    OnTransactionStart/Commit oddities?
    29 Posts 5 Posters 2.7k Views 5 Watching
      I was trying to use the onTransactionStart and onTransactionCommit event from the ModelObserver - thinking they would trigger upon model.start_operation and model.commit_operation. But it seems they trigger for every model modification within the start/commit_operation. Though, the operations all get wrapped neatly within one undo/redo operation.
      Does anyone else see this? Or is it just me? Did it always work like this?
        Test with plain SU8 installation - using Jim's observer test suite:
        (One Face with four edges in model)
        attaching #<ObserverTests::ModelObserver:0xb06051c> to #<Sketchup::Model:0xb06128c>
        Activate Move
        Initial Click
        -onTransactionStart:#<Sketchup::Model:0xb06128c>
        Move Cursor
        Second Click
        onTransactionCommit:#<Sketchup::Model:0xb06128c> -onTransactionStart:#<Sketchup::Model:0xb06128c> onTransactionCommit:#<Sketchup::Model:0xb06128c> -onTransactionStart:#<Sketchup::Model:0xb06128c> onTransactionCommit:#<Sketchup::Model:0xb06128c> -onTransactionStart:#<Sketchup::Model:0xb06128c> onTransactionCommit:#<Sketchup::Model:0xb06128c>
        Expected result would be just one onTransactionStart and onTransactionCommit.
        I really thought the ModelObserver could be used to detect the start and end of an undoable operation. But it seem to trigger as often as the EntitiesObserver.
          Tested in SU 7.1.6860 : Same as SU8
          Tested in SU 6.4.265 : Works as expected! One onTransactionStart and one onTransactionCommit
          This looks to be a regression bug. 😞
          One that's turning out to be very troublesome...
            However, this didn't work as expected under SU 6.4.265
            Sketchup.active_model.start_operation('test')
            -onTransactionStart:#Sketchup::Model:0x10c1f660
            onTransactionCommit:#Sketchup::Model:0x10c1f660
            true
            Sketchup.active_model.active_entities.add_cpoint [10,10,10]
            #<Sketchup::ConstructionPoint:0x10c1bdf0>
            Sketchup.active_model.active_entities.add_cpoint [20,10,10]
            #<Sketchup::ConstructionPoint:0x10c1bb20>
            Sketchup.active_model.commit_operation
            true
            • Dan RathbunD
              Dan Rathbun
              So this is perhaps why the poster, over at GG was having problems ??
              GoogleGroup: "transaction model question"
              Would my idea of a "manual" callback be a valid workaround ?? (If not as I've shown, perhaps moving the call after the commit call?)
              I'm not here much anymore.
                I was trying to use the observer because I wanted to catch any actions performed while my tool is active. It draws a UI based on the model geometry so I need to refresh when the geometry changes. And I wanted to catch events where a custom action from outside my plugin was triggered.
                • Dan RathbunD
                  Dan Rathbun
                  Does the disable_ui flag have any difference in the effect ??
                  Also.. I wonder about the transparency flags.
                  But it does seem like a bug. We would want them to trigger only once, per operation, per model.
                  • Dan RathbunD
                    Dan Rathbun
                    @thomthom said:
                    ... I wanted to catch any actions performed while my tool is active. ...
                    And that stickin' ToolsObserver still will not fire for Ruby tools, right?
                      I tried both. Same results.
                      onActiveToolChanged triggers, but not onToolStateChanged.
                      Besides, many actions are not triggered by a tool.
                      Once more I seem stomped by observers. I swear, they'll be the bane of me.
                      • Dan RathbunD
                        Dan Rathbun
                        As I remember, onActiveToolChanged didn't give us any useful data.
                        The tool_id just says 50000 (or similar,) for ANY Ruby tool, and "RubyTool" for the tool_name.
                        I wish they would fix this...
                        I suppose the built-in Standard Ruby Observer class won't work ether huh?
                          Some 'transparent' tools like Zoom or Pan don't trigger.
                          Other native-tools do trigger... BUT some have names not exactly equivalent to what you might expect.
                          Plugin tools all return the same value/name !
                            I can't find any combination of methods or observers that will let me know reliably when an operation has been committed.
                            Guess it time to brush the dust of that old State of Observers list again...
                            • Dan RathbunD
                              Dan Rathbun
                              You want the Start of the OP, and the finish of the OP ??
                                ...onChange half-works, ...onCommit doesn't ?
                                  I want to catch the commit of an operation so I know I can rebuild the geometry cache I use to draw my tool's UI.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    OK, so are you the one writing the operation ?? or is this one of Sketchup's normal undo operations ?
                                    • Chris FullmerC
                                      Bummer Thom, I just played with the oncommitaction observer yesterday for the first time and I did not encounter any oddities, but I did not test it more than just drawing a few lines.
                                        I want to catch any operation. By me, by other plugins, by SU's native commands. I'm writing a custom Select tool and therefor any operation might occur while the tool is active - and I need to know when it does.
                                          Did you draw a few lines between start/commit_operation ? and the observers triggered only once?
                                          • Chris FullmerC
                                            I didn't attach a startaction observer. I only cared about actions finishing. And in the end I decided I really wanted to watch for entities being added to the model, so I moved away quickly from the transaction observers.
