    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 240.6k Views 41 Watching
    • jolranJ Offline
      jolran
      Anyway heres how I implemented your code, between ents erase(facestogo) and intersection. It does not work on faces with holes, as mentioned.
      Is there a clash with 2 pt.clones? Maybe I HAVE put your code in wrong places. I will continue..
      bb=face.bounds
            di=bb.diagonal
             pt=face.vertices[0].position
              p1=pt.clone
           if face.normal.x.abs>0.9999
            p1.y=p1.y+1
           else
            p1.x=p1.x+1
           end#if
            p1=p1.project_to_plane(face.plane)
             ve=pt.vector_to(p1)
              po=pt.clone
            tr=Geom;;Transformation.rotation(pt,face.normal,@angle.degrees)
             vp=ve.transform(tr)
              vp.length=di*2
               vs=face.normal.cross(vp) #spacing vector perpendicular to hatch line
               tot=0
            until tot>=di*2
              ps=pt.offset(vp)
               pe=pt.offset(vp.reverse)
                gents.add_line(ps,pe)
                 pt.offset!(vs,spacing)
                  ps=po.offset(vp)
                 pe=po.offset(vp.reverse)
               po.offset!(vs.reverse,spacing)
              tot=
      • jolranJ Offline
        jolran
        May have found something? Commented out the last parts. Line hatching and intersection.
        The results of faces with holes is a group(clone) with reversed face? Faces without holes is created as expected.
        Since using face.normal that might (in my theory logic) pose some trouble?
        Updated Hmmm, no. Grr. Did not matter if faces was reversed or not. Problem remains..
        This code reverses the faces anyway.
        Could be useful later on, but it will reverse ALL faces, wich is not useful right now. Faces without holes do not need reversing.
        faces2=[]
              gents.each{|e|faces2 << e.reverse! if e.class==Sketchup;;Face
        • TIGT Online
          Perhaps instead of pt=face.vertices[0].position it might be better to use pt=face.outer_loop.vertices[0].position
          • jolranJ Offline
            jolran
            It does not work 😞
            However i noticed that "face" entity gets erased after erase(facestogo) if it has holes in it. Not if it's a square for ex!
            I used puts face after loop face erasing..
            So do face.plane have something to refere to when there are holes? Or is the variabel set earlier?
            • TIGT Online
              Erase the faces after you've set the points/vector etc - you can't get the plane or normal of an erased face!
              • jolranJ Offline
                jolran
                AHA!!
                So even if I am stupid enough to make that misstake, I noticed that in fact that was the error going on?
                I'm making progress!! πŸ˜„
                Thanks TIG. I will try to fix it.
                • jolranJ Offline
                  jolran
                  The "earliest" place where I can insert gents.erase_entities(faces2go) without erasing the access to face.plane is:
                         vp=ve.transform(tr)
                          vp.length=di*2
                  The result is not correct. Missing edges and too short.
                  Is face.plane or any command referring to "face" using the inner-hole faces, perhaps?
                  Should one use gents.entities.face(or something to retrieve the face.entity in gents) instead of just face?
                  • TIGT Online
                    You can set variables plane=face.plane and normal=face.normal and pt=face.outer_loop.vertices[0].position, then face.erase! - the variables are still remembered... then use them later as needed ?
                    • jolranJ Offline
                      jolran
                      Ok. You mean before faces2go << face? After erase.faces2goI was going to define the
                      linehatching as a method for crosshatching, as we discussed earlier. They will have to be instance.variables then or do I pass all of them into the argument-list when calling the method?
                      That's why I was wondering if one could use face from gents.entities, since gents will be passed into the args-list anyway.
                      Or did you originaly mean I should put the whole operation into a method for crosshatching?
                      I'm sorry if I sound confused. 😳 But I am.
                      • TIGT Online
                        All this part is trying to do is set the vector from which you will set the angle for the hatching.
                        At the moment it's set from the vertices [0] to [1] vector which varies, so to fix it I suggested a way of projecting the x-axis onto the face.plane and getting a vector from that to use instead [with changes for a plane that doesn't play nicely with the x-axis to give a valid vector...
                        You get all of this from the original face NOT the temporary face ??
