    [Plugin] CleanUp
    974 Posts 217 Posters 834.1k Views 217 Watching
      bitslapped
      Hi thomthom I noticed you have a new 'merge identical materials' which seems like you had a crack at my request?! Thanks for that.
      I have been getting the same errors particularly when I run the cleanup with only 'merge identical materials' checked.
      The script still works for older functions.
      I'm running sketchup 8 and your latest libraries.
      Cheers
        Got a sample model?
          SpookyChick1013
          Sorry to take so long getting back here. Was out of town and off grid for a few days.
          Anyway, the errors only show up when I am actually running the script, after checking settings and clicking "CleanUp". I am using your latest library, and Sketchhup 7.1, as always. The error has occurred with every model to this point.
          The settings that I have observed the problem occurring with.  If I UN-check Merge Identical Materials, Cleanup works fine.
          Late Edit: Something bitslapped said got me thinking, and so I UNchecked "Merge Identical Materials". When I ran CleanUp with MergeIdenticalMaterials NOT checked, Cleanup ran fine; So I am wondering at this point if the problem is with that part of the plugin.
          https://kuromatsudriveyards.com
          Fo-su to tomo ni aran koto o...
            driven
            hi Thomas,
            i'm getting path errors in safari
            Not allowed to load local resource:file:///Library/Application%20Support/Google%20SketchUp%208/SketchUp/Plugins/TT_Lib2/webdialog/css/ui.css
            note: I can run selection toy WD with it's path
            <script type="text/javascript" src="js/base.js"></script>
            I can't fathom your interface enough to switch paths...
            has anyone had it [cleanup3] all working on a mac? [I am using the dev version of safari]
            cheers
              I'll have a look next week. But are you sure you have the very latest CleanUp and TT_Lib?
                @driven said:
                hi Thomas,
                cheers
                I got a mac at home I test on - CleanUp should work.
                ...what OSX version do you have?
                  Can you post a screenshot of this error? When does it appear?
                    driven
                    I'm still on 10.5.8, but safari 5.0.6 is the pre-release for the next safari and it stops Fredo's updater from checking here for updates, but I haven't had any local file errors from anything else, and sellectionToys works...
                    dev version of safari 5.0.6 is stricter
                    EDIT: checked on my macbook and it's OK for now...
                    The dev version of safari is a preview for safari 6, so soon everyone will have this issue...
                    is it possible to use the same paths as selection toys, because they work on both.
                    BTW... I modded the ui.css for nicer IMHO mac scrollbars
                    safari 5.0.3 on macbook OSX10.5.8
                      SpookyChick1013
                      Yeah. I wondered myself if I really had DL'ed and installed it, but I do have it. Freshly downloaded and installed, just to see if that would fix the problem. Seems to have cropped up since I originally updated to this latest version.
                        Driven: I have no idea why it says it is not allowed to load any local resource... I hope it's a bug in that beta version.
                        (btw - how did you edit the mac scrollbars? I thought only IE allowed that to be changed...)
                        Spooky & Driven: I won't be able to look into this until next week - when my vacation is over.
                          driven
                          just did some checking and it's not a bug or a beta,
                          it's now the current update with new security 'features'...
                          5.0.6 for Leopard or 5.1 for Snow and Lion,
                          anyone with auto update will already have this as well, there are no changes since the pre-release...
                          Webkit psuedo elements, here's a link with detailshttp://css-tricks.com/9130-custom-scrollbars-in-webkit/
                          I did a close[ish] match for Selection Toys
                          by dropping this into ui.css
                          ;;-webkit-scrollbar
                              width; 12px;
                           ;;-webkit-scrollbar-thumb
                              background; rgba(255, 255, 255, .25);
                              border; solid 1px rgba(0, 0, 0, .25);
                          ;;-webkit-scrollbar-thumb;vertical,{
                          ;;-webkit-scrollbar-thumb;hover
                             background-color; rgba(0, 255, 0, .25);
                          ;;-webkit-scrollbar-track-piece
                              background; rgba(0, 0, 0, .05);
                              border;none;
                              border-left; solid 1px rgba(255, 255, 255, .1);
                          ;;-webkit-scrollbar-corner
                              display; none;
                          for Cleanup I just dropped in the version I use as a Safari alternate CSS,
                          /* blendin mods */
                          ;;-webkit-scrollbar
                              width; .5em;
                              height; .5em;
                              background;  transparent;
                              -webkit-border-radius; 1em;
                              border; solid 1px rgba(0, 0, 0, .05);
                              background; -webkit-gradient(linear, left top, left bottom, from(rgba(255, 255, 255, .25)), to(rgba(0, 0, 0, .25)));
                          background-color; rgba(0, 255, 0, .5);
                          ;;-webkit-scrollbar-button;start;decrement, ;;-webkit-scrollbar-button;end;increment
                              display; block;
                              height; .5em;
                              width; .5em;
                              display; block;
                              margin; .5em;
                              display; none;
                          /* end of blendin mods */
                          you can set them here for Safari, WebDialogs need the css includedon all websites, iFrames can be flakey...
                          have a good vacation
                            Ah pooh! Cursed - now I got to dig into this new ... thing - whatever it is. Thanks for reporting though.
                            And thanks for the webkit CSS tip. πŸ‘ πŸ‘
                            • Rich O BrienR Online
                              Something's up with this .skp?
                              uninitialized constant TT;;Sketchup
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;456;in `cleanup!'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;442;in `show_cleanup_ui'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;161;in `call'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;161;in `initialize'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `call'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `close'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `initialize'
                              TT_CleanUp_Error.skp
                                Actually getting this on any file?
                                  Yer CleanUp is out of date!
                                    Yer dead right πŸ‘
                                    I'd forgotten I'd updated TT_Lib2 with Quad Tools. My bad.
                                      Ye!
                                      • W Offline
                                        wrc86
                                        http://img580.imageshack.us/img580/8752/capturadepantalla201108ft.th.png
                                        it's not working for me, it doesn't show any error when I start SU
                                        It just to work with my old OS, now I'm working with OS X LION
                                          hm... not sure what it could be. with no error message at all.
                                          can you open the Ruby Console before you try to use CleanUp and see if you get any messages there?
                                            Sakika
                                            This might be a "stupid" question, but how do i install this plugin on sketchup? Because it is an .rb file and i dont know what program to open it?!
                                            Thanks,
                                            Sakika
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 48
                                            • 49
                                            • 20 / 49
