    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 41.4k Views 23 Watching
    • N Offline
      notareal
      Thea Render v1.0.8 Revision 486 is available at the Thea development forums.
      This revision has also 2 major improvements.
      First is the improved sampling of diffuse and rough glossy surface in the presence of IBL for Adaptive BSD method. Especially, when the lighting in the IBL has a lot of variation.
      Second, a big workflow improvement has been added. We can now save Sky/IBL/Sun settings with a few clicks and easily apply them later in another scene. This way, you can easily now create your sky libraries (including your sun settings) and restore them with a simple drag & drop in the Viewport.
      Changes Log
      Thea Render v1.0.8 Revision 486 (30 March 11)
      • Fix for evaluation of grayscale non-power-of-2 bitmaps (bug introduced in previous public revision RV481). (all engines)
      • Hemisphere gizmo in OpenGL Viewport displaying HDRI is now independent of IBL intensity. (UI)
      • Added ability to save sky settings (through browser context menu) and restore by simple drag & drop into Viewport. (UI-I/O)
      • Browser icons have now 3 sizes (the previous 2 plus a higher resolution 150x150). Scene previews are also saved now in (higher) 150x150 resolution. (UI)
      • Corrected renaming and removal of IES files in browser. (UI)
      • Fixed chromaticity for sky previews and hemisphere gizmo. (UI)
      • Building of adaptive bitmap resolutions (for trilinear interpolation) is now taking place on demand (it is used only by Adaptive BSD). (memory management)
      • Some code refactoring with respect to resources. (refactoring).
      • Addition of secondary browser in studio, it can be accessed from Window > Browser #2. (UI)
      • Fixed minor bug where interpolation of HDR bitmaps was used as None despite having set to Bilinear/Trilinear. (all engines)
      • Vast improvement of diffuse and rough reflection sampling in the presence of IBL. (Adaptive BSD)
      • Added ability to save and restore backup files. (I/O)
      • Added automation for materials set selected ones to default min and max blurred subdivs. (UI)
      • Added Planar and Charles-Loop subdivision methods. (modeling)
      • Corrected tone mapping operations when used for bump mapping. (all engines)
      • Added ability to draw in OpenGL Viewport with full triangulation, key '' is the default one. (UI)
      • Fixed min/max emitter rays taken correctly into account now by direct light estimator. (Adaptive BSD)
      • Fixed render region brightness when Progressive (BSD) is used in darkroom rendering. (Progressive BSD)
      • Fixed peculiar crash when saving scene. (I/O)
      • Corrected time stamping of signed installers. (Windows/Installation)
      • N Offline
        notareal
        Thea Render Revision 491 is available at the development forum.
        Thea is now improved in terms of noise when it comes to IBL lighting with Reflection and/or Refraction maps defined. Affecting both, the unbiased core as well as Adaptive BSD.
        Another important addition in this revision is network rendering for Adaptive BSD! This works for still images (like unbiased modes) in a bucket rendering fashion.
        • N Offline
          notareal
          Technology Preview of Luminance/Illuminance Analysis
          We are very happy to announce that Luminance/Illuminance Analysis has
          been added in Thea render. Analysis can be saved as a html report.
          Feature will be available with the next public revision.
          Luminance analysis for a penthhouse (modeling by Claudio Pilustrelli).
          Corresponding report.
          • N Offline
            notareal
            Thea Render Revision 504 with luminance and illuminance analysis is now available at the developement forums. A minitutorial for analysis is included in the revision annousement post.
            The revision contains also some Adaptive BSD enchangements and fixes; rendering animation through the network has also been implemented.
            • N Offline
              notareal
              A little heads up and technology preview of next Thea Render release:
              Dear friends,
              you know we are working hard "behind the scenes" to get the most out of Thea Render. And we are taking the opportunity, this summer period, to advance Thea to the next level. During the last weeks, we have worked on the core of the application and succeeded into achieving a remarkable speed boost that makes Thea up to 2 times faster!
              In more detail about our achievement:
              • Render times are now decreased between 25% and 50%. This is true for all render modes although it is much more obvious for the unbiased modes TR1/TR2 - BSD shows a speed increase as well but depends more on the scene.
              • Construction of the environment (during initialization) is now multi-threaded. This means faster render startup and a more fluid interactive render!