                        • jolranJ Offline
                          jolran
                          You get all of this from the original face NOT the temporary face!
                          Yes, that part I understand(hopefully) what it was about to fix for problems.
                          However when you said I can't get the plane or normal of an erased face, I thought
                          order matters. I think my english is a bit bad, I don't understand everything right away. Apologize for that.
                          Lets say I use ORIGINAL "face" for face plane, I still must pass "face" on in the argument-list if I am going to
                          have following script setup, wich will be needed for crosshatching later on, no?
                          Feels like I'm doing some fundamential misstake here.
                          (edited)It should be "face" in the argument list. NOT faces.
                          • jolranJ Offline
                            jolran
                            Think I got! @face=gents.add_face etc..in tha Face creating-part And use @ varibles in the code below seams to do the trick!
                            It works on holes anyway. Don't know how kosher that is TIG? It would get into the linehatching method.
                            • jolranJ Offline
                              jolran
                              Works with holes..
                              • TIGT Online
                                It seems to work now πŸ˜„ - is the angle always more logically oriented to an axis rather than an edge of the face ??
                                As @face is a reference to a face before you run hatch and you erase it afterwards you don't really need to pass [@]face as an argument because @face is an instance variable read across methods, but if you do it'll probably still work... πŸ˜‰
                                Also you [mistakenly] show a space in the def name AND started it with CAPITAL letter - use 'linehatch' or 'lineHatch' or simply 'hatch' or even 'make_hatching' etc which are all just fine... call it with self.hatch(aa, bb, cc) or whatever it's called...
                                Use a @xxx variable where you want to use it across several methods [def's]
                                Pass arguments to a method when you want to reuse the method with changes to arguments without using @xxx as you want to keep that for later - e.g. the @angle etc IS reused next time you use the dialog so when you pass angle again you use @cangle for the crosshatching angle but want to use the same method again... πŸ€“
                                • jolranJ Offline
                                  jolran
                                  Thanks for all your help and advice TIG!
                                  I will follow them.
                                  Don't know πŸ˜„
                                  So I'll update the plugin then? All OK?
                                  Will work on the crosshatching later. I think it is a good idea to get this fix out, so people can use this plugin
                                  more properly.
                                  This coding-testing burns more calories than a 2hours jogging in the forest πŸ˜„
                                  • TIGT Online
                                    Test it on a cube's faces and a copy/copies of that cube rotated oddly in 3d to see what the hatching angles look like ??
                                    • jolranJ Offline
                                      jolran
                                      Crap! It always hatches in the axis. Doesent matter if the cube is rotated or not.
                                      OK. for tomorrow then... sigh... I hope you will come to the rescue again πŸ˜„
                                      I'm guessing -transformation to axis something?
                                      I will never get to experiment with NEW features!!!
                                      It put the ver 1.4 update up anyway. Think it's better than it was before.
                                        sergey2402
                                        It's just great!
                                        I see - this is a very difficult job.
                                        But now I am a real bad guy. I see only flaws! πŸ˜•
                                        (I’m sorry 😳 )
                                        • jolranJ Offline
                                          jolran
                                          Sergey. No need to feel bad. It's good if you report anything suspicious. β˜€
                                          The hatchgroup is created on Hatchlayer. The edges are created on the "active" layer.If you want ALL hatchline-geometry on "Hatchlayer". Just create one hatch(to add the hatchlayer). Delete it.
                                          Select Hatchlayer as active layer, then ALL lines will get to that layer.
                                          If we go back to the problem with hatchline alignment. Yesterday's update (TIG code)fixed the problem with ngons or to call it "asymmetrical" faces .
                                          I thought about this. I think the best solution(if doable) would be to do an additional edge selection.
                                          Where hatches get aligned to that edge. Something like if selection.contains edge, the vector will be created from that edge and override current solution. Eg if only face is selected hacthing will be done as current "on axis solution".
                                          I do not think this problem can be solved by an automatical solution(hope I'm wrong), cause faces can be created in so many different shapes. What edge should hatching be aligned to and so on..
                                            sergey2402
                                            Angle of Hatching
                                            • 11
                                            • 12
                                            • 13
                                            • 17
                                            • 18
                                            • 11 / 18
