    Reference photos for 'match photo' practice
    8 Posts 4 Posters 545 Views 4 Watching
      Artistram3d1
      Hello everyone
      At the risk of sounding like a complete noob (which I am)
      where can I find photos for practicing 'match photo' work?
      I've already searched the web, but couldn't find any
      that would meet the proper criteria, i.e.: proper angle showing
      both front/side, no cropping, nothing obscuring view from the
      front, etc.
      Thanks for your help!
      Rama
        I suppose taking a few pictures yourself of a building you're familiar with is the best approach. That way you're sure you've everything you need to practice with.
        • HieruH Offline
          Hieru
          I often use www.contemporist.com as a source of architectural inspiration. www.archdaily.com & www.homedsgn.com can be pretty good as well.
          The quality of photography is usually very high and I've saved quite a few image sets for future use on projects where I will possibly use SU's photomatch.
          www.davidhier.co.uk
            Be careful with those and PhotoMatch. They are typically those "architecture" photos with shift lenses - look at the verticals; they are all verticals and I suspect that many of them were made artificially verticals - i.e. no real, "original" perspective in them.
            Then almost certainly all are cropped for more artistic presentation - which is particularly not suggested when using PM.
            Great images but "just" images (from this point of view)
            • HieruH Offline
              Hieru
              To get around shift lens issue you can reintroduce converging verticals using an image editor and then use photomatch. It takes a bit of guesswork and fine tuning, but you can get good results. That's the approach I used here:
              www.davidhier.co.uk
                Nice πŸ‘
                  Nice πŸ‘
                  Indeed. πŸ‘ πŸ‘
                  • HieruH Offline
                    Hieru
                    Thanks guys πŸ‘
                    I haven't used the technique much, but imagine it will work in most circumstances.
                    www.davidhier.co.uk
