Guess it time to brush the dust of that old State of Observers list again...
                        Dan Rathbun
                        You want the Start of the OP, and the finish of the OP ??
                          ...onChange half-works, ...onCommit doesn't ?
                            I want to catch the commit of an operation so I know I can rebuild the geometry cache I use to draw my tool's UI.
                              Dan Rathbun
                              OK, so are you the one writing the operation ?? or is this one of Sketchup's normal undo operations ?
                              • Chris FullmerC Offline
                                Bummer Thom, I just played with the oncommitaction observer yesterday for the first time and I did not encounter any oddities, but I did not test it more than just drawing a few lines.
                                  I want to catch any operation. By me, by other plugins, by SU's native commands. I'm writing a custom Select tool and therefor any operation might occur while the tool is active - and I need to know when it does.
                                    Did you draw a few lines between start/commit_operation ? and the observers triggered only once?
                                      I didn't attach a startaction observer. I only cared about actions finishing. And in the end I decided I really wanted to watch for entities being added to the model, so I moved away quickly from the transaction observers.
                                        Yea, its the completion of an operation I'm interested in as well. It's just that I noticed it mis-triggers just like the end does.
                                        But do you want to be notified for each entity being created - before the operation has fully completed?
                                          Ugh! The only workaround I can find at the moment is a nasty filthy timer hack.
                                          <span class="syntaxdefault"><br />class ToolModelObserver </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ModelObserver<br />    <br />    def initialize</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> tool </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tool </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> tool<br />      </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">delay </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0<br />    end<br />    <br />    def onTransactionStart</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#puts 'onTransactionStart'<br /></span><span class="syntaxdefault">      UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">delay </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />    <br />    def onTransactionCommit</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#puts 'onTransactionCommit'<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#@tool.onModelChange( model )<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># (!) onTransactionStart and onTransactionCommit mistriggers between<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#     model.start/commit_operation.<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># Because of this its impossible to know when an operation has completed.<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># Executing the cache on each change will slow everything down.<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># For now a very ugly timer hack is used to delay the trigger. It's nasty,<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># filthy and only works in SU8.0+ as UI.start_timer was bugged in earlier<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># versions.<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># Simple tests indicate that the delayed event triggers correctly with the<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># timer set to 0.0 - so it might work even with older versions. But more<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># testing is needed to see if it is reliable and doesn't allow for the<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># delayed event to trigger in mid-operation and slow things down.<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># Since the event only trigger reading of geometry the only side-effect of<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment"># a mistrigger would be a slowdown.<br /></span><span class="syntaxdefault">      UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">delay </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">delay </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 0.001</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">        </span><span class="syntaxcomment">#puts 'Delayed onTransactionCommit'<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;Just&nbsp;to&nbsp;be&nbsp;safe&nbsp;in&nbsp;case&nbsp;of&nbsp;any&nbsp;modal&nbsp;windows&nbsp;being&nbsp;popped&nbsp;up&nbsp;due&nbsp;to<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;the&nbsp;called&nbsp;method&nbsp;the&nbsp;timer&nbsp;is&nbsp;killed.&nbsp;SU&nbsp;doesn't&nbsp;kill&nbsp;the&nbsp;timer&nbsp;until<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;the&nbsp;block&nbsp;has&nbsp;completed&nbsp;so&nbsp;a&nbsp;modal&nbsp;window&nbsp;will&nbsp;make&nbsp;the&nbsp;timer&nbsp;repeat.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(&nbsp;@</span><span class="syntaxdefault">delay&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tool</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">onModelChange</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">invalidate<br />      </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    end<br />    <br />    def onTransactionUndo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#puts 'onTransactionUndo'<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tool</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">onModelChange</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />    <br />    def onTransactionRedo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#puts 'onTransactionRedo'<br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">tool</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">onModelChange</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    end<br />    <br />  end </span><span class="syntaxcomment"># class ToolModelObserver<br /></span><span class="syntaxdefault"> </span>
                                          I don't like it, in fact, I hate it. It opens up for worms. But so far it seem to kind of work.
                                          I'd be happy for a cleaner workaround.
                                          • scottliningerS Offline
                                            scottlininger
                                            Hey Thomthom,
                                            In general, the Observers all work at the core Sketchup level, not at the API level, so you'll get a mess of events that are created from SketchUp's internal messaging mechanism, often in ways that appear bizarre from the outside. When we first started putting Observers into the product we knew that they'd be hard to work with in some cases, and you've delved into a complex example.
                                            I wish I had a simpler one to offer, but I think your timer method looks like a reliable workaround.
                                            • Scott Lininger
                                              SketchUp Software Engineer
                                              Have you visited the Ruby API Docs?