              • There is a reduced memory footprint now - estimated between 10-20%, that makes it possible to render even heavier scenes.
              • The improvement is even more pronounced for heavily instanced scenes (with speed ups between 2x and 5x!) - a particular example can be seen below. The scenes that use displacement on the other hand show marginal improvement since displacement-on-the-fly is a different process to optimize.
              We are sure you are going to love our new version. We are continuously working on various improvements and advances, so we believe next public revision will be an important milestone for us. Stay tuned!
              best wishes
              Instancing_107_billion_polys_i7_920_6GB_TR1_1h_small.pngOriginal render. A heavy instancing scene rendered with our latest internal Thea Render x64 version. Scene created by Pentti LahdenperΓ€ using Thea's instancing tool.
              • soloS Offline
                Holy sh*t!! 107 billion poly's 😲
                That must be a record of some sort.
                • N Offline
                  notareal
                  Exactly 107642197634 polys, but basically the available memory is only limiting factor if you with 64-bit OS πŸ˜„
                  • soloS Offline
                    So, I have pretty much the same comp specs as you, however I have 12GB ram, I should in theory be able to get 200 billion polys? πŸ’š
                    • N Offline
                      notareal
                      Yes, something like that. Naturally there are other factors that can affect; like relight, render resolution, displacement or some unreleased feature
                      http://www.thearender.com/forum/images/smilies/icon_shh.gif
                      • soloS Offline
                        Not to worry I'm good at that.
                          Damn you guys, keep your secrets silently, not hinting stuff here! 😑
                            πŸŽ‰
                            I'll keep fingers crossed on GPU
                            • N Offline
                              notareal
                              :bounce:
                              GPU support is on the way (no date available yet), unfortunately it will take some time until they are ready for such massive use of RAM, that next version is ready for.
                                I was just fishing for info. Looks like I'll have to wait for September or get on the beta πŸ˜‰
                                • soloS Offline
                                  Wow, Thea instancing is smooth now, here is a quick test 21 million polys only (could have done 10 x this but there was no need)
                                  Xfrog trees (heavy poly)
                                  http://img195.imageshack.us/img195/6465/theatrees.jpg
                                  • PixeroP Offline
                                    Pixero
                                    πŸ˜„
                                    With "smooth" do you mean navigation in the Thea viewport with a lot of instances?
                                    • soloS Offline
                                      Yes, interactive (realtime) smooth.
                                      • Bob JamesB Offline
                                        Bob James
                                        This shameless teasing is just plain cruel, Peter πŸ˜†
                                        You know that my project production holdup is having to put very dense weeds, bushes and trees on a Google Earth topography of about 2 sq. miles of sloping and mountainous terrain πŸ˜’
                                        With my 32GB of ram and 24 cores of CPU, version 1.1 will finally allow me to finish the project.
                                        You couldn't Dropbox me a beta could you? 😎 πŸ˜„
                                          patrickbateman
                                          Thea looks really over my head and I have very little idea how to use it but I am intrigued. 3D modeling is incredibly addicting and ever since I got my hands on some evermotion plant collection demos I have wanted to find a way to use them.
                                          I am really loving sketchup and for landscape architecture the only thing I'm disappointed with is limited plants when there is some crazy high poly stuff out there I have wanted to use. I am used to podium one click rendering so this is intimidating.
                                          Are there tutorials and things I can look at to get started? How can I integrate thea into my sketchup workflow where I do most modeling in sketchup then plants in thea? I'm not really sure how it works and how much more time I am looking at compared to something like podium or shaderlight. I am probably going to end up using both and looking into the thea route for high profile presentations. How does thea handle grass? I really just have no idea what I'm getting into here and appreciate any help/patience.
                                          • soloS Offline
                                            I saw your thread regarding Podium but chose not to say anything, however now that you are looking at Thea let me say this:
                                            Unlike most render apps Thea is studio based so you are not limited to Sketchup's crappy poly limits.
                                            Add as much trees as you wish in Thea.
                                            Thea is both biased and unbiased, but lets not get you confused right now, why not download the free version, watch the videos and see if it's for you.
                                            Thea is not really a entry level app, Podium and Shaderlight are, so maybe learn with them, until you require more control, bells and whistles then look at Thea. I used Podium for many years before moving to Vray and finally to Thea as I wanted to get more realism and control over my renders.
                                            • 4 / 8
